first htv 1320 received
Old Mar 21, 2008 | 12:57 AM
  #751
USMCFieldMP's Avatar
Rattlesnake Race Shop
Originally Posted by Witt
About a 1.3psi increase over the stock blower and 2.8" pulley if you do the math from that MAP value above. 15.3 stock blower vs 16.6 with the TVS.
So you had a 1.3psi increase over the M62's 2.8"... by using the TVS with a 3.34"?
Am I right on that one?
Old Mar 21, 2008 | 12:58 AM
  #752
Raven SS's Avatar
Originally Posted by fast98
raven ....ya its frequency will lower but thats only becuase its in a bigger pipe, the stock maf in a 85mm housing will give the same readings
witt i would go with a return style with a walbro in tank
yea me and witt were actually just talking about our stock maf in a 4 inch pipe...
  #753
Witt's Avatar
Yeah, thats about right. My ambient pressure is 14.1psi here.
Old Mar 21, 2008 | 01:03 AM
  #754
Josh@ottp's Avatar
what are the stock pumps dimensions
Old Mar 21, 2008 | 01:06 AM
  #755
Raven SS's Avatar
i got a walbro gss342
Old Mar 21, 2008 | 01:34 AM
  #756
SK360's Avatar
Saw this blower of FAIL tonight, NAWT impressed.
Has a pulley the size of a harmonic balancer on it.
Weaksauce
Old Mar 21, 2008 | 01:35 AM
  #757
Witt's Avatar
Originally Posted by SK360
Saw this blower of FAIL tonight, not impressed.
Weaksauce
diaf.
I'm looking for them. I had a spare and took measurements from but can't find the damn info now.
Old Mar 21, 2008 | 01:48 AM
  #758
SK360's Avatar
GTO Key Owns Brand New TVS with Harmonic Balancer Pulley... Story @ 11.
Old Mar 21, 2008 | 02:16 AM
  #759
Witt's Avatar
I know you believe the LSJ with the TVS is faster, but did you really have to swap the LS2 out for it?
Hmm, from what Paul has been posting about running the MAF out of range on his turbo, I'm thinking if the PCM can continue to convert cylinder airmass from frequency at higher than 11,100hz tweaks can just be made in the PE table.
I'll get it to work one way or the other when I swap pulleys, its just getting the fuel there that's going to be fun. I'm seriously considering the Aeromotive Digital FMU at this point. I already have the required pump.
Old Mar 21, 2008 | 02:24 AM
  #760
2K5SS/SC?'s Avatar
Witt, how did you get the 79# injectors to work out and where did you get them? I thought I saw something back awhile ago, but I can't remember where. Just curious if it's a pain in the ass to control them HPTuners.
Old Mar 21, 2008 | 02:25 AM
  #761
Witt's Avatar
Racetronix.
They are disc style and easier to control at tiny pulse widths compared to the pintle style 60s.
Old Mar 21, 2008 | 03:57 AM
  #762
jgarciarivera's Avatar
A walbro gss342 does not fit inside the black cylinder module in the fuel tank. Is longer than stock
Old Mar 21, 2008 | 04:37 AM
  #763
Scythe_Snake's Avatar
I was under the impression that with stock internals and 60's it was possible to run it. Or was the video with the IRL not safe?
Old Mar 21, 2008 | 04:54 AM
  #764
How is the low-end? Does it seem to lag as much as the M62 did? More or Less?
Is 35 to 40mph still right about where it takes off
Old Mar 21, 2008 | 05:13 AM
  #765
Blown 4-banger's Avatar
Well, it seems with all the fueling problems, I might just go with a relatively large (haven't decided size yet), in-line pump, and pretty much remove all the stock fuel system (remove stock pump, install larger fuel lines, inline pump, return line, and regulator, and just hook the pump up to an on/off switch), with a set of 83 lbs/hr injectors. :shrug:
Old Mar 21, 2008 | 10:00 AM
  #766
lsjwannabe's Avatar
it completly blows the tires off with no effort, all around more power.
Old Mar 21, 2008 | 10:02 AM
  #767
Amazing... that would mean (in my eyes) that there is A LOT less parasitic loss... because I think that is what really kills us down low with the M62. Like second gear doing 25 is just dead.
Old Mar 21, 2008 | 10:03 AM
  #768
Josh@ottp's Avatar
witt the maf is gunna be accurate to 11250 hz and after that you can just add in with pe.
blown4banger go with a intank pump, the external are noisy and unreliable. the pump is acctually cooled by the fuel around it, so a external pump is gunna run hot and that shortens its life.
and i dont think anyone is gunna need larger than a 3/8 fuel line from what i've seen
Old Mar 21, 2008 | 10:08 AM
  #769
lsjwannabe's Avatar
well im barely spining this blower half as hard as i was the m62, it's hard to completely say though i would have to go out and dyno to lay the final verdict down but i can say pretty much it will make more power all over.
Old Mar 21, 2008 | 10:25 AM
  #770
Rangerondubz's Avatar
When is everybody going to the dyno?
Old Mar 21, 2008 | 10:27 AM
  #771
Edubs's Avatar
I'm surprised Witt's **** isn't in a thread by now. I'm waiting patiently, figure I may get a PM at some point...
Old Mar 21, 2008 | 10:29 AM
  #772
WSFrazier's Avatar
We haven't even gotten decent videos yet. The weather here fucked us the first night.
I'm hoping he gets time from work to put the 2.75" on this weekend, I want to see first hand how that fkr compares to Dans RL and my 2.5 pullied car.
Old Mar 21, 2008 | 10:31 AM
  #773
Edubs's Avatar
F*uckin' weather...
Old Mar 21, 2008 | 10:34 AM
  #774
SSdan's Avatar
****** weather is right!
Old Mar 21, 2008 | 10:35 AM
  #775
lsjwannabe's Avatar
you ever race a stock cobalt, think of that
i ran out of fuel so i have to try a few things to see if i can band aid it if not it may be a while.
Last edited by lsjwannabe; Mar 21, 2008 at 10:35 AM. Reason: Automerged Doublepost
