Official Turbo LSJ thread!!!
Old Aug 30, 2012 | 07:59 PM
  #2776
zrated89's Avatar
dude i didnt smoke but i was only down 100psi in num four. other 3 were 220. But your comp on all the others is low as well
Old Aug 30, 2012 | 08:00 PM
  #2777
BLAZIN07SS's Avatar
I'm too JDM for you
My clutch is finally starting to give me issues. Still not slipping though, just lots of engagement height change when I beat on it. Gmpp ftw!
Old Aug 30, 2012 | 08:05 PM
  #2778
zrated89's Avatar
^^^ lol me too i went to power shift at 8k and clutch was like wtf u doing ngga not happening lolz
Old Aug 30, 2012 | 08:11 PM
  #2779
c130aviator's Avatar
I just did a leak down test on #2 at TDC and heard air flowing into my intake. (that would explain the wired problems with my TBS error) 130 psi on a new engine with rings was good.
I have friend who is a toyota tech that is an ASE certified mechanic, told me he just did this on his sisters car and it was burnt valves, the cyl were at 130 psi when new.
I wont know until I know. I have to move in a month and unless I can get some serious help I am going to wait until after I move so I have more time and a new home/garage to work in. My rental here sucks for garage space and driveway.
Old Aug 30, 2012 | 08:17 PM
  #2780
zrated89's Avatar
dude i dont care what ur friend says, im also a master certified tech and 130 for these motors is low. I had 120 in my number four with a busted ringland
Old Aug 30, 2012 | 08:18 PM
  #2781
klutch814's Avatar
yea that is low man
Old Aug 30, 2012 | 08:31 PM
  #2782
ok ok lol. Thinking about the saab motor swap or built...
Old Aug 30, 2012 | 08:35 PM
  #2783
zrated89's Avatar
i rebuilt mine in the driveway with no air tools. Forged pistons, total seal rings, new rod bearings and rod bolts, a light hone and call it a day. i did some more stuff but thats all you would need
Old Aug 30, 2012 | 08:56 PM
  #2784
Originally Posted by ItalianJoe1
Doubtful, pull the head and check. Most LSJ bottom ends are the first thing to go, so i'd bet on that first.
Plan on pistons at minimum, hope there isn't much more damage than that. And be ready to tune properly when you put it back together, or leave it on lower boost.
welp, sounds like a challenge, I think I may take it on. Do you have contacts for the parts? maybe a receipt laying around. what about the head? I think its burnt.
Old Aug 30, 2012 | 09:03 PM
  #2785
zrated89's Avatar
probably not burnt, just have it checked and replace the valve seals with the viton seals from zzp. Only 20$ for the set. The guides on these have been known to give a few people issues, but mine were fine. Other than that, lap the valves when u re install everything for a good seat. I got my diamond forged pistons for about 500$ Total seal rings for 140$. I recommend the arp head studs, they are only a little more than stock new ones and are reusable. The other misc stuff u will get, head gasket, rod bearings and rod bolts arent that exp. I did my build including full cams, valve springs and retainers, new valve seals, port and polish job, neutral balance shafts, arp head studs and extras including my fuel system stuff all for under 2500$
( since i work at a dealer though i did get everything cheaper) right down to the gm special rtv
Old Aug 30, 2012 | 09:05 PM
  #2786
klutch814's Avatar
did you build yours while in the car?
Old Aug 30, 2012 | 09:07 PM
  #2787
that was my next question, I do have access to a lift and dropping the cradle may be a lot easier!
Old Aug 30, 2012 | 09:08 PM
  #2788
zrated89's Avatar
yup and even honed my block with it still in the car. Took me about 2 hours to have the pistons out on tear down, and about 4 to put everything back together and torquing to spec. the hardest part was doing the neutral shafts with the motor still in the car because u have to lower the cradle to pull them out and clear the frame
imo its quicker to do it in the car, esp just a piston swap.
Old Aug 30, 2012 | 09:10 PM
  #2789
klutch814's Avatar
so it is possiable to swap nutrual balance shaftes while in the car?! another part added to the list lol. that was my main concern. that is if the lsj balence shafts are the same as the 2.2
Old Aug 30, 2012 | 09:44 PM
  #2790
zrated89's Avatar
im sure they are its possible just have to loosen the cradle let it hang, and some pry bar persuasion
Old Aug 30, 2012 | 09:51 PM
  #2791
klutch814's Avatar
interesting. i will def look into that now.
Old Aug 30, 2012 | 11:27 PM
  #2792
BLAZIN07SS's Avatar
I'm too JDM for you
Just spun third on the way home. Gmpp is good to go and the peda went back to normal
Old Aug 30, 2012 | 11:29 PM
  #2793
nice, I have a spec 2+ NIB, I may actually get a chance to install it now. LOL
Old Aug 30, 2012 | 11:46 PM
  #2794
Axelthered05's Avatar
What are the pros and cons comparatively between the Turbo Tech Racing intake manifold and the Saab intake manifold
Old Aug 31, 2012 | 12:37 AM
  #2795
Wait for future reference I burned up cylinders 1 and 2, 3 and 4 were the ones without ruined plugs and still had compression...
Old Aug 31, 2012 | 09:50 AM
  #2796
SCcobaltSS's Avatar
Hope you didnt scar the sleeve too bad. When a guy here put a hole in the side of the piston it scared the sleeve so bad it needed to be replaced. Total motor disassemble.
Old Aug 31, 2012 | 10:57 AM
  #2797
zrated89's Avatar
Do a brake fluid flush.
Old Aug 31, 2012 | 11:16 AM
  #2798
BLAZIN07SS's Avatar
I'm too JDM for you
i did about 6000 miles ago, full fluid flush and new clutch master
Old Aug 31, 2012 | 11:19 AM
  #2799
startingline05's Avatar
i had that clutch in my turbo lsj with the s252et and a few months on the s256et. it barely lasted a year and i really dont beat on my car that much.
Old Aug 31, 2012 | 11:26 AM
  #2800
That setup you have there is more than my 350hp hahn turbo kit... It may do alright at this power level. Also at this point anything lasting a year sounds like decades to me. I got 2 weeks into my turbo swap and broke something...
