Jn2's goes the easy route
yeah we can figure out WTF is going on car likes to stay 200+, have bled the system twice, even tried a 80/20(water/coolant) mix, still doing it, even spent 10 bucks on watter wetter
to bolt the intake manifold to the engine you need
m6x1.0 75mm x2
and the other stock ones will work with washer to help make up for them beig longer than needed
to bolt the alternator on
m8x1.25 130mm x3
i messed up and got m8x1.25 75mm for the intake manifold, turns out i needed m6x1.0 x_x
m6x1.0 75mm x2
m8x1.25 130mm x3
It's the same threading as the throttle body bolts, just in 75mm lenght
Out here now...no one I recognize...
Ok here's how shot went down LOL
Losses:
K20a3 civic x2
Charger rt
B20vtec DC teg
Wins:
Svt focus
Some other integra
Also i've never had the car in the 4rth gear top end...but my a/f is 10.2...not good LOL, what's weird is in 2nd and 3rd it 11.8-12.3, and 10.2 in 4rth...I don't get it...may need to get with vince again..but I'll leave it alone for now...swap to a 3" pulley...get a ls4 tb, dual pass, and than I'll get a retune
Losses:
K20a3 civic x2
Charger rt
B20vtec DC teg
Wins:
Svt focus
Some other integra
Not stock cars...both have bolt ons and tuned...they are a 200hp car to start with...I have stock pulley, will be doing the fllowing to male sure this won't happens again
3" pulley
Ls4 throttle body
Dual pass
RAW 3" intake
Re-tune
3" pulley
Ls4 throttle body
Dual pass
RAW 3" intake
Re-tune
I don't know that an LS4 TB would be necessary but I wouldn't have thrown the stock pulley on there in the first place. Even stock pulley LSJs are slow...
note to self, take it through all gears while tuning
Hmmm do I need dual pass for 2.8"??? I kinds don't wanna run more than 15psi as idk how the stock engine react to that kind of pressure...I'll do a 2.9" at the lowest...
you might want to get one, hell we made one for liek 5 bucks in parts at lowes, its worth the time and effort
Hey don't u have access to the bolt sizes for everything at the dealership? I know at my local dealership they can tell me the bolt sizes for virtually any part for my car
I think he's saying that those bolts are the same size as whatever they are for the TB, only a diff length. But if you don't know the size of the TB bolts you're screwed
So I asked him what he used. He said.
m6x1.0 75mm x2
So I was simply asking if he took out the M6 studs that are in there now and changed them over to bolts for the intake. By looking at my intake, I cannot see anywhere else where two 75mm bolts would go.
I'm basically trying to figure out... do I need to drill and tap for the M8 bolts, do I not need to worry about bolts and can use my current studs, or can I simply use the two m6x1.0.x75's.
