Harrop HTV1320-LSJ using Eaton TVS technology
Old Feb 29, 2008 | 09:27 PM
  #1126
Eagle_f90's Avatar
What is this updated intake gasket?
Old Feb 29, 2008 | 10:44 PM
  #1127
2K5SS/SC?'s Avatar
Originally Posted by AlphaJaguar5
I would recommend the studs for anybody pushing an excessive amount of air but the stock head gasket is more than fine for 500hp applications running under 30psi.
Remember, Psi is a measurement of restriction not of air flow. You could push double the amount of air that an Eaton M62 makes at 15psi through your engine and still run 15psi if your head, intake manifold and exhaust are all size properly.
Yeah, I understand the difference between CFM's and PSI. I guess I could have stated that one better, but I get lazy when typing.
Old Mar 1, 2008 | 09:24 AM
  #1128
TVS_SS's Avatar
CFM is not a good measure.. CFM is a VOLUME flow measurement..
Lb/hr or Kg/hr is a MUCH better measurement because its a MASS FLOW measurement. and you AFR is a MASS based ratio.
Old Mar 1, 2008 | 09:59 AM
  #1129
Rodimus_Prime's Avatar
I would think a piston install is a little bit more involved than just going out and get the diamonds and dropping the pan with the crank? or is it
ive never done anything like that and i have little faith in local shops knowledge of domestics, who do I go to if all I want is pistons?
Old Mar 1, 2008 | 11:10 AM
  #1130
2K5SS/SC?'s Avatar
Rodimus, you have to take the head off, drop the oil pan, undo the rod bolts and pop the pistons out of the top. That's sounds easy enough, but doing it will take a lot longer. Plus, then you have to worry about the rings seating right if you don't hone the cylinders, and honing should only be done with the rest of the block apart to prevent nicking the crank.
Old Mar 1, 2008 | 11:24 AM
  #1131
Raven SS's Avatar
this is where alot of members are going to have alot of problems. Killing the pride thing and talking to a shop that works on hondas to see if the can get there cobalt worked on LOL
Old Mar 1, 2008 | 02:42 PM
  #1132
shabodah's Avatar
If you can control the weather, would you please make it warmer outside tomorrow?
Old Mar 3, 2008 | 01:54 AM
  #1133
bigrroberto's Avatar
can we start a thread with the hard facts on this sc. I'm sure many of us dont want to read through the 60 pages of bs...
Old Mar 3, 2008 | 01:55 AM
  #1134
Raven SS's Avatar
if there was..im sure we would...test units will be out shortly then the info will pour in
Old Mar 3, 2008 | 11:23 AM
  #1135
Raven SS's Avatar
its moday...and march...im excited for this thing to finally come out...
Old Mar 3, 2008 | 02:55 PM
  #1136
damn thats kinda what i thought, id rather get it done right then do more harm then good getting it half assed
Old Mar 4, 2008 | 01:18 AM
  #1137
MrSlickSter06SS's Avatar
So when is it exactly that this is gonna get released?
Old Mar 4, 2008 | 01:27 AM
  #1138
USMCFieldMP's Avatar
Rattlesnake Race Shop
March 2009
Old Mar 4, 2008 | 01:32 AM
  #1139
Scythe_Snake's Avatar
March 2009
Old Mar 4, 2008 | 01:39 AM
  #1140
I lol'd too.
What really makes me lol is when i read the Hahn thread that says that their 20g kit will be out by the end of the summer in 2007... I roflcopter then.
Old Mar 4, 2008 | 01:49 AM
  #1141
March 2009
haha serious?
Old Mar 4, 2008 | 02:27 AM
  #1142
No... it is supposed to be released sometime this month!!!
Old Mar 4, 2008 | 11:09 AM
  #1143
Raven SS's Avatar
damnit the anticapation is killing me..im ready to press send on my paypal account
Old Mar 4, 2008 | 11:53 AM
  #1144
Omega_5's Avatar
So.... ZZP doing the retailing huh?
Old Mar 4, 2008 | 12:09 PM
  #1145
WSFrazier's Avatar
Doubt it. ZZP just got butt hurt.
  #1146
Raven SS's Avatar
huh?
Old Mar 4, 2008 | 12:14 PM
  #1147
Omega_5's Avatar
WTF are you talking about?
Old Mar 4, 2008 | 12:33 PM
  #1148
Area47's Avatar
Rent me! per hour
heheeheh
i giggled
Old Mar 5, 2008 | 03:59 AM
  #1149
EmperorJJ1's Avatar
ok ill send you my address... i forget if paypal has gift as a category to send money.... *trailing off*
Old Mar 5, 2008 | 06:51 PM
  #1150
Raven SS's Avatar
ahhhhh wensday is almost overwith..
