HARROP TVS, What You Need To Know & FAQ
Old Feb 15, 2010 | 07:42 PM
  #151
SSLOW06's Avatar
Riiiiiiitttteee !
Old Feb 16, 2010 | 01:48 PM
  #152
383_Stroker's Avatar
Originally Posted by wickedss2005
ever see the movie babe?
baa ram ewe
baa ram ewe
Old Feb 16, 2010 | 01:51 PM
  #153
Supercharged Guy's Avatar
babe...?, movie...? when 1950's
Old Feb 16, 2010 | 02:17 PM
  #154
1995
Old Feb 16, 2010 | 04:53 PM
  #155
Billig ss/sc's Avatar
^^It's pure win.
So anyway....
TVS... Is there an official dyno/quarter mile thread just for the TVS cars yet? I want to make one if not.
Old Feb 16, 2010 | 05:23 PM
  #156
06_SIC_SS's Avatar
Originally Posted by Billig ss/sc
^^It's pure win.
So anyway....
u should make one
my dyno sheets sittin next to me
Old Feb 16, 2010 | 05:25 PM
  #157
Coming right up good sir!!
Old Feb 16, 2010 | 05:27 PM
  #158
06_SIC_SS's Avatar
u decide to go tvs billig?
yes! unfortunaltly i dont have it uploaded anywhere so i cant post it up lol
Old Feb 16, 2010 | 05:30 PM
  #159
Perhaps
TVS Dyno and 1/4 thread....
https://www.cobaltss.net/forums/show...98#post4694198
Old Feb 16, 2010 | 05:39 PM
  #160
WickedSS2005's Avatar
well this sucks. i have no printouts.
Old Feb 16, 2010 | 05:42 PM
  #161
06_SIC_SS's Avatar
lol whatd u get urs up to tom? ur word is my printout
Old Feb 18, 2010 | 03:56 AM
  #162
EatonTVS07's Avatar
click
Old Feb 18, 2010 | 01:17 PM
  #163
Mid 300's
Old Feb 24, 2010 | 08:48 PM
  #164
jazzyjames1371's Avatar
has anyone had any problem with belt slipage on the tvs. vince is doin my tune and asked me if mine was. i guess my boost is fluxuating at high rpm's. any solutions? im still useing the stock belt.
Old Feb 24, 2010 | 08:51 PM
  #165
EatonTVS07's Avatar
Get a stage 2 belt.
Old Feb 24, 2010 | 08:56 PM
  #166
Originally Posted by Cobalttc05
Get a stage 2 belt.
will a stage 2 belt fit on the stock tvs pulley
Old Feb 24, 2010 | 08:57 PM
  #167
EatonTVS07's Avatar
Yessir.
Old Feb 24, 2010 | 09:06 PM
  #168
Tennpenn83's Avatar
the stage 2 belt will fit. it is really tight, but will fit. keep an eye on the other things in your engine bay, like your coolant. if you notice any leaking from anywhere, including the expansion tank, then pop off the valve cover and check the head bolts.
on my 2nd WOT pull with the TVS, i saw a lot of boost fluttering and it ended up being the 2 head bolts to the left of cylinder #1 had stretched, letting the head lift off the block. the bolts are tq-to-yield and are not suitable for the motor past 250whp. keep an eye on your coolant, and your oil, to see if it is mixing with coolant at all. and do a comp test
Old Feb 25, 2010 | 08:02 AM
  #169
selfinfliction's Avatar
or you could just add nitrous and let us know how that works out
Old Feb 25, 2010 | 03:12 PM
  #170
Tennpenn83's Avatar
um... i have since fixed the problem... but nitrous would be fun...
Old Mar 3, 2010 | 05:45 PM
  #171
krazycobalt's Avatar
bump very informative!
Old Mar 28, 2010 | 11:54 PM
  #172
CobaltSSilver's Avatar
Sub...at some point I need to do more research to figure out with this mod when I add it, what set-up will be most reliable...I'm looking for a set-up that will get me 100K out of the motor of course if the motor is healthy when the mod is added.
Old Mar 29, 2010 | 09:16 PM
  #173
Also, will it pass emissions and I presume one needs a little more oil for oil changes since the SC is bigger and needs more?
What was wrong? You still feel like the motor needs some upgrades to handle the TVS?
And another thing....LOL..... spark plugs....recomendations there...I am running one range colder now, will that work and do things change with the pulley swap just like on the M62 blower where dropping pulley upping boost means two range colder plugs ect...
Last edited by CobaltSSilver; Mar 29, 2010 at 09:16 PM. Reason: Automerged Doublepost
Old Mar 29, 2010 | 09:21 PM
  #174
Tennpenn83's Avatar
the TVS is sealed from Harrop just like the M62. they have their own oil, and per the manufacturer, they are good for the life of the unit.
emissions... you should be good if your tune is good. cat-less is another story
my own opinion is to at least upgrade the stock head bolts to head studs. other than that, you can push the stock pistons quite far. the rods are plenty strong, and the crank is forged from the factory. i don't feel any more upgrades are needed on my car unless i blow out a sleeve, but then again, that *should* not happen if your tune is good. knock is the enemy.
Old Mar 29, 2010 | 09:27 PM
  #175
Thank you, anybody have head studs out of the supporting vendors that I could buy? I will probably say screw it and go with 79 injectors with the 2.75 off the bat with the 3" intake. Sounds like the upgraded TB will not be as nice for the street. She is the daily driver and weekend track toy so she needs to stay reliable and streetable.
