Jn2's goes the easy route
Old May 14, 2009 | 04:58 AM
  #401
Jn2's Avatar
Jn2
Originally Posted by TwoStep
You should have also pulled that charger.
I would assume 10Lbs and a 2.2 with supporting mods would be making around 210-230 WHP.
Nope...I'm in stock pulley..with a 3" I would see 220whp, and that's about 15psi
Also I think my headgasket may be blown...my coolant is magically dissappearing, along with the overheating issues I've been having since day 1...I think
-finished build
-started tuning
-coolant hit 240*+ during wot pull(upper radiator hose came off)
I think after that hose came off during tuning and us bit knowing and doubt wot pulls...so far no knock...no signs of engine damage...just coolant dissappearing, a engine that won't stay cool, and a possible bad gasket...I'll be checking the top of each piston and pray to see carbon build up...not a shiny top of the piston
Old May 14, 2009 | 04:59 AM
  #402
Jn2's Avatar
Jn2
-finished build
-started tuning
Old May 14, 2009 | 02:08 PM
  #403
HunterKiller89's Avatar
260bhp < 325bhp im afraid...even if they are an extra 1,000lbs... not to mention he has an extra gear over me..lol
Old May 14, 2009 | 08:00 PM
  #404
glen229's Avatar
where are you calculating BHP, just curious?
Old May 14, 2009 | 08:54 PM
  #405
Gene Culley's Avatar
Talking
Originally Posted by HunterKiller89
are you sure yu're not thinking of the M8x1.25x120mm for the alternator bracket/tensioner? I dont recall buying any additional bolts....
No he mentioned that we needed M8x1.25x130 for the alternator in the same post. Oh well. No one wants to answer the question so I'll just have to wait till install day and figure it out.
Old May 14, 2009 | 08:56 PM
  #406
glen229's Avatar
thats the best part
Old May 15, 2009 | 02:31 AM
  #407
Jn2's Avatar
Jn2
answered u twice...the 2 manifold bolts on the bottom r
M6x1.0 75mm
The m6x1.0 is my guess, I know it's m6, the treading is the same as a throttle body bolt, so go to Autozone, pop ur hood, remove 1 throttle bolt, go inside,find out the treading on the bolt, than get the exact one but in 75mm(u will order it, Autozone probably won't have it) but the point is now u have ur size, and I told u the lenght is 75mm
Also found another problem, my intercooling system was flowing air thru it, a lot of it, I managed to pour about 80oz of water into it tonight, I know bc I used 5 20oz bottles, and some spilled so about 80...I could tell bc as I started filling it with the pump pumping I could hear it when it touched the hot manifold and after a while I got it filled, well now when the pump is on I can hear water plumbing thru, before I would hear the pump only...so this whole time I was blowing useless hot air inside the engine...
Old May 15, 2009 | 03:21 AM
  #408
the interceptor gauge has a bhp estimate based on MAF readings. its not the most accurate thing in the world, but all i have to go by at the moment
Old May 15, 2009 | 04:11 AM
  #409
Jn2's Avatar
Jn2
260bhp < [b]330whp [\b]im afraid...even if they are an extra 1,000lbs... not to mention he has an extra gear over me..lol
Fix'd, from what he said he made that much
Old May 15, 2009 | 08:05 PM
  #410
Talking
M6x1.0 75mm
Thanks, I figured as such. You mentioned the sizes, but not where they went. It is M6x1.0. I am just trying to get all of my bolts ahead of time, no big deal.
Old May 17, 2009 | 12:50 PM
  #411
IonNinja's Avatar
where are you guys finding that upper radiator hose? whats the brand or p/n?
Ive seen the chrome one at an auto parts store and that ****** was $60??
Old May 17, 2009 | 02:30 PM
  #412
Jn2's Avatar
Jn2
I got a universal bendy one, 1.5" in/out...I forgot the part #
Old May 17, 2009 | 04:03 PM
  #413
IonNinja's Avatar
a "universal bendy one" eh? that helps
Ive seen like 3 of you guys with the same hose and I cant find it at Checkers
Old May 18, 2009 | 04:34 AM
  #414
Jn2's Avatar
Jn2
It's a universal hose, go to Autozone tell them u need a universal radiator hose, desveude it as a straight hose with bendy things, yes sounds retarded but they'll know what u mean, measure to make sure it 1.5" in/out after that get on that a good hmmm...2ft, than trim it to fit, ps if you trim it clip the metal spring on the inside so when u clamp it it doesn't clamp the spring...
iPhone touchscreen>me
Old May 18, 2009 | 08:42 AM
  #415
stenguyen1's Avatar
it was called a flex house where you can get it at advance auto parts.
Old May 18, 2009 | 07:28 PM
  #416
Talking
I bought the GM one so that I don't have any issues.
Old May 19, 2009 | 04:30 AM
  #417
Jn2's Avatar
Jn2
I had to double clamp mine on both ends, it keep busting free during wot pulls...
Old May 19, 2009 | 09:38 AM
  #418
utsadude's Avatar
That was fun...
Old May 19, 2009 | 09:43 AM
  #419
stenguyen1's Avatar
i didn't have to use double clamps. thats weird tho.
Old May 19, 2009 | 11:31 AM
  #420
IonNinja's Avatar
That's comforting!
Old May 19, 2009 | 03:10 PM
  #421
Jn2's Avatar
Jn2
If u do it the first time around it's no big deal, I didn't know it was the clamps until the third time it did it
Old May 19, 2009 | 03:15 PM
  #422
Edubs's Avatar
Try getting better clamps?
Old May 19, 2009 | 08:13 PM
  #423
Talking
I am wondering if it is because the aftermarket hose is not formed the same as stock? I will find out when I do mine soon.
Old May 20, 2009 | 08:15 AM
  #424
stenguyen1's Avatar
instead of usin the same hose clamp that stock has thats clamps on. use the clamps that you screw on tight. so than u know it will hold it right.
Old May 20, 2009 | 09:14 AM
  #425
utsadude's Avatar
He used a screw on clamp (proper name? hose clamp?) it took two to hold on the hose to the radiator and the block each. we dumped coolant on the ground on more than one occasion...
