For discussion of all things Powell!!
Old Jul 10, 2013 | 10:16 PM
  #501
Just hit them with a rust proofer every winter.
Just emailed john and gloria about getting the f35 stage 1 mount. I'll be removing the ottp mounts and replacing with stock in the rear and stage 1 in the front
Old Jul 11, 2013 | 10:12 PM
  #502
Pinky Demon's Avatar
the zinc plating on Powergrids is really a cad plating I think, and it stands up better than zinc on the powergrids. Salt screws everything thats why I no longer drive the RL in winter and I have replaced all the parts that did get salt covered the one winter i used it.
I now use 10.9 cad plated bolts in our sway bar hardware packages. I tried stainless, which resists corrosion very well, but the bolts are as weak as grade 5 and more brittle so stopped.
The wntrbtr2 a SAAB 9-5 is stellar for corrosion resistance. But I wash it a lot in winter, and I oil it underneath prior to winter. The rear muffler will probably succumb first to salt, but the main system is good quality stainless and stands up well. LNF downpipes stand up well to winter I have found...
That ain't cool. This thing is going to be a winter beater. No choice about it. Guess I'll go Moogs then.
Old Jul 11, 2013 | 10:19 PM
  #503
I'm glad i found out about the powergrids not being any good for winter before I picked up a pair.
Also OP you might want to update the price for F35 mounts, they've increased just ordered them yesterday and Gloria broke the news about the price increase, $175 plus shipping
Old Jul 12, 2013 | 07:02 AM
  #504
Powell Race Parts's Avatar
thats F23 Erik...you have a TC ?Gloria mixed up your order. The composite mounts (F23) took a big price increase due to cost of GM part. The all steel F35 are still the same. $110.00 I think you may have a Refund coming lol. Let me know via email...Glroia is travelling today....I also think its wrong to say powergrids dont stand up to salt, they do way better than stock but the cad plated rod does tarnish and lose its luster is all; cosmetic
Old Jul 12, 2013 | 07:23 AM
  #505
Yeah I have a TC, I'll email Gloria and cc you on it.
Old Jul 12, 2013 | 10:23 AM
  #506
Fixed
Old Jul 12, 2013 | 11:14 AM
  #507
Fixed
Thanks.
Awesome customer service.
Old Jul 12, 2013 | 12:38 PM
  #508
Shipped
Old Jul 17, 2013 | 04:04 PM
  #509
Also posted in the LNF valve gunk thread:
Current update July 17 2013 on PCV upgrades, and status of current hardcore and xXx rear sway bar orders. Tx.
There are issues with no vacuum while in boost for sure , understand that as far as GM are concerned the system is designed with the stock K04 to maintain vacuum levels even under boost in the neighborhood of -2 03 -3 kPa. which is .5 to .8 in hg.
Two things are clear to me. #1 the stock K04 with GMst1 or better on the race track is under boost so much, that there is no vacuum under boost. I have not measured this, but based on the oil backing up the oil drain return, its happening. Keep in mind that in a 2 minute lap at a typical road race track you are at least 1 minute 20 seconds under boost.. at least.
#2 with the way the aftermarket turbos are configured, thare is little chance of the pcv system pulling a vacuum under boost.
SO. Diesel engines dont typically have vacuum in the crank case, so oil drain lines from the seperator need a check valve. OUt folks tracking their cars with a K04 need a check valve. Folks with aftermarket whatever s256/ZFR/ et al need this as well.
I am working on it. The Fabi is away in Syracuse at a big hot rod meet, ,Ronnie my gear cutting machinist is due to go out on holiday, and I am having a hard time locating a mann hummel check valve ( MH recommend this for diesel oil return seperator systems)
Let me repeat to be very clear; there is sufficient blow by gasses in the crank case that oil will go back up the dipstick tube drain back vent hose, into the oil seperator.
