Official Turbo LSJ thread!!!
Old Jun 25, 2013 | 08:26 AM
  #5801
574's Avatar
574
So where do I tap into the block for my oil feed line?
Old Jun 25, 2013 | 09:05 AM
  #5802
nwss's Avatar
There is three ports on the back side under the head(Allen key heads) and you take one of those out and thread your feed line. I used the one closest to cyl one
Look in the front under the intake mani and it's the same on the back
Old Jun 25, 2013 | 09:28 AM
  #5803
nwss's Avatar
Ok so I have a problem and I've came up with my high flow cat being poop.
Cold starts the idle jumps up to 1500ish and down to 700ish and such
Have to rev more than usual in 1st
Interceptor reads misfires like crazy(bkr7e gapped .030)
Driving around it likes to be at 190+ (60 outside)
On pulls it will hit 200 or more
And still beats 400whp evo's cars running like so haha
My guess is when I blew my motor all that coolant and such fucked up the highflow. I'm taking it out regardless just wondering if anyone else thinks my assumption is right.
Old Jun 25, 2013 | 05:37 PM
  #5804
BLAZIN07SS's Avatar
I'm too JDM for you
boost higher then normal? odd smell? how many miles do the plugs have on them?
Old Jun 25, 2013 | 08:04 PM
  #5805
c130aviator's Avatar
I think I am getting somewhere with this 20g... Not a hint of knock on any of these dyno runs.
Old Jun 25, 2013 | 08:15 PM
  #5806
anyone willing to take the 20g a little more serious? I would have been happy with 20 extra hp. Go figure 50 horsepower with just a BRFPS...
Old Jun 25, 2013 | 09:34 PM
  #5807
dktgarlick's Avatar
So what should my afr be when at idle, cruising around, and full throttle. Right now my idle jumps from 14.8-16+ sometimes. Cruise I'm about the same and full throttle I'm around 10.8 or 11.8 can't remember
Old Jun 25, 2013 | 09:41 PM
  #5808
I am 14.1-14.9 at idle/cruise and 12.1 WOT. If you have HPT your trims should be + or - 3-5 percent depending on how much you want to put into getting the error out of the tune.
Old Jun 25, 2013 | 09:44 PM
  #5809
noorj's Avatar
props man that's sweet! how did you make more power with the brfps, were you running out of fuel previously? Also how much boost was the 472 on?
Old Jun 25, 2013 | 10:02 PM
  #5810
Thanks man, I was so nervous getting back on the dyno. I have been so afraid to blow another motor. This time I have no doubt I built my motor from the crank up, the right way. I was running out of fuel, which is still the case from 5500-7000. I need a bigger fuel pump. The injectors were around 60 percent at WOT. Boost at the 472 mark was 26psi peak/ 24psi nominal. I am using a turboxs High Performance Boost Controller. You can get rid of the peak with a second valve on the MBC. I am on E85 and those were 13 AFR's. Although I didnt have any knock I didnt leave it there. 13 is not the safest AFR. Got it down to a safer level by turning my boost controller back about a quarter turn and left it alone.
Old Jun 25, 2013 | 10:28 PM
  #5811
terry11's Avatar
i NEED e85
Old Jun 25, 2013 | 10:32 PM
  #5812
dktgarlick's Avatar
Thanks c130aviator. So that means my tune is off?
Old Jun 25, 2013 | 10:33 PM
  #5813
nwss's Avatar
Been like this since the rebuild lol, So the boost is adjusted to how it was on the first start up lol. Plugs don't have to many miles on them. And I don't think the highflow would stink it's just a metal honey Comb. Car is pretty damn quiet tho
Old Jun 25, 2013 | 10:38 PM
  #5814
yeah man, if you can, invest in HPtuners.
Old Jun 25, 2013 | 10:47 PM
  #5815
nwss's Avatar
Oh and dat tick is going on, sure hope it's just loose manifold bolts.
Old Jun 25, 2013 | 11:33 PM
  #5816
EXsoccer1921's Avatar
i'd be interested to see how it does on the track. or another dyno lol
Old Jun 25, 2013 | 11:39 PM
  #5817
i would too, but before the hate starts, this is the same guy that tuned me at 420whp 4-5 months ago. I pay them not for unmbers but for a tune. The funny thing was that with just 2 turns on the boost controller we went from 18 to over 25 on the big run. Scared the crap out of me and I will admit that I am not running that AFR or power. With it being 100 degree today, I am sure there was correction in there. Its a dynomite dyno, go look into them, they are considered one of the more accurate chassis dyno's.
Old Jun 25, 2013 | 11:46 PM
  #5818
most mbc's 1 turn is about 3psi give or take.
Old Jun 25, 2013 | 11:53 PM
  #5819
Yeah, at first turn I moved it, nothing happened. we were trying to get the spike out with the spike adjustment on the Turboxs HPBC. Got it pretty flat, then upped the boost and didnt realize it was going to make that kind of power. It didnt knock at all even at 13 AFR's. We backed it down and I am running proabably closer to 440. That is still 40 whp more than I went in there daily driving with (400whp before todays tune).
Old Jun 25, 2013 | 11:58 PM
  #5820
Also I just thought that every time there is a dyno comparison thread every one states they are only good for comparing numbers to previous runs, the numbers arent important but the data that you get from them is. Well in my case this is my second set of runs in 4 months. I definitely found some more horsepower whether its corrected or not. It was on the same dynomite std correction setting.
I wont really know until I see what mph I trap in the quarter, my 60ft times are going to suck, though.
Old Jun 26, 2013 | 12:00 AM
  #5821
for anyone wondering, that was on stock lsj connecting rods and I pulled around the 460's probably a dozen or so times. no knock in any of the runs.
Old Jun 26, 2013 | 12:05 AM
  #5822
nwss's Avatar
Out of no where this happened today. No noise Til I rev it up then she gets a knocking. Put a broom stick to the valve cover and the noise is coming from above cyl 3. Has a rough time idling at times. And of course i Floored it, seems to run fine lol
Old Jun 26, 2013 | 12:26 AM
  #5823
Old Jun 26, 2013 | 07:46 AM
  #5824
Tjolley's Avatar
The stock lsj rods r good to 600 hp
Old Jun 26, 2013 | 08:28 AM
  #5825
armcclure's Avatar
But probably not 9k....
Horsepower doesn't break rods usually, it just weakens them. Rpms it what breaks them. How often do you see a rod smashed? Hardly ever. They almost always get pulled apart.
