Common Problems with cobalts (Everyone Please!)
The fact that it's just a porely designed car. I'm tired of my clutch problems. This latest clutch problem is going to cost me around 2000 CAD because GM won't own up to a faulty part.
For more info read this thread. My car has been at the dealer for almost two weeks for this. The part cost 160 CAD and the labour is the rest.
https://www.cobaltss.net/forums/problems-service-maintenance-69/gm-f%2A%2Aks-another-customer-again-105743/
The are blaming the after market clutch on this even though I showed them that this has also happened with cars that had the OEM clutch still in it.
Too many problems! LEMON?
I have a 2007 ss/sc, and ive had small problems almost since i got it! #1. Exhaust sounds like ****! It sounds rough and weak, and the car sounds like it has a hissing noise! #2 Nasty grinding noise from engine area! #3 E brake is loose #4 Only getting 5 pnds of boost in 1st ! #5 Had boost guage replaced twice! #6 Weird noise from exhaust when starting car(sometimes)! #7 I had gas pressure cap problems! #8 Water(moisture) around heat vents! I love the car so much, but it sucks having all these problems! Also Dealership infringed on the lease, so i want into a new car!
Shutting off, bad idle, sunroof rails broke twice, bcm went out twice, radiator blew up once, driver side door quit working,many rattles... others I cant remeber.
'My car was in the shop 18 different times in the 2 years I owned it.
Chevy Cobalt Sport 08 @ 1,430 mi can't say I have any problems except if I shift too fast to the next gear, I get this crunch like sound. if I do it slower like almost putting it into n first then the next gear (except doing it all in 1 fluid smooth motion) it won't do that. which I think your supposed to do that anyway? the only other thing is since I put in a LED 3rd tail light, my cruise control stopped working. =/ I don't have any sun roof or sun roof button issues like everyone else has though.
Starting with most recent and the rest are in random order:
I've had two sunroofs in 14,600 miles...first one broke and the second one leaked which caused me to replace the headliner
intermediate shaft problems...first time I lubed it and well, now I'm going to replace it when I feel like it
brake rotors grooved and rusted
shifter cover fell off
clutch switch squeaked....super lube
door handles stick...super lube to the rescue
door switch bezels have paint coming off
paint is coming off at the bottom of both doors
misaligned hood which bent the corner...had to be straightened and repainted
clutch slip at times
engine rattles...still haven't bothered figuring that one out since I don't care anymore
passenger door was out of adjustment....had to bend in the top corner to sit flush
replaced both top door weatherstrips from tear
rear seat squeaks
rear deck rattles
steering wheel is off and the car drifts even after multiple alignment checks...brakes aren't sticking either
windshield started randomly cracking from the bottom with no evidence of impact
driver's axle seal MIGHT be leaking...I sprayed it off and will check later
axles started clicking shortly after buying the car....lubed splines and retightened axle nuts
Pirellis are JUNK and flatspot real bad
exhaust heat shield rattled
PCM and coolant reservoir rattled
sometimes it won't go into reverse
front bumper was wavy on the passenger side...I fixed that
rear bumper sticks out more on one side
I think that's all the problems I've had with it so far. Being that I work on the SOB it's getting old.
I'm scared to think of what else could go wrong with it since that's not all the common problems. "exploding" heater core, clutch going out early, bad crankshaft position sensor, flexpipe cracking, wheel hop damage from winter driving, master cylinder mounting plate eek, etc.
rear seat squeaks
rear deck rattles
didn't feel like reading through all pages, but my problem, been back 3 times is door rub
here is the link to the thread on that i started earlier
https://www.cobaltss.net/forums/problems-service-maintenance-69/door-wearing-paint-69880/
cds get stuck in stereo, rear seat squeaks (self fix), interior paint comes off really easy, brake pads throw alot of dust, that little plastic flap under the front bumper scrapes everywhere, the stopper on the seat belt fell off (which is REALLY inconvinient), but besides that everything else is ok... that and i go through oil faily quickly but thats my fault heh
I HAVE A LIST LOL
-CHIPPING INTERIOR PAINT
-JUST TODAY (4-18-08) PITTING RIMS
-PASS SEAT STITCHING
-CAR CREAKS AND MOANS
-SLOW
-EXTERIOR CLEAR COAT SUCKS
-STOCK SHIFT KNOB FELL APART
-STOCK CARPET FALING APART
-SUNROOF BUTTON COCKED TO THE SIDE (HAPPENEDWEEKAFTERBOUGHTCAROFFSHOWROOMFLOOR)
-POORLY ALIGNED BODY PANELS
ETC I DONT EVEN KNOW HOW LONG I COULD GO ON AND ITS A 06 2 1/2 YEARS OLD AND ONLY 11k ON IT WTF!
-SLOW
2007 Cobalt SS/SC
Bought September 22, 2006
current mileage: 39,324 miles
day after I picked it up, the clutch linkage in the firewall popped free. Improperly installed from the factory. Not even ten minutes to fix. Been fine ever since.
January- broke a sway bar link (more attributed to local roads than build quality of car). Replaced under warranty.
Problems? None. Brakes are still excellent, stop the car well. No warpage on rotors. One niggling annoyance with the sunroof... the sunshade all the way back has a tendency to rattle. Since i usually have the radio up very loud, i rarely hear it anyway (i have hearing loss from where I work... )
Other than that, i love this car!
Get your ignition switch checked. also, i read that the supercharged cobalt ss doesn't govern, because it comes equipped with z-rated tires... i could be wrong about that
i had the problem of my car shutting off while driveing, but i was only doing about 40. turns out the alternater quit chargeing the battery and it ran out of power. electronic ignition doesnt work with no power. then chevy fixed the problem but thats the only time it happend to me.
Originally Posted by D4
Tbanks for all the replies with the "Stock vs. Modded" thread! Here's a new one!
So what seems to be the most common problems with cobalts? Not a one time thing, but what do you guys hear about most often. This is for Truedelta, which is a new-ish site that is provideing detailed reliability reports. It goes way above and beyond something like the magazines and publications that are out, as the results are from real users that report on what really happens with their car.
For those that are not members of the survey panel of truedelta, if you can post with the problem, year and model of car, and what the cost was to fix (if not covered under warranty) i will update the info.
Thanks guys!
Thanks guys!
A few more:
5th gear is beginning to grind/clash
driver's side axle seal weeping more than usual
3 of 4 wheels have bubbled paint
glovebox rattles
rotors are **** again after sitting a few days in rain
*sigh*
glovebox rattles
*sigh*
I read the WHOLE thing...just seems like everyone is having so MANY problems...I think some of these problems are driver related...and I said some...so again no need jump down my throat...because you know I would hate to have an opinion that didn't agree with everyone else's...