This is where I am at; contact via email is best, and I am trying as hard as I can to get it all done as we find out more. Normal non track folks pretty much have no issues at all.
PS the powdercoaterr did a hatchet job on his finger with a hedge trimmer and his 2 i/c is on holiday this week so those folks waiting patiently ( or not) for sway bars my apologies, we are late with hardcore and triple X bars. Also the humidity is so high the moment you blast metal it rusts in about an hour just sitting. wow.
I expect Tuesday all the bar orders will be shipped and for the PCV upgrades, i should have the check valve system figured out next week ; again , email me if you are in that club- Sox fan is for sure....also Kevin J and his ZFR also.....
and they said this would be easy lol
Old Jul 17, 2013 | 10:37 PM
  #510
Got my mount today good looking part. I'll take a closer look at my pvc system when I install the mount next weekend on holiday out of state this weekend
Old Jul 18, 2013 | 04:50 PM
  #511
colodude18's Avatar
I'm in both clubs lol waiting for my sway bar and oil from the PCV oil separator all over my garage floor lol no worries John, I know you're working on it and will get it right!
Any chance you can send my TCABs? I told Gloria to include them with the bar but I've been waiting to install my YYZ's and Konis until the TCABs are here.... Thanks!
Old Jul 18, 2013 | 07:30 PM
  #512
email me your address i ship the tcabs at my expense not your fault that the pc guy should stay away from the garden- stitches and they glued his nail back on. lucky the finger is still attached.
i just got attacked by a black fly ugh that sucks big.. working with mann hummel on the check valves, you would think I was looking for the holy grail.
Old Jul 19, 2013 | 08:51 AM
  #513
C_A_D88's Avatar
Any word on the rear brembos John?
Old Jul 19, 2013 | 10:49 AM
  #514
colodude18's Avatar
Email sent. Thanks John!
Old Jul 19, 2013 | 12:01 PM
  #515
Wired's Avatar
I haven't installed my pcv system yet so I'm eager to hear about this upgrade. Can't wait.
Old Jul 19, 2013 | 01:16 PM
  #516
Have not seen it going to post office with it after lunch. Will check now shipped tracking sent
Old Jul 19, 2013 | 02:51 PM
  #517
padlock's Avatar
john you should start making miata parts so I can go broke on buying those from you too
Old Jul 19, 2013 | 03:10 PM
  #518
GreenySC2's Avatar
Originally Posted by c_a_d88
any word on the rear brembos john?
+1
Old Jul 19, 2013 | 03:24 PM
  #519
Its good, gonna pull my cold side this next weekend, i'll post up pics
Old Jul 19, 2013 | 07:54 PM
  #520
Originally Posted by GreenySC2
+1
i got the plan the parts sourced etc, but no time or money to invest, gotta get these pesky rear bars out and stuff like that. time to talk about the cost I suppose.
lol. email about the CED wish list, thanks
Last edited by Powell Race Parts; Jul 19, 2013 at 07:54 PM. Reason: Automerged Doublepost
Old Jul 20, 2013 | 02:26 AM
  #521
night_throne's Avatar
#1 on wish list
auto rotated mounts finally!
Old Jul 20, 2013 | 02:33 AM
  #522
andrewcarr1993's Avatar
I always thought there wasn't a point in rotated mounts for an auto since the axles are already in line. How much is it for F23 rotated mounts now? I want them badly but don't know if I really want to spend as much as they are when I've yet to install poly tranny mounts, which are still sitting in the box I got them in.
Old Jul 20, 2013 | 02:37 AM
  #523
there isnt a point to them untill u slam one to the ground same reason they make them for the f23 and such it raises the axles back closer to being straight again
Old Jul 20, 2013 | 02:42 AM
  #524
I'm only on YYZ springs (which I love) but I thought the main point was the performance improvements, mainly wheel hop.
Old Jul 20, 2013 | 03:23 AM
  #525
and axle bind for those of us how like to scalp the roads rolling low
