HARROP TVS, What You Need To Know & FAQ
Old Jan 18, 2012 | 11:46 AM
  #401
RooTBeeR's Avatar
ok, perfect so if i take it of(again smh) i should be able to see any scoring though the outlet on the rotors and wiggle them to see if i have any play...how ever, they looked perfect, like not even the coating even had any wear when i put it on, cant say if i did or didnt have any play...might pull it soon any way just too look, i could do all the work on the blower myself if i had to so not worried about that. just 10-20 bux for bearings, no biggie
Old Jan 18, 2012 | 12:04 PM
  #402
Bluelightning's Avatar
Got Bewst?
Originally Posted by Jrhdpaintball
Dyno tested when i first got the blower and ran 298hp, tested after all this, even with the scored up housing, still pulled 295 hp, with the same run, so i dont see this blower being a problem right now
both pulls were 20ish psi, no loss in psi
dont be afraid of this happening, just be aware if you have a doubt about it, i would recommend to take it off just to be safe, and if you can afford send it out to get the bearings replaced...
What pulley were you on when you dynod? Running meth or e?
Old Jan 18, 2012 | 04:05 PM
  #403
Jrhdpaintball's Avatar
3.1? whatever the stock pully is. by the time i got dynoed the first time i was using meth on 93octane, mild tune. it was a hot day and didnt want to push really hard
Old Jan 18, 2012 | 04:14 PM
  #404
RooTBeeR's Avatar
80mm/3.15" decent numbers for a mild tune stock pulley
Old Jan 18, 2012 | 06:52 PM
  #405
i also reved it to 7500... but ive got a spare motor thats built ready to go in, so i could afford to rev it higher
these love octane and high revs...area47 had a good comparison somewhere on here
Old Jan 18, 2012 | 07:45 PM
  #406
freakta's Avatar
my m62 did the same thing with its bearrings.... thats why i have a tvs now.
Old Jan 19, 2012 | 07:25 AM
  #407
Staged07SS's Avatar
Administrator
Administrator
Truth.
Old Jan 19, 2012 | 10:42 AM
  #408
RooTBeeR's Avatar
bleh...guess i can add this here nothing spactacular
Progress, there's more in there though...
Old Jan 19, 2012 | 10:51 AM
  #409
Staged07SS's Avatar
Administrator
Administrator
Progress is progress man.
Keep it up!
Old Jan 19, 2012 | 05:25 PM
  #410
zrated89's Avatar
1320 times or go home :P
Old Jan 23, 2012 | 11:25 AM
  #411
shasam1721's Avatar
let me get this straight. i want to get the ottp stage 3 kit with the tuned pcm. is it not possible to tune the pcm they send you? cause i was planning on sending my old one back as a core to get some cash. 60# are alright and probably wouldnt see max capacity ever? or are 80#s worth it? that and which spark plugs should i get there iridium and theres copper. ive heard people have problems with one and the other works, but then other people have problems with that one and be fine with the other. did anyone else notice they dropped the price on that kit by 500 bucks on black friday? ill prob wait till next black friday to get it and hope they do that drop again
and i have searched and read the threads on the ottp stage 3
Last edited by shasam1721; Jan 23, 2012 at 11:25 AM. Reason: Automerged Doublepost
Old Jan 23, 2012 | 12:02 PM
  #412
ebristol's Avatar
It is possible to tune the PCM they send you. They will send you a base tune for the setup. To get all the power out of that kit, you are going to want a custom tune.
60# injectors are okay if you only plan on running gasoline. If you plan on running E85, then you should get 80# injectors.
I prefer NGK copper plugs. Other people like iridium. I run Copper plugs for one year and then replace them. They are cheap so if I only get 10-12k miles on them, I don't care.
I don't think there is any gaurentee that the kit will go back on sale next black Friday. IIRC, Josh had one blower with some small damage that did not effect performance. He was able to discount that blower with the kit.
