Official Turbo LSJ thread!!!
Old Feb 23, 2012 | 10:49 PM
  #1526
USMCFieldMP's Avatar
Rattlesnake Race Shop
Good set-up. If I wasn't running the LNF block, I would have bought it back, just swapped the turbo.
Old Feb 23, 2012 | 10:54 PM
  #1527
mexi_loco's Avatar
he'll sell it to you for the right price. Or cheaper if you have a part he wants. And since when have you been on an lnf block?
Old Feb 24, 2012 | 02:00 AM
  #1528
BlkWdoSS's Avatar
Since he popped the last one...
Is your car in Texarkana now Robert? What design manifold/DP did you with this time?
Now... Internal vs. External WG... IDK what any of you are saying when you say that they sketchy above 24psi... There are diesel trucks out there that push 50+psi on an internal wastegate without problem. Internal is actually considered safer than external simply because its the only way to release pressure correctly. READ MAXIMUM BOOST by Corky Bell. Learn how to design a turbo kit and learn how all of this stuff works. An External wastegate has to be setup a precise way or it is doomed to fail.
If you want to build a kit for 2500-3000, it can be done fairly easily as USMCFIELDMP has stated. A good turbo can be sourced used or with the right research new for fairly cheap compared to the larger name resellers. If you are having a welder fab your intake and exhaust manifold, IC piping, and DP, you cut out all the large costs of your build. Dejon makes intercoolers but so does 1000 other places. Find what fits your car best. There are calculations you can do to determine the CID of the intercooler that you will need for your HP and then buy slightly larger for growing room. Dont plan on 15 for this 22 for that. Unless you are limited by fueling, run the max that you want because that will make it the most fun.
What I havent seen even mentioned as of yet is setting up your fuel system. You will need at minimum injectors and fuel pump rewire. I suggest return style for sure. It increases the cost but helps with fueling and tuning. Which brings to another aspect of your build, Dont total up all of your parts to $3k and go ok it was in budget because you have completely missed THE MOST IMPORTANT PART OF THE BUILD and thats the TUNING. It can be costly so budget out that part as well.
I custom built my kit, it was EXPENSIVE. I went very much over the top, You dont seem to be headed in that route and if you need assistance with details, small parts you will need so that you dont get an absolute headache while trying to do install, other info, plz pm me.
l8r,
PD
Old Feb 24, 2012 | 03:57 AM
  #1529
For the right price. I don't need it for one, and two... I'm on an LNF block. Much easier to use the LNF oil drain.
Yeah, it has been since June. I'm just now ordering all the parts though and starting into it. Build thread is on GMSC.
ZZP manifold this time around. It'll be a simple set-up this time around. Probably only make around 500whp on 30psi.
Old Feb 24, 2012 | 04:19 AM
  #1530
ULWizSS's Avatar
Well its time for me to run my setup for the first time tomorrow if weather permits.
For anyone that does not know this is my current setup.
06 SS/SC G85 LSD Turbo Swapped
BorgWarner EFR 6758 Turbo
BYT HP Tuned
BYT 304SS Tubular Manifold w/ Merge Collector
BYT 304SS Catless Down Pipe
BYT 3' CAI
BYT "Stealth" Charge Pipes
TTR Intake Manifold
TTR Upper Engine Mount
TTR Rear Sway Bar
ZZP Front/Rear Transmission Mounts
ZZP Front Strut Bar
ZZP Stage 2 Race Trans 4.45 Final Drive
ZZP Stage 3 Axles
ZZP Stage 2 Port and Polished Head, ZZP Stage 2 Race Cams. (Not Installed)
ZZP Triple Gauge Pod
ZZP Boost Reference Fuel Pressure System Option 2
Mototron 80# Injectors
Hallman Pro RX Manual Boost Controller
Eibach Front Sway Bar
Exedy Stage 3 Hypersingle Clutch
DevilsOwn Progressive Meth Kit (Installed but not running this time)
N2MB Wotbox NLS/2Step (Need a new Clutch Pedal sensor)
AEM Uego/Boost/EGT
Aeromotive Fuel Pump (Not Installed).
