BuyHIDs.com BuyHIDs.com is a Supporting Vendor of CobaltSS.net
Contacts: mkulrey13
RETROFIT Install questions and support!
Old Sep 12, 2010 | 03:45 AM
  #101
dillw33d's Avatar
Looks great wicked!
dill recheck your connections and make sure the red and black wires are hooked up.
Ah, I thought those were only for the ccfl and I let those off. Still, I could hear a clicking but didn't see a change. Ill try that tomorrow.
Thanks!
By off I meant unconnected
Old Sep 12, 2010 | 05:54 AM
  #102
morelos704's Avatar
the two cables i circled where exactly do they go?
Old Sep 12, 2010 | 09:15 AM
  #103
mkulrey13's Avatar
Guys PLEASE read the instructions...BUY HID's Click DIY retrofits. Those need to be a switched power course.
Old Sep 12, 2010 | 09:41 AM
  #104
WickedSS2005's Avatar
How "Not waterproof" are they.... my hood is vented above the blower and water does get in the engine bay..
Old Sep 12, 2010 | 09:51 AM
  #105
mkulrey13's Avatar
Its electrical so really no water should get to them. Below is the install link and at the end it shows you where i mounted mine. They go nicely inside the frame infront of the engine above the rad fans.
http://www.buyhids.com/pdf/install_retrofits.pdf
Old Sep 12, 2010 | 01:41 PM
  #106
mkulrey13's Avatar
Also guys, I will update the guide but the 9007 connector on both harness need the wires swapped around. Blue/white wires need to be swapped on the blue 9007 connector on the retrofit harness's.
Old Sep 12, 2010 | 02:45 PM
  #107
dillw33d's Avatar
Also guys, I will update the guide but the 9007 connector on both harness need the wires swapped around. Blue/white or brown/blue. Without it in front of me i cannot be sure which wires. But one of the 2 combos need to be done. Just the way the factory makes the connectors. Not sure why
Would this be why I only have lows then? Everything is powered and grounded but nothing. I'm going to tinker more when I'm out of work in 5 hours
Old Sep 12, 2010 | 02:53 PM
  #108
mkulrey13's Avatar
Yes thats why there is no high beams.
Old Sep 12, 2010 | 04:14 PM
  #109
jacobpaschall's Avatar
I am also having problems with the high beams. Everything is hooked up and everything works except the switch between high and lows. The right light is stuck on high beam and will not go to low. The left light will switch between high and low, but will only switch to high beam once out of like 10 clicks on the high beam selector. When it does switch to high beam, it goes back to low beam after like 1 second on its own. There is only one way all of these wires and plugs go together, so I don't know how it could be wired wrong. Any suggestions? The car will not even be drivable at night with the right light stuck on high beam. The halos are spliced into the side marker light and are working correctly.
Old Sep 12, 2010 | 05:22 PM
  #110
mkulrey13's Avatar
..Please read what is above your post. In order for them to work correctly with 9007 cars the wires mentioned above need to be swapped around.
Old Sep 12, 2010 | 08:07 PM
  #111
skatin_boarding's Avatar
For the life of me I cant figure out or even see in your directions where those red and black wires go. Sorry but the mosquitoes are bad.
Old Sep 12, 2010 | 08:10 PM
  #112
mkulrey13's Avatar
Its clear as day
http://buyhids.com/pdf/install_retrofits.pdf
Once you build them you follow that how-to on installing them.
Old Sep 12, 2010 | 09:33 PM
  #113
Originally Posted by morelos704
can you post some close up shots of your lights?
More pics of my lights, here they are. Thanks Mike and Kidcrash (w/e you name is, never seen it posted)
https://www.cobaltss.net/forums/appe...7/#post5226211
Old Sep 12, 2010 | 11:55 PM
  #114
kidcrash603's Avatar
The name is Steve.
Glad to help!
Old Sep 12, 2010 | 11:57 PM
  #115
Hi Steve. Any relation to Scuba Steve?
Old Sep 12, 2010 | 11:58 PM
  #116
He's my cousin. He likes to tell people about taking baths...
Old Sep 13, 2010 | 12:32 AM
  #117
...thats why my dims are my brights and my brights are my dims...
Old Sep 13, 2010 | 12:42 AM
  #118
dillw33d's Avatar
Got them wired up and functional =D the blue and white thing was my only stumbling point. And somehow between aiming and putting my lenses on my cutoffs got messed up which is my fault. Great sell guys, thanks again!
Old Sep 13, 2010 | 10:48 AM
  #119
Everything is woking good with mine too. I have the same problem, cutoff is all jacked up, but it will work for now. I would recommend that people mount the headlights and adjust the cutoff before you re-seal the lights. If that step is in the instructions, I forgot to do it, but it would be worth the extra time. Thanks for the help and patience with us first timers.
Old Sep 13, 2010 | 10:51 AM
  #120
I spliced the hot wire into the small side marker light and grounded the black wire to the same spot as the other ground wire.
Old Sep 13, 2010 | 02:21 PM
  #121
dillw33d's Avatar
Yeah, the brown wire (should be) coming from the marker light (NOT the running lamp/turn signal unless you get the constant wire which I have no clue on) should connect into the + for the halo for whoever was confused
Old Sep 13, 2010 | 03:31 PM
  #122
mkulrey13's Avatar
Glad you guys enjoy them!, Im sure once the word is out, i will be able to do another GB but i think i sold it to everyone this time
Old Sep 14, 2010 | 10:33 PM
  #123
GOt mine all finished up. Only question now is, how would you guys go about getting the tint off the head light plastic? I had mine tinted lightly for when I had hids in the stockers before, now I dont want it. I just dont want to deal with messing up the clear plastic.
Old Sep 14, 2010 | 11:16 PM
  #124
RHZ's Avatar
RHZ
I've switched the white and blue wires on the blue connectors... Now my lights will actually switch from high to low.
Only problem is my lights are opposite... passenger is stuck on high beam during low beam and switches to low beam when i turn on my high beams....
Old Sep 14, 2010 | 11:37 PM
  #125
zerosk8ter83's Avatar
you have to switch the wires on the other connector as well
