Tvs 1900....ottp stg5?
Old Oct 26, 2014 | 01:31 AM
  #151
andrewcarr1993's Avatar
Originally Posted by Spawne32
Doesn't have anything to do with ported heads or cams or intake manifold design, has more to do with the fact that superchargers will just never flow the same as a turbo, not to mention the fact that they rob power as they make it. You have to think, every time you increase the blower speed, pressure gradient in the manifold, or increase the size and weight of the blower (for instance this TVS1900) it takes more and more energy to drive it through the belt system. Eaton stated years ago that (when properly sized and run at the rated speed) their 3rd generation superchargers would use anywhere from 8-10% of an engine's crank hp to drive the supercharger at its peak RPM. Any modification you do to the blower increases this parasitic draw exponentially. That is why the power gains become less and less significant the faster you spin a blower, M62 for example, not to mention they also become less efficient. Turbo's work entirely differently, they efficiently use engine waste to generate power, they push more CFM and they have no parasitic draw.
I'm so sick of the damn CSS gang, I pointed this out, and all you get is hate, apparently some d-bag thinks the TVS-1900 maxed will have a lower loss than an M62 maxed
Old Oct 26, 2014 | 01:47 AM
  #152
KMO43's Avatar
So they're saying it take more hp to spin the smaller m62 than the larger tvs1900?
Old Oct 26, 2014 | 02:02 AM
  #153
Yes, they couldn't comprehend that it's so much bigger it just takes more energy to spin at the same speed. I could see possibly 300 HP vs 300 HP because it's spinning so much slower but they didn't want to hear it. Just a bunch of uninformed idiots in a circle jerk over the 1900. Yes it's nice but half them don't understand it. One guy who I had the pleasantry to meet just has no idea, TVS car without any cooling mods...
Old Oct 26, 2014 | 02:12 AM
  #154
KMO43's Avatar
I'm a turbo guy but what I understand is that the 1900 with the more efficient 4 blade design will make boost per size more efficiently than the m62 ( like 80% of max vs 80% of max m62) but spinning the extra mass to 7 or 8000rpm will take more hp than spinning a m62. It's not like a supercharger blade is a small item
Old Oct 26, 2014 | 02:23 AM
  #155
I completely agree, yes it's a more efficient design, their only argument, but it's close to double the size, that a lot more mass to spin.
Old Oct 26, 2014 | 02:28 AM
  #156
KMO43's Avatar
I believe that the 1900 can prob flow the air to make the 550hp rating but I don't think it will happen on an lsj. I would love to see it and will be stoked if it happens but it's a lot of mass to turn for just a 2L 4cyl
Old Oct 26, 2014 | 02:40 AM
  #157
The big question I have is how much power are you loosing to turn it to see 500 at the wheels.
Old Oct 26, 2014 | 02:44 AM
  #158
KMO43's Avatar
Lots!
Old Oct 26, 2014 | 03:30 AM
  #159
ThexGovenor's Avatar
why would you ever listen to SS gang?
Old Oct 26, 2014 | 03:41 AM
  #160
KMO43's Avatar
How many people are in ss gang? Are they all dumb? I know nothing about this it can't be possible no one knows what they're talking about there like is being said
Old Oct 26, 2014 | 07:38 AM
  #161
goaliemo's Avatar
If the SS Gang is anything like Redline Forums Facebook Style, then their is only a handful of people that know what theyre talking about.
The rest are like, "im running a 2.6 pulley with just a fmhe because racecar!".
Which is why I stick to the forums. More people know what theyre talking about, and the information is at least archived on here.
Like this topic for example. Yes, I like it and want it. But I wont make any decisions until I see more tests from the people that know what theyre talking about. I want my facts straight so I am not one of those people.
Old Oct 26, 2014 | 09:09 AM
  #162
Josh@ottp's Avatar
The comparison should be between the 1320 and the 1900 because they are in the same family. We know that a 1320 can make about a max of 400 whp. Lets assume you are spinning it to the end of it's compressor map which is about 18,000 rpm (that's a 2.6" pulley at 7200 rpm). To equal that same amount of airflow from the 1900 you only have to spin it about 13,000 rpm. The 1900 is also about 67% efficient and the 1320 is only about 55% at this flow and pressure. This is at a 2.4 pressure ratio which is about 21 psi. The faster you have to turn something the more power it's going to take. I don't have time to find the specs on weight and do the math at this moment but I suspect that the 1320 is taking more power to turn at this point than the 1900 is. For sure the 1900 is putting out less heat. I will send an email to Harrop and see if they have graphed blower speed vs hp consumed for either blower.
Old Oct 26, 2014 | 09:13 AM
  #163
Josh@ottp's Avatar
On the intercooler cores and a HP rating. That is a number that has a lot of variables. I think it's best to just wait a few weeks and see what they can handle.
Old Oct 26, 2014 | 09:22 AM
  #164
Terminator2's Avatar
That band of idiots and their lack-lustrous leader need to get exterminated. They are diluting the gene pool.
Old Oct 26, 2014 | 09:54 AM
  #165
KMO43's Avatar
Well you said a lot of numbers there but proved nothing so it's on your car do a 1320 vs 1900 dyno for everyone!!!!
Old Oct 26, 2014 | 10:00 AM
  #166
26gen4's Avatar
for the tards
http://www.engine-expo.com/forum_200...rt_walling.pdf
Old Oct 26, 2014 | 12:56 PM
  #167
mrbelvedere's Avatar
depending on pulley and dampener configurtion it could take less power to spin then an m62 at the same pressure
they are not that big
depending on blower config there is a chance that you may not loose as much as you think
Old Oct 26, 2014 | 02:44 PM
  #168
Better off sticking to the forum for information. pretty much everything has been covered. SS gang has a few smart people but the majority are new owners who want something for nothing and are operating on bad info. Stick on here..
Old Oct 26, 2014 | 02:47 PM
  #169
26gen4's Avatar
Considering how everyone on here joined within the last 2 years this is not the SS gang...
all the triple OG's are gone for the most part
Old Oct 26, 2014 | 08:25 PM
  #170
KMO43's Avatar
I just wonder how much power it actually take to spin it
Old Oct 27, 2014 | 03:22 AM
  #171
But that's spinning the 1900 way slower which is beneficial and I pointed out. I'm just thinking the engine could have more stress making 500 on a SC than 600 on a turbo. Is that actually possible though with the power loss to turn it?
Old Oct 27, 2014 | 03:57 AM
  #172
KMO43's Avatar
Is the belt system strong enough to spin a 500hp supercharger without slipping?
Old Oct 27, 2014 | 04:01 AM
  #173
Never even though of that, I would assume so though. I wonder what is different on say a SVT cobra, wider belt or stronger all together?
Old Oct 27, 2014 | 07:13 AM
  #174
Staged07SS's Avatar
Administrator
Administrator
All the kiddies with SS Cobalts in my area seem to be in SS gang. I can tell with the mods they choose and how they act.
Old Oct 27, 2014 | 07:45 AM
  #175
phatnackySS's Avatar
I feel the same way about the cobalt community as a whole, maybe a hand full of people that know what they are talking about, and the rest of the self proclaimed experts probably never dealt with modifying cars before they got their cobalt.
