Drivetrain: How-To: Install B&M Shiftplus
Old Nov 13, 2007 | 11:23 PM
  #176
Hotwired2689's Avatar
is it easy to open the case? anyone wanna snap a close-up of the board inside
Old Nov 13, 2007 | 11:27 PM
  #177
HackAbuse's Avatar
No it's not easy, I tried but I didn't want to break mine.
It's very well built, I wouldn't be surprised if it was filled with epoxy or something for the express purpose of hampering reverse-engineering.
Old Nov 14, 2007 | 12:14 AM
  #178
ahh oh well..i'll have to take a look at mine...when i get it! but i will...and i will be sure to let you know
Old Nov 27, 2007 | 02:52 PM
  #179
bikeboyben14's Avatar
i installed mine today and i was hoping it would bark tires like my friends cavi but it didnt. however it does shift very firmly. still happy with it and maybe once i get more mods done it will wake it up even more
Old Nov 27, 2007 | 02:55 PM
  #180
Viper33884's Avatar
What Balt do you have?
Old Nov 27, 2007 | 03:20 PM
  #181
i actually a 2.2 base g5 but same car its bone stock besides the shift+ i watched those vids of your car and it barked tires with the stage 2 on and mine just kinda shifts hard and i dont hear or feel the tires tryin to give loose
Old Nov 27, 2007 | 05:25 PM
  #182
kkanowitz's Avatar
Actually, you're right. I took mine apart because I wanted to relocate the switch. It took me about 45 minutes to break down the casing because it is pretty much just covered in epoxy. The big casing where the switch is actually contains nothing but the switch soldered to three wires. It looks like the IC or resistor doing the actual modification is farther down the wire in the small plastic casing.
Old Nov 27, 2007 | 05:27 PM
  #183
HackAbuse's Avatar
Did you see any means of breaking down the epoxy?
Old Nov 27, 2007 | 05:45 PM
  #184
kkanowitz's Avatar
Yea I had to! It was a pain in the ass. I pretty much used wire cutters and shaved it down to nothing. It took almost an hour. Under the epoxy is nothing but the three-pole switch. I noticed on the other side of the second box that was actually plastic futher down the wire that the wire got smaller so I'm positive that all of the controlling is in that part.
Old Nov 27, 2007 | 06:08 PM
  #185
HackAbuse's Avatar
tear that **** up!
Old Nov 27, 2007 | 06:13 PM
  #186
Viper33884's Avatar
Well when I first put mine on I only had an intake and when I did the test that's all I had in the videos. But I will try and get a few more videos with all my other mods on....lately it hasn't because of the Ingalls but on a shitty road not flat damn they chirp.
Old Nov 27, 2007 | 08:21 PM
  #187
Sarbae's Avatar
Mine chirps on Stage 1 when I 1-2 shift taking a slow turn... makes me look like an idiot, but, hey,
Old Nov 28, 2007 | 02:44 PM
  #188
kkanowitz's Avatar
tear that **** up!
haha I only tore up the switch becuase I embedded it into my dash. I don't have a reason to destroy the second plastic box.
Old Nov 28, 2007 | 02:52 PM
  #189
HackAbuse's Avatar
Please?
Old Nov 28, 2007 | 03:48 PM
  #190
kkanowitz's Avatar
Please?
Isn't it like $40 on TTR? Just buy a new one to play with.
Old Dec 4, 2007 | 01:21 AM
  #191
Panici's Avatar
Question:
Which part of the ShiftPlus unit gets hot? The box with the switch in it, or the in-line unit? Would it be possible to heatsink this unit?
Old Dec 4, 2007 | 01:56 AM
  #192
HackAbuse's Avatar
Nothing gets hot?
Old Dec 4, 2007 | 03:34 AM
  #193
Sarbae's Avatar
I remember reading somewhere (I think in the instructions) that the control box (in-line) is supposed to get hot, but I kept an eye on it and didn't notice anything out of the ordinary... *shrug*
Old Dec 4, 2007 | 08:48 AM
  #194
HackAbuse's Avatar
It definitely isn't hahah, i dunno where you got that from
Old Dec 4, 2007 | 02:01 PM
  #195
HunterKiller89's Avatar
best i can come up with is it mentions how hot the transmission itself gets, and then would mention how the B&M lowers tranny temps
Old Dec 4, 2007 | 04:58 PM
  #196
Viper33884's Avatar
Correct this helps reduce the transmission temps because it shifts quicker lowering the clutch plates slipping inside the transmission.
Old Dec 8, 2007 | 11:19 PM
  #197
Sarbae's Avatar
Had this connected for over a month now, just noticed this...
Anyone else unable to remove the key after turning off the car at setting 2?
Old Dec 9, 2007 | 05:37 AM
  #198
lol...nope
i havent taken it off setting 2 since i got it
Old Dec 9, 2007 | 10:00 PM
  #199
Viper33884's Avatar
Uh....no, I usualy turn it on stage 2 long enough for it to kick in the turn it back off so not sure if I've even had it ok when the car turned off but could be wrong...there also could be a problem with your sensor/soliniod in the shifter itself, I had a problem with mine after only 6k miles on the SS and they replaced it for free and no problems since.
Old Dec 19, 2007 | 05:22 AM
  #200
Acer00789's Avatar
Props, that will most definetly make my install go 10 times faster. Ordered it yesterday and cant w8 for it to get here.