Old Jan 23, 2012 | 01:29 PM
  #413
i think thats the one bluelighting got
Old Jan 23, 2012 | 02:09 PM
  #414
ebristol's Avatar
Yeah. There was a small corner of the inlet flange that got bent. Josh fixed it but could not sell it as new.
Old Jan 23, 2012 | 02:21 PM
  #415
Got Bewst?
Yup that's the one I picked up. It was so minor and josh gave me a smokin deal on it. Not to mention repairing and repainting the tvs for free with an inhouse warranty.
Old Jan 23, 2012 | 05:25 PM
  #416
shasam1721's Avatar
wow really? i thought that was just a black friday thing. i talked to them and they said the price would go back up after that weekend. so it did. now its back at 2400 instead of 1999. so the tune they send on the pcm can be tweeked to make it custom then? 10-12k miles is fine with me for copper plugs. ha.
Old Jan 23, 2012 | 06:32 PM
  #417
Got Bewst?
Yup you can get a custom tune after they send you your PCM. If its anything like the canned tune i got from them when I bought my stage 2 is its gonna be piiiiiig rich.
Old Jan 24, 2012 | 09:47 PM
  #418
07sssc's Avatar
Im torn between a tvs and a zzp turbo swap kit. I know my ideal goal is 300-350 anywhere in between i would be happy. Im sure with my setup right now and a 2.9 pulley i could hit 300 on a tvs. An buying a tvs is a heck of a lot cheaper then turbo. Also i live in Wisconsin we have e 85 everywhere. Hell i got 2 e85 pumps in my city alone.
Just looking for some insight on how everyone is likeing the tvs.
my mods right now s3 heat exchanger dual pass end plate option b mid length header 3inch down pipe full 2.5 magnaflow exhaust 60lb injectors.
Old Jan 24, 2012 | 09:51 PM
  #419
Got Bewst?
Well you are pretty much set up for a TVS and your power goals are 300-350whp. I say definitely do the tvs. Especially if you have E around.
Old Jan 24, 2012 | 10:27 PM
  #420
07sssc's Avatar
Ya Blue one perk of wisconsin is we have a **** ton of corn and we produce alot of e85. Im just trying to see what setup is going to cost me less and still make over 300 wheel hosepower. 4k is a huge dent in my wallet for a turbo lol. i can deal with a used tvs for 1200 lot easier.
my only thing is the whole rotor problems and the socing on the housing. how many of u guys had to pull off ur tvs to fix them ? that scares me. but with every great thing comes a risk !
Old Jan 24, 2012 | 10:30 PM
  #421
ebristol's Avatar
And you have one of the best LSJ tuners in your back yard.
Old Jan 24, 2012 | 10:50 PM
  #422
Got Bewst?
Ah I wouldn't let that scare you. Jrhdpaintball is the first TVS that I had ever head of that happening. And if it does, well buy some needle bearings and rebuild it haha. You've already spent the money on supporting mods for a supercharger. You will run 350whp easy on E. Especially with a damn good tuner like ebristol.
Old Jan 25, 2012 | 01:06 AM
  #423
07sssc's Avatar
Hey blue best thing about E-bristol is he only lives like 30-40 mins away from me lol. We both live in wisconsin in the states. We have talked a little bit. although im not sure if he remembers lol.
that reminds me dont u have facebook Bristol it would be nice to chat on there so much easier lol
Old Jan 25, 2012 | 02:16 AM
  #424
shasam1721's Avatar
is the stock clutch able to handle 350whp? does anyone else with a tvs have stock clutch? if not wats the best brand to get? spec? act? exedy?
Old Jan 25, 2012 | 06:13 AM
  #425
07sssc's Avatar
My buddy had a stock clutch on his tvs he was a little bit over 300 to the wheels. his lasted just fine. thing is u can have ur fun with ur car but u beat on something in ur car for to long and to hard things will break.
