Drumrush's build thread
Old Nov 18, 2011 | 08:12 PM
  #276
c1_c1rca's Avatar
dont put your dick where you wont put your figure
Old Nov 18, 2011 | 08:21 PM
  #277
drumrush's Avatar
Lolz
Old Nov 18, 2011 | 10:26 PM
  #278
drumrush's Avatar
how many amps is the fuel pump hose? i got an add a fuse for the intercooler pump and it says dont go above 10 amps
Old Nov 19, 2011 | 03:23 AM
  #279
c1_c1rca's Avatar
i tapped it into my sunroof fuse..... so maybe 10, i think i got a 15amp fuse in there tho
Old Nov 20, 2011 | 07:52 PM
  #280
drumrush's Avatar
im starting this build in about an hour... wish me luck
Old Nov 20, 2011 | 08:56 PM
  #281
c1_c1rca's Avatar
Nice man good luck
Old Nov 20, 2011 | 08:57 PM
  #282
1LowLS's Avatar
good luck.pics pics pics
Old Nov 20, 2011 | 11:51 PM
  #283
drumrush's Avatar
no pics yet because my phone is dead, but i changed my plugs, took off my bumper, took off my IM/TB, rewired my tb harness, installed my new injectors, and test fitted the intake manifold. i would have tried to install it but my lower mount wont be here till tomorrow...
and i noticed that the intake manifold almost fit except for a wire connector thing at the bottom seemed to be getting in the way. anybody know what im talking about? its got a red rubber thing around it
Old Nov 20, 2011 | 11:52 PM
  #284
drumrush's Avatar
oh, and i changed my supercharger oil and did a few other things like that. not bad for 3 hours and taking my good old time!!!
Old Nov 20, 2011 | 11:54 PM
  #285
c1_c1rca's Avatar
sounds like the positive terminal to your starter, make sure your intake mani doesnt touch that or else youll ground out your car, that was a problem i had
Old Nov 20, 2011 | 11:55 PM
  #286
drumrush's Avatar
what did you do to fix it?
Old Nov 20, 2011 | 11:57 PM
  #287
c1_c1rca's Avatar
cut a piece off of my coupler and hot glued it to the top og the positive terminal and sat the intake mani on top so it wouldnt move
Old Nov 20, 2011 | 11:59 PM
  #288
drumrush's Avatar
hmm pics by any chance? and how did you get the mani to actually fit on top of it? it seems to really be in the way. and do you think i could cover it up with anything that will keep em seperated?
Old Nov 21, 2011 | 12:01 AM
  #289
c1_c1rca's Avatar
as long as a current cant pass through it anything should be find to use, and no i dont have any pics.... my intake mani fit in pretty easily.... i hope were talking about the same thing, u got pics of what your talking about?
Old Nov 21, 2011 | 12:02 AM
  #290
drumrush's Avatar
no because my phone is dead and the ****** thing takes forever to charge
Old Nov 21, 2011 | 12:04 AM
  #291
c1_c1rca's Avatar
lol shitty
Old Nov 21, 2011 | 12:07 AM
  #292
drumrush's Avatar
nevermind, i brought the charger into the garage with me and it worked. pic will be up in a minute
and some other fun pictures
Old Nov 21, 2011 | 12:09 AM
  #293
c1_c1rca's Avatar
yeah thats the positive terminal to your starter, u might be able to move it so its out of the way, if not make sure that does not touch the intake mani
Old Nov 21, 2011 | 12:11 AM
  #294
drumrush's Avatar
i hope i can move that ****. and if not ill probably put a nice piece of thin (but not too thin) rubber between em
Old Nov 21, 2011 | 12:17 AM
  #295
c1_c1rca's Avatar
yeah thats why i used a pice of the coupler i had, seems how i had to cut the coupler anyhow
Old Nov 21, 2011 | 12:18 AM
  #296
drumrush's Avatar
which coupler are you talking about exactly?
Old Nov 21, 2011 | 12:19 AM
  #297
c1_c1rca's Avatar
that holds my k&n intake to the thottle body, that rubber tubing = coupler
Old Nov 21, 2011 | 12:21 AM
  #298
drumrush's Avatar
ahhh gotcha
Old Nov 21, 2011 | 09:38 AM
  #299
drumrush's Avatar
i was able to trim away part of the connector that kept it from rotating, and now my manifold fits like a glove
Old Nov 21, 2011 | 11:01 AM
  #300
1LowLS's Avatar
make sure you have the seal for the bypass.It's green and goes in the circle part on your intake manifold.I cant see it in the pic,