Aeroforce Intercepter Scan Gauge
Modern Performance MPx Steering Column Gauge Pod
Hurst STS
HP Tuners Software
15's Verde Protocols Rims
15's M & H Slicks (Track)
Wondering what this thing will run. 24psi no meth on the EFR 6758
Old Feb 24, 2012 | 04:27 AM
  #1531
TTR Rear Sway Bar
Gross. Get rid of those. Stock mount, Powell bar. You've got a great list of parts, minus those two.
Why you go with the Hallman Pro RX, instead of just the regular Pro? IIRC, the RX only allows like 5psi of adjustment.
Old Feb 24, 2012 | 04:30 AM
  #1532
EXsoccer1921's Avatar
oh that post reminds me. i replied to your post on zzp's wall ulwiz.
Old Feb 24, 2012 | 04:45 AM
  #1533
ULWizSS's Avatar
Hallman is just a name i trust. If comes with two springs. On the smaller spring i got 12psi cranked all the way up. Added the heavy spring and turned it all the way down and it was sitting at 20. Currently at 24 with lots of room to grow. Believe the heavy spring can do 30psi. Either way i got this one cause i wanted the ability to add the inside extension to control boost from the inside.
Just noticed that, sent you a friend request.
Old Feb 24, 2012 | 04:47 AM
  #1534
ULWizSS's Avatar
Thoughts on what this thing will squeeze out, keep in mind i am no slouch at the track and make roughly 60 passes a year if not more. Also been 1/4 racing for 15 years already
  #1535
pay no attention the profile picture
Old Feb 24, 2012 | 04:53 AM
  #1536
tell me about it. this was just half of the '08 season and half of '09
Old Feb 24, 2012 | 05:02 AM
  #1537
Really depends on how aggressively you're tuned and how much power she's putting down.
Should be good for 11's @ 12x, without a doubt though.
I run a Hallman, as well. I was just wondering why you went with the RX instead of just the Pro. I forgot they came with the extra spring and ball so you can add higher amounts of boost, as well.
Old Feb 24, 2012 | 05:07 AM
  #1538
if i can pull 112 on 91octane and 14psi. you should be able to hit 120 traps easily. will you be running the slicks for sure?? idk how they'll like being cold. but with the car 11s are possible. 10s will depend on power with the manual.
Old Feb 24, 2012 | 01:04 PM
  #1539
ULWizSS's Avatar
I will be on slicks.
Old Feb 24, 2012 | 02:12 PM
  #1540
zrated89's Avatar
slower than me :P just kidding lars. Im going to say low 12's 120mph traps maybe an 11. Definately an 11 once on meth with more timing
Old Feb 25, 2012 | 05:50 AM
  #1541
ULWizSS's Avatar
Well i got rained out yesterday so hoping to make a run on Sunday.
Old Feb 27, 2012 | 02:07 AM
  #1542
BlkWdoSS's Avatar
Went to a dyno day today, temps were good so bumped the timing up a few degrees.
Made 438whp woot woot, getting close to the 450 mark.
l8r,
PD
Old Feb 27, 2012 | 03:22 PM
  #1543
ChargedUp's Avatar
Sweeeeeet^^^
Old Feb 27, 2012 | 04:33 PM
  #1544
jonathan923's Avatar
guys help me sell it
https://www.cobaltss.net/forums/part...-5-kit-272458/
Old Feb 27, 2012 | 05:18 PM
  #1545
slickss24's Avatar
what plugs and gaps u guys running on 20 to 25psi?
Old Feb 27, 2012 | 05:20 PM
  #1546
mexi_loco's Avatar
i posted your thread in my local forum jonathan!
Old Feb 27, 2012 | 05:26 PM
  #1547
i'm gapped at .028
Old Feb 27, 2012 | 05:35 PM
  #1548
ChargedUp's Avatar
i just text u ExSoccer...im raul haha
  #1549
startingline05's Avatar
.022 here
Old Feb 27, 2012 | 05:37 PM
  #1550
ChargedUp's Avatar
and i guess ill post the ? here as well.
i had a couple cels that all seem to have been fixed.
my only one left is p1183 supercharger inlet pressure circuit low voltage or something like that.
i was just wondering if that was because of the fact that the zzp kit doesnt use that sensor? does it just need to be turned off with HPT or what?
thanks guys. just trying to get the car ready for when it gets dyno tuned.
