For discussion of all things Powell!!
Look what the post man dropped off today!
Creative packaging, or what?!!
Here's what's inside, along with my old (red) hardcore bar:
The XXX is visibly beefier than the hardcore:
And I really like the finish of the ends better than the old one:
As soon as it's installed, I'll post pics
Thanks Powell Race Shop!!!
Your welcome! Tyler (Hobbit) got his and it had broken at both ends out of the package, first time i have had that happen in for ever since Josh R ( florida) got his harness bar damaged in transit in 2009?. sucks. so glad you are happy...waiting to hear if Hobbits bar is okay
Well Powell I have to hand it too you, I'm happy you and Matt O talked me into buying the Hardcore bar at CED. Also want to thank you a ton for throwing it on for me! Car is a totally different animal when taking turns! Let me know when you get those check valves for the PCV setup and me and Matt are gonna route the lines a little different and get that other line off the K&N. it was great finally getting a chance to meet you!
Kyle
Kyle
Kyle
Kyle
happy you did that too. Its really nice to provide parts that make the car better and handle and put power done well and keeps everyone safe as well. Such a nice 4 inch intake you have, that gold pc is the nicest I have ever seen worth the big bux for the powder!!!
Yup. Bolt is in already. Made a bloody mess with the loctite just to make sure loctite were on the bolts lol. Gonna ret torque tomorrow around same time to allow 24 hours of settling in and curing .
Yea my post office prolly just tossed it around lol. The box ends were tore up but bar still looks good! Little scuff on one corner but its going under car and still gonna work great! Lol not to mention some sick sticker were inside
Sorry, quick questions for Mr. Powell: I'm getting conflicting information from both you and Gloria, stating that I can, and can not, use the rear LNF mount with your keyhole spacer for the F23 rotated mount. I have threads here, you telling me that I should do that, and Gloria just emailed me saying that I can't. On top of that, you PMed me and told me 150 for a set of mounts, just a couple days ago, and Gloria said they switched to $175 a while back. She also said I couldn't send in my composite mount as a core which you said I could in the same PM. I'm just trying to seek clarification here because I can't seem to get a straight answer from anybody and it's pissing me off. Thanks for your time
first of all your emails to her which I have now read confused me, so easy to see where the confusion came from. Reading your emails, at first you were asking for just a spacer to put under the rear mount. That wont work. you cant lift the rear and not drop the front to rotate the motor.
secondly, the issue of cores for the composite mount is a problem, as these mounts can break. So while it would be nice to offer a core as I talked of to you, Gloria and my machinist both agreed that I should not do that, as the risk for some unsuspecting purchaser to get a modified mount off a core that would fail prematurely is too high. I was over-ruled. It happens.
#3 GM increased the price of the composite mount, A lot. Takes too much work to make them to keep the price the same and yes, the price increase is recent.
4, the shape of this darn F23 mount makes it impossible to economically reproduce in steel or alloy. The block of alloy to make it would cost about 100 before machining .
and finally using an LNF rear mount is a very good idea you have; thats a much better mount for stability than the stock F23 or LSJ rear mounts, so you were right on with your thoughts. And no, you cant buy OEM parts from me cheaper than CED - CED is the source, his pricing is rock bottom and he is in the USA
sorry for the confusion, but think about it like this; you and gloria spent over an hour going back and forth on this, which took time that Gloria was not doing other things for customers, and in the end, you are not happy and
neither am I. sorry to say. Hope this helps.
And I didn't get any stickers...
I wouldn't say it improves rear end traction, it basically reduces the under steer characteristic of the car dramatically. In auto-X or on a race track, this means you can put the power down sooner coming out of turns and/or go into turns harder than you could without it.
The sway bar is most effective when you're driving on the limit of traction, which by definition you probably shouldn't be doing on the street ;-)
aww I had better send you some then, email gloria and I will put in extra for Pitbull for all his trouble with us cheers
