HARROP TVS, What You Need To Know & FAQ
Old Jan 25, 2012 | 07:22 AM
  #426
Staged07SS's Avatar
Administrator
Administrator
Originally Posted by ebristol
And you have one of the best LSJ tuners in your back yard.
What's his name??
Old Jan 25, 2012 | 10:03 AM
  #427
Bluelightning's Avatar
Got Bewst?
GMPP clutch is a great bang for the buck when running a tvs.
Old Jan 26, 2012 | 12:10 AM
  #428
InfraRedline's Avatar
Just finished putting mine in a few hours ago and took it for its first drive
Old Jan 26, 2012 | 03:53 AM
  #429
07sssc's Avatar
his name is mr anderson
Old Jan 26, 2012 | 09:15 PM
  #430
shasam1721's Avatar
softer or harder than stock? sometimes ive seen stronger clutches easier to push in...oddly. i would think it would alwasy require more force with something more durable. take the whole engine out to get at it?
Old Jan 27, 2012 | 12:06 AM
  #431
Yep just a little stiffer than stock, which is nice cause the stock mashed potato feel always bugged me
And no I didnt take out the engine. I dropped the subframe and then dropped the trans. Follow the GM build book and youll be golden.
Old Jan 27, 2012 | 05:04 PM
  #432
zrated89's Avatar
thats what i did didnt need the build book though only pain is that blasted 15mm behind the starter lol
Old Jan 28, 2012 | 02:15 AM
  #433
That could be your problem, cause its an 18mm!! :P just bustin ya
As I told bluelightning in PM, the build book is nice because it gives you all the tq specs and bolt sizes which helps so your not running back to the tool box over and over
Old Feb 2, 2012 | 04:36 PM
  #434
Got Bewst?
Just curious, what kind of AFR's are you guys running with your TVS?
Old Feb 2, 2012 | 05:35 PM
  #435
ebristol's Avatar
Same as M62.
Mid 11s for safety and high 11s with a spot on tune.
Old Feb 3, 2012 | 01:13 AM
  #436
Yep, just as EB said. My tune is set up to start at 11.5 AFR in the mid range and work its way to 11.8 or so by redline. Should be going to the dyno within a few months whenever it gets here to see how a few different tune setups work.
Oh and tomorrow or saturday is valve spring install day Huge thanks to Hawlyns for letting me borrow the tool!
Old Feb 3, 2012 | 01:49 AM
  #437
Got Bewst?
With my current set up and tune I run 11.5 all the way though. Running something like an 11.8 on top is it like a you may or may not blow up your motor? This is my dd and I obviously want it to be safe but I want a spot on tune at the same time haha. Just a little torn on how aggressive to go.
Old Feb 3, 2012 | 01:54 AM
  #438
11.8 is just fine. On E85 Ive ran as high as 12.5 or so but without a dyno its hard to tell if it made more power or not, but with some research Im thinking I would start losing power running it that lean on a blower setup like this. Typically most people wont go leaner than 11.8 on gas.
Old Feb 3, 2012 | 10:20 AM
  #439
Got Bewst?
Good to know. Thanks!
Old Mar 25, 2012 | 08:04 PM
  #440
Billig ss/sc's Avatar
bump for a good thread with lots of info
Old Mar 25, 2012 | 11:08 PM
  #441
Got Bewst?
Bump? It's a sticky lol.
Old Mar 25, 2012 | 11:23 PM
  #442
You're goddam right I did lol
Old Mar 26, 2012 | 01:17 AM
  #443
sjc0013's Avatar
Window Licker
Yeah imma need a retune for sure, Afr is right at 10.0 at wot
Old Mar 26, 2012 | 08:17 AM
  #444
zrated89's Avatar
mines at 12.2 pussies :p
Old Mar 26, 2012 | 08:34 PM
  #445
WickedSS2005's Avatar
Yeah, well mine's 8.2 at WOT
Old Mar 27, 2012 | 12:32 AM
  #446
383_Stroker's Avatar
^ Ghey
Old Mar 27, 2012 | 01:03 AM
  #447
Originally Posted by 383_Stroker
^ Ghey
Actual E85 AFR I bet lol
Old Mar 27, 2012 | 07:09 AM
  #448
Staged07SS's Avatar
Administrator
Administrator
For sure
Old Mar 27, 2012 | 04:21 PM
  #449
RooTBeeR's Avatar
...mine hits high 9's on 91octane
stock tune ftw!
Old Mar 27, 2012 | 04:27 PM
  #450
c1_c1rca's Avatar
sub'd
