Jn2's goes the easy route
JN2... couple of questions for you.
On the TB re-pinning and all. If our connector is a 6 pin and the LSJ is an 8 pin, how does that actual connector body fit in the LSJ TB?
I see that you mentioned in another thread you have 2 LSJ headers. I need one for my car so I can get rid of the SAI. Can you help me out with one?
I was told from the person who I bought it from, in this thread, that a 6 pin was not available. I just looked in the GM Parts Catalog and all TB's from 05-07 were the same, proving his claim a bit. What am I missing?
Yeah done and tuned ready to go
you can rewire an 8 pin TB to accept a 6 pin connector, as long as you have the pigtail of the 8pin. The 8 pin connector has 2 high voltage and 2 low voltage reference wires. The 6 pin connector only has one of each, hence 2 less wires. You can split the 2 wires in a 6 pin TB to make 8 pins, or you can join the 2 similar wires of each pair together in an 8 pin connector to make 6 pins
Thank you sirs, for your information.
Oh, one last thing. I'm trying to figure out where stuff goes, hoses, etc. The big nipple on the SC close to the TB. Where does that go?
Last edited by Gene Culley; May 2, 2009 at 08:28 PM. Reason: Automerged Doublepost
if you're talking about the brass one facing the front of the car, then there is a little plastic (the non flexing one) hose that attaches to it.
if you're thinking of the same one i think you are(towards the firewall), then it connects to the boost bypass actuator
There is the small one for the bypass actuator. There is one facing the front of the car, but that is on the TB and that goes to the evap solenoid. I'm talking about the big one to the left of the bypass valve shown in the pic, close to where the TB would mount.
Yes, I found on JN2's pics that the line goes from valve cover to the air intake. That was one of my other questions previously (not asked here).
I haven't had a chance to look in the parts manual yet so where does my current brake booster hose go? I guess I need to buy the one for the LSJ?
I did, lol. So stock pulley was 10 and 3.0 was 11? That doesn't sound right (from what I've been reading). I'm just asking because I decided to go ahead and get the 3.0 pulley instead of using the stocker.
Last edited by Gene Culley; May 3, 2009 at 11:06 AM. Reason: Automerged Doublepost
Thank you gentleman. You are making my preparation a great experience. I'm just trying to avoid tearing it down and then looking for more parts, lol.
-3.0 pulley is like 14-15psi
it attaches to the intake manifold on the 2.2 and 2.4. Its kind of hard to see until you're uninstalling the stock manifold. It is BARELY long enough to reach the new location, so you can reuse the stock hose.
I got ya now. Oh boy... well I bought a 3.0 pulley so we'll see what happens.
You are extremely valuable, lol. I checked this afternoon in the parts catalog and I did see it went to the intake on my car.
You know, the brake pedal is really bad on my car, 2009, and all of the other 2009's on the lot are like this... and the 2008's are NOT like this... and they upgraded the intake manifold for 2009, so I bet once I install the SC my brake pedal gets better!
Thanks for the info, I will be ordering the booster hose in the AM.
Last edited by Gene Culley; May 3, 2009 at 05:55 PM. Reason: Automerged Doublepost
