Stage 3 Comp Cams....Anyone done it???
Old Feb 1, 2010 | 11:59 PM
  #126
xxxxsh4d0wxxxx's Avatar
Originally Posted by huckernage
6 pins instead of 8 pins
Okay, so all I need is just the TB itself from a 2008 2.4? Correct?
Old Feb 2, 2010 | 11:53 AM
  #127
huckernage's Avatar
if this TB is 6 pin go for it
Old Feb 2, 2010 | 01:06 PM
  #128
Yeah, but I don't know which year 2.4's have which pin!
I'd assume since my 2008 has a 6 pin that I want a 2008 2.4 TB?
Old Feb 2, 2010 | 03:10 PM
  #129
huckernage's Avatar
you can try to find the diagram of rewire from 8 to 6 pin. it here somewhere
https://www.cobaltss.net/forums/show....php?p=4588024
Old Feb 2, 2010 | 05:46 PM
  #130
BlaqkBalt's Avatar
what year 2.4 tb would i use for my 09?
Old Feb 3, 2010 | 03:42 AM
  #131
There is a way to do it without rewiring.. Isn't there..?
Old Feb 3, 2010 | 08:08 AM
  #132
huckernage's Avatar
there is the way to rewiring from 8 to 6 maybe that can help you
Old Feb 3, 2010 | 12:31 PM
  #133
Yeah, see, the thing is, I know there is a way to do it without rewiring.. IE, buy the correct TB from the corresponding year 2.4
I am just unaware which year is as such.. I believe, though, that it is 2008.
Old Feb 3, 2010 | 02:37 PM
  #134
huckernage's Avatar
go in section 2.4 and ask there
Old Feb 3, 2010 | 02:45 PM
  #135
06_ion2's Avatar
Buy a 2.4tb from the same year or it wont plug in.
Old Feb 4, 2010 | 12:33 AM
  #136
Alright, that's the answer I wanted, thank you.
Now I just need to find a soul, with a 2.4, willing to sell their TB..
Old Feb 10, 2010 | 08:24 PM
  #137
NWAE Cobalt's Avatar
ok, so back to exhaust/ headers
ill come right out and say it, i was wrong
talked with dan this weekend and he supports your side of it. the tri y (4-2-1) header is GREAT from idle till 5500rpm...after that it falls on its face! thats why im looking to change now
my misunderstanding was in the long/ midlength tubes which are GOOD for power, if sized right they can help scavenging and are better up high (someone correct me if im wrong).
he has my car for some R&D work right now that he needed to get done, but when that is overwith we will see what i can convince the gf to let me spend to change things up a bit
Old Feb 12, 2010 | 12:52 PM
  #138
Yeah, apparently he told me that a properly designed 4-1 will not even have much difference in bottom/mid, but you WILL notice the difference up high.
Maven, though, told me 4-2-1 was better, and that a small displacement motor is best served by a multi-merge header.
I'm sure it's all preference.
Old Feb 12, 2010 | 02:02 PM
  #139
true, although this explains why my dyno falls on its face after 6000rpmish range...
Old Feb 12, 2010 | 02:07 PM
  #140
Who goes above 6,000 RPM daily, though?
Old Feb 12, 2010 | 03:11 PM
  #141
huckernage's Avatar
everyday not everytime, even 7500 on stg2 cam.
Old Feb 12, 2010 | 03:18 PM
  #142
All I'm trying to say is the 4-2-1 might be the better choice.
All I know, is I would ask Clear Image, as they're the ones who make the parts, and they would know best.
A properly designed 4-1 can outperform a 4-2-1 in all aspects, even down low, and vise versa!
I believe Dan told me that their 4-1 did outperform their 4-2-1, and that the 4-1 was the better choice.
Old Feb 12, 2010 | 07:44 PM
  #143
huckernage's Avatar
dont forget it is a cam stg 3 thread. you will amputate your low end to get high peak with Cams
Old Feb 12, 2010 | 11:34 PM
  #144
i did talk to dan
he is the one that told me that.
if you are looking to buy a 4-2-1 setup...PM me...I can probly help ya out
exactly
Last edited by NWAE Cobalt; Feb 12, 2010 at 11:34 PM. Reason: Automerged Doublepost
Old Feb 13, 2010 | 12:45 AM
  #145
Well if you went with a 4-2-1, and stage 3 cams, wouldn't you be getting the best of both worlds?.. My car will probably never see cams as I don't feel like replacing the valve springs and retainers.. If anything it would only be stage 2.
i did talk to dan
exactly
You're selling yours? ^Like I said above.. I want to find out which is best for my application as I'll more than likely never see cams, but who knows.
Does the 4-2-1 pull good down low and in mid range?.. And what R&D work are we talking about?
I don't understand what you mean.
Last edited by xxxxsh4d0wxxxx; Feb 13, 2010 at 12:45 AM. Reason: Automerged Doublepost
Old Feb 13, 2010 | 01:02 AM
  #146
the setup im selling is GREAT for low to midrange, it makes AWESOME power till 5500-6000rpm....and i need to be able to BUILD to 7.5k rpm....
i just posted a for sale thread about it, but pm me what your looking to spend and we can talk
https://www.cobaltss.net/forums/parts-66/clear-image-4-2-1-header-catless-dp-204597/
and btw...this is PERFECT for you if you are looking to stay n/a without cams
and i cant talk about the r&d work right now....i will when i can
btw, the reason it is not great for a bigger cam, is because the cam doesnt start building till 3500-4000rpm and the header starts dropping power at 5500-6000rpm...so you dont really have much of a power band. having an exhaust setup that works till 7500+rpm lets you build power further and keep in your powerband throughout a race
Last edited by NWAE Cobalt; Feb 13, 2010 at 01:02 AM. Reason: Automerged Doublepost
Old Feb 13, 2010 | 01:56 AM
  #147
https://www.cobaltss.net/forums/showthread.php?t=204597
So with no cams you'd say 4-2-1..
Cams.. 4-1?
I'd consider buying that from you.. If it was catted.
Also, didn't they change how they made their 4-2-1?.. They used to have cylinders paired by firing order didn't they?.. It's different now, though.
Old Feb 13, 2010 | 02:00 AM
  #148
correct on the pairing, it is the original.
its not catted now, but it would be an easy swap for a shop.
and ya, no cams i would say 4-2-1, with cams, 4-1
Old Feb 13, 2010 | 02:05 AM
  #149
Any idea on why they changed it up?.. I remember seeing a picture of the older model and it was goofy looking.. Maybe fitment issues?.. Or performance issues?
I'm also going to buy their 2.5" cat-back, I emailed them for pictures of it, so I can get a feel for the muffler and ****, but no email back yet.
Old Feb 13, 2010 | 02:50 AM
  #150
dan is pretty busy, should have pics online though
as far as changing it, we talked about that today haha. he said that they werent really selling any of the first model just because they werent deep into the balt market yet. he tossed the jig for it and then a few years later when they decided to start making it again, they redesigned it a bit. he said it should give any diff in performance as far as changing it up. no fitment issues with it and its performed great!
