Taking the Turbobalt to the dyno.
no you are exactly right, this toolbag doesn't even know his own car. LOL. The car is going to make the same power no matter where it is cause the gay ass ecu. So his 14.0@101 run is probably exactly what he'll run in NY depending on his launch there.
I dont even know why im still on this forum, Im only still here for the Non fucktard SS owners that are interested in proof and not some kids living in mommys basement
Took the car to Bandamiere in CO today
' For the people who are retarded and do not know what DA or Altitude is do not respond to this post '
80+ Degrees & Humid
8,256 DA
Basically the highest 1/4 mile in the nation.
14.0 @ 101 ' rolling off line/no launch control
You figure out the correction
13.1 - 13.3 is what it will be in NY
Everytime in in CO & Then NY its always around 1 sec diff / my TBSS did 1.1 diff as it was 65 in NY when i ran
I will also post a 1/4 run @ NYIRP when im out there end of July
http://www.youtube.com/v/gjaPYMo9DKg
will post timeslip later for the other fucktards. that are gonna ask for it.
80+ Degrees & Humid
8,256 DA
13.1 - 13.3 is what it will be in NYEverytime in in CO & Then NY its always around 1 sec diff / my TBSS did 1.1 diff as it was 65 in NY when i ran
/thread
hahah, this guy hasn't proven a damn thing and he doesn't even know about his own car. haha, what douche. Dyno was FAKE, track numbers show those of a good driver in a stockish tc, not bone stock though, remember he has a filter and muffler delete. lol. 275whp and 300wtq my ass though, I trap 103 on street tires with only 222whp and 201wtq. I trap 100 on slicks. what a ******* liar. GTFO these forums loser.
You guys are too funny. Why doesn't someone do the mather here and try to figure out how much HP it takes one to run a 14.0 @ 101 at 8,200' elevation? I can tell you this, the stock 260HP isn't getting you anywhere close. You are looking at closer to 15s.
Since cobaltss.net is so smart and says the ECU limits and maintains power @ 260. Please tell me how it does this. I have some engineering experience and reading that posted link tole me NOTHING about how the ECU even measures TQ let alone keeps it @ 260 regardless of conditions or mods. I challege you to enlighten me.
@ What elevation?
@ What elevation?
@ What elevation?
@ What elevation?
260 hp is closer to 15's? so explain to me how all the ss/sc's with 200-225 hp stock are running mid to low 14's explain how a stock 2.4 with 160 whp ran a 14.9, and most of all explain how ralliartist with 222whp ran a ******* 13.5 explain why you can get the grasp around the fact that elevation doesn't matter with this car..
seriously just gtfo..... from the words of GM / chevy themselves at the GM owners meet in e-town... when trying to boast about the new ss/tc they said that no matter altitude the car would always push enough power to get 260 hp... so that way you dont feel your losing something buying it in canada.. god you're ******* dense..
pwned! and why does it take more power to run 14's at higher elevation? It doesn't *******.
At higher altitudes you LOSE power because of the thinner air. So MOST cars have to retune. But the SS/TC's ECU automatically adjusts for 260, so no matter the altitude, it will make that much power, which explains this guys 14.0@101. Now an SS/SC would definitely run 15's stock cause the thinner air would kill the power output down into the 160-170whp range and the car is hard to launch as it is.
I do know. I want to know if YOU or anyone on here does and can tellme how it does so.
I understand that a given car would make more power after being retuned at sea level than at 8000ft. But the ss/tc always produces 260.
I can't tell you how, cause I didn't design the damn car and I think that it's bullshit that it does that anyway. one of the two reasons I don't like the LNF, the other reason is DI.
Last edited by ralliartist; Jun 28, 2008 at 10:00 AM. Reason: Automerged Doublepost
omg you fail at life.. seriously GTFO...
What are they?
same way the tq managemend works in any other gm car pretty much, calculated engine load, tq load etc. don't know the exacts, but it does use the wastegate and pulling timing to reduce power output when these parameters are exceeded. Hence why a car in NY would probably be running @15-16psi at a basically sea level elevation, where as a car at a higher elevation will run @20psi to make the same power.
data streams:
air data (MAF/IAT)
fuel data (injection qty & timing)
MAP
RPM
Coolant Temp
O2 sensor
don't think any more are needed to get an accurate estimate, might be able to cut a few out, lose some accuracy, but wouldn't tax the ECM as much
air data (MAF/IAT)
MAP
RPM
Coolant Temp
O2 sensor
This is too funny because all you fools still fail to realize what I am even getting at here. One person had it here and noone even noticed. That's the problem with this board, all of you (OK most) are too busy bashing and name slinging and can't even realize what's going on. That is why you suck. Because you are too petty and ignorant and uneducated to even try to learn something and attack skeptism with thoughtfull analysis. doesn't it make you feel soo much better to hate on someone. Doesn't it give your insignificant lives more meaning if you are better or your car is better than someon elses? yeah it feels good doesn't it guys. the biggest obsticle to your knowledge groth are your hard heads. You all should try to grow up someday.
No one knows the answer, this thread is full of idiots. The guy is lying but no one is willing to take him up on his offer besides paul that has 400 horsepower and even if he did make those numbers on the dyno he would still loose to anyways.
Engine torque models have been around for over a decade, if you really want to see how long do a patent search. There are a gross multitude of methods for estimating torque and for controlling torque. If you don't believe me google.com/patents will provide you with all the evidence needed. This engine uses torque management and is seen in accurate dyno graphs.
Please shut the **** up now Mr. Troll.
Sincerely,
Krispy
further proof the LNF is torque limited
Torque is a flat line in a steady state dyno test, limited at 260.
