Official Turbo LSJ thread!!!
Old Jul 30, 2014 | 08:36 AM
  #8251
bmxracerchamp12's Avatar
Originally Posted by richienolan
Hey guys I'm working on putting my Turbo kit together and I just have a few questions first external wastgate v band or 2 bolt flange what's the best way to go and why and second whats the pros and cons of going 38mm or 44mm. Thanks richie
v band and 38mm
Old Jul 30, 2014 | 08:43 AM
  #8252
richienolan's Avatar
OK thank you, could u give me a quick price and con And y its best to go that route, I'm just trying to learn lol
Old Jul 30, 2014 | 05:11 PM
  #8253
TFD's Avatar
TFD
Hi people,
can't find the answer and don't want to start a new topic so hence the question here:
Can you put a 2.4 IM on a LSJ (B207 in europe) ?? And when boosted, how much psi can the 2.4 IM handle? Looking for 8-10 psi of boost.
Thank you,
Daniel
Old Jul 30, 2014 | 05:16 PM
  #8254
JapEatr's Avatar
South Central *********
Goedemiddag!
the better option is the LK9 saab manifold for the LSJ. the 2.4 mani is plastic and will not sustain pressure
Old Jul 31, 2014 | 02:39 AM
  #8255
TFD's Avatar
TFD
Haha goedemiddag lol, Dutchy as well?
So it does fit. I know they will pop at a certain point, just wanted to check at what point ;-)
Grtz,
Daniel
Old Jul 31, 2014 | 07:20 AM
  #8256
i944scania's Avatar
does anyone have 80s for sale? im maxing out my 60s.
Old Jul 31, 2014 | 08:40 AM
  #8257
Grtz,
Daniel
it depends but most that i have seen run around 20 or so
i have a brand new set of ev6 80's
Old Jul 31, 2014 | 08:46 AM
  #8258
i944scania's Avatar
send me a message. i could do partial trade for 60s too if that interests you.
Idk what the ev names mean, i forget which connector is which but i have siemens 60s from zzp, so i had to get the adaptor harness for them.
Old Jul 31, 2014 | 10:41 AM
  #8259
BLAZIN07SS's Avatar
I'm too JDM for you
ZZP stage 3 cams $525 shipped today only!
Old Jul 31, 2014 | 09:44 PM
  #8260
Cherry GT's Avatar
Grtz,
Daniel
I run 11psi on stock 2.4 mani and I believe I've heard of running 15.....
Old Jul 31, 2014 | 10:40 PM
  #8261
EXsoccer1921's Avatar
So what's a good price on a Quaife LSD?
Old Jul 31, 2014 | 11:49 PM
  #8262
Gmoney06's Avatar
So after doing some more researching I've decided against going the cheap k04 route. After numerous people saying it's just no good on the lsj. Was looking at the pte 5554, any opinions on that turbo? Goals are not big, 300ish whp will make me happy for now.
Also if I go with this pte 5554, does anyone know if the Hahn or zzp downpipes could be made to work? I don't know of any good tuner shops around me and am currently lacking a welder, so the more parts I can buy that won't require too much fab work the better. Would like to use the zzp pipe so I can recirc my wastegate. No screamer pipes for me, would like to keep it as quiet as possible.
Old Aug 1, 2014 | 08:51 AM
  #8263
ev6 is the base model connector. i dont think it would be plug and play for ya
i have alan's old 5531 and he had a zzp dp on it
Old Aug 1, 2014 | 11:34 AM
  #8264
armcclure's Avatar
the zzp dp could be made to work, but you would for sure have to use their manifold and have a very skilled fabricator line up the recirc pipe.
there's a reason mine goes out the hood, and it's not purely for noise
Old Aug 1, 2014 | 07:52 PM
  #8265
Gmoney06's Avatar
I was planning on using there manifold. Would the downpipe work better if I didn't go the recirc route and ran a screamer pipe? Or should I just plan on having to have one built? Really want to recirc as I would like to keep it as quiet as possible.
Old Aug 1, 2014 | 09:42 PM
  #8266
Cherry GT's Avatar
any tuners care to look at this...I need help !
afr and timing big swings at P or N idle
Thanks for your time !
Old Aug 2, 2014 | 01:51 PM
  #8267
noorj's Avatar
hmmmm you don't say?
Old Aug 2, 2014 | 02:23 PM
  #8268
JapEatr's Avatar
I know I know....
Old Aug 4, 2014 | 08:27 PM
  #8269
Bluelightning's Avatar
Got Bewst?
Anyone here running meth injection on thier LSJ-T? I was looking into something else than drilling a hole in my charge pipe for the nozzle. Like a throttle body spacer but I can't seem to find one for the 2.4 TB.
Old Aug 4, 2014 | 10:22 PM
  #8270
574's Avatar
574
Just tap it
Old Aug 4, 2014 | 11:07 PM
  #8271
Got Bewst?
Looking for something cleaner for an install if possible. Maybe I'll just get a tb spacer made.
Old Aug 5, 2014 | 12:44 AM
  #8272
Rut rohh.
Old Aug 5, 2014 | 07:41 AM
  #8273
TStone's Avatar
Rut rohh.
I would ask what you're doing since winter is coming up but you probably don't even have winter out there -___-
You gonna go for that top 10 list?
Old Aug 5, 2014 | 11:12 AM
  #8274
InfraRedline's Avatar
So the car does still exist? lol
May be hitting up the local dyno dynamics on Thursday just to play around a bit. I am not expecting great numbers (stock LSJ makes about 160-170whp on it), but it will be fun to see how much I can gain and what each lb of boost does. And way safer than dialing in higher boost on the street.
Old Aug 8, 2014 | 07:04 AM
  #8275
i944scania's Avatar
so i just bought 80s. my 60s max out when its under like 72 degrees out.
someone on the dreaded css gang said he was maxing out 80s with his tvs setup and about 330whp.
Is that BS or no? cause im running a bit more than 330 and just starting to max out my 60s
