Jn2's goes the easy route
what length did you guys get on the flex hose?
2ft is way too long and there is only about 3 inches or so on each side of that hose that can be cut
im staying boosted, i found a job, i start on the 17th
you can cut more, measure what u need, use some pliers and grab the spring and pull it out to how ever much u need to cut off, than pull it out about 3" more...than use some wire cutters and cut the spring, after that, use the plier to push the spring back inside the hose...
just ended up getting a shorter one around 1.5ft and trimming that to fit. worked much better...
I need some help on the hose routing setup for the IC system. I cannot find a diagram anywhere?
I have an extra coolant tank and the ZZP H/E which doesn't have a small nipple on it. What am I to do?
there you go
here's something i whip'd up...going to work on it some more in the weekend to get a few pages of what ive done with the car from being stock>bolt ons>boosted
wanna probono me a 3" intake
im going to need one when i get a Ls4 throttle body
almost forgot here's a vid i shot earlier tonight
http://www.youtube.com/watch?v=F9mv1jvtasU
^^^ 7k redline, i didnt shift at 7k everytime as i was trying to go easy on it during the turns
i wont use adapter plate, i'll port the supercharger inlet instead and save some cash
also took the time today to work on the h/e
^^^^ NOW
VVVV BEFORE
^^^^ NOW
VVVV BEFORE
Thank you for taking the time to make a diagram. I had panic so I decided to overnight the stock SC tank setup. I wish I would have seen this before i did that lol. Oh well, it will look even more factory now.
i cut its lip off
anyway here's some a vid i did of me doing launch practice
http://www.youtube.com/watch?v=bgWzO...e=channel_page
Current method of plugging
previous method:
first method: used a aluminum piece to push down a cut piece of hose to plug the hole
Cptnslo
Sep 24, 2015 09:32 AM
lol...
