Painting the upper dash
Old Mar 19, 2008 | 04:01 AM
cobalt_driver's Avatar
Originally Posted by smp4488
I just got done painting my pillars and im looking into painting the headliner and dash black. I want the dash to be a smooth gloss black. As you may know the dash is not smooth and in debating if i want to sand it or bondo it. It was a pain in the ass to sand the pillars and the dash is a much larger area. Am i wasting my time with the bondo or should i man up and just sand it all? I know im going to have to sand the bondo anyway, but it will be much easier than sanding hard plastic.
alright! first things first. sand it. its worth it. look at my gallery n look at my interior. i dont have pics up of my dash but its done. all sanded. go to walmart, and buy an electric sander, n use 80 grit, and take it down as much as u can, n then sand it with 220 and wet sand with 220 as well.
prime it with 3-5 coats, and wet sand before u paint. paint it 5-6 coats and wet sand every 2 coats, and clear coat it with like 7 coats. when wet sanding in between coats use 400-600 grit.
also, to take off ur dash, take the a-pillars off then remove the trim going across the glove box, radio, ect... now the very very very front is just clipped on. yank it off. theres a bunch of screws. unscrew them. same thing with under the trim. oh n be careful around the airbag. take a screw driver and pop most of the cover off. idk how to get this off, so i just left it. i hope that helps.
EDIT: lol, so i posted before i read the thread. u have the same problem as me. i guess we're both stumped. lol.
Old Jan 14, 2009 | 03:07 PM
PolishPauL's Avatar
Getting the airbag cover off is pretty much impossible unless you cut it and take it off in pieces.
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
riceburner
Sep 26, 2015 12:57 AM
