Official TVS Thread!!!
Old May 20, 2014 | 04:24 PM
  #8651
Bluelightning's Avatar
Got Bewst?
Not really. It's an average number.
Old May 20, 2014 | 05:02 PM
  #8652
mrbelvedere's Avatar
now blue you know its earth shattering wide
Old May 20, 2014 | 05:17 PM
  #8653
slitterell's Avatar
Confrontational was the word I was looking for when I was talking to you John lol
Old May 20, 2014 | 05:19 PM
  #8654
no not me lol
Old May 20, 2014 | 05:51 PM
  #8655
mezzanno's Avatar
Originally Posted by KTM
Would you recommend it. I could get before I take the car to get tuned.
yes
I'll look into it. Which kit do you recommend?
alky control
Well I ran meth injection for 4 years with my M62 and TVS. It does work really well if you don't have access to E85. The problem I did was I got a little greedy with it spraying larger amounts. Last year the line pulled off the pick up line of my meth and took my motor down. But I was spraying so much that the car relied on it. So if you choose to spray meth, just done tune it so the car relies on it and you can catch it if you ever have an issue.
spraying lots of meth is not a problem, using a cheap kit is.
I ran a Devilsown stage 1 kit. Was a good bang for the buck.
cheap kit
There's 2 ways you can go with meth. Either run it small enough that you have time to **** down f it fails, or run it so heavy that the car will just fall over if it fails. As if your fuel pump went out.
this
Old May 20, 2014 | 06:46 PM
  #8656
Got Bewst?
Ya I know there's a kit that will cut engine power if the meth quits but it's super expensive. 99% of the kits out there no matter what if the meth injection quits, you're running lots of it and don't catch it the motor is goin down.
Old May 20, 2014 | 11:12 PM
  #8657
Dave1515's Avatar
Thanks for the insight guys, always a good read.
Old May 20, 2014 | 11:19 PM
  #8658
Haven07's Avatar
Just a question regarding the meth injection, anyone think aem's wideband fail safe gauge could potentially pick up the meth pump failing and revert the car to a rich tune to protect the engine? Or that split second is enough to destroy it?
Old May 20, 2014 | 11:27 PM
  #8659
CobaltSS 16's Avatar
That's why I'm too much of a ***** to run meth
Old May 21, 2014 | 12:56 AM
  #8660
100% METH's Avatar
Install correctly
Set fail safe via timing adders in the tune itself
Stop being a *****
I just installed my 7 year old system on a 2.4 sc. Runs 12gph and 10* advance at 14 psi
Gds
Old May 21, 2014 | 07:48 AM
  #8661
armcclure's Avatar
Mine is on the other end of the spectrum. 17gph of straight meth. I have had it quit twice. Once tank was empty, other the boost line popped off thanks to 30 psi. Both times I was logging, and both times the car just dumped over as if I let off the gas. No kr. No problems.
Old May 21, 2014 | 08:59 AM
  #8662
Got Bewst?
Wow that's crazy arm haha. Back when I ran a 7gph on my M62 the pump quit but kr would go crazy with and sort of wot so I knew. The last time with my 14gph all it took was a quick 4-7k pull in 2nd passing someone and I busted a ring land. No kr even showed up. Perhaps it was just detonating that hard.
Old May 21, 2014 | 09:48 AM
  #8663
armcclure's Avatar
Yeah 7 pre turbo, 10 post.
No meth iat would break 200 halfway through 3rd. Now they drop during a pull.
Old May 21, 2014 | 10:28 AM
  #8664
InfraRedline's Avatar
The difference here is that you are not relying on the meth for octane, and will not see much for KR if it fails, even if the car were to keep trying to pull. E85 is the ultimate safety cushion.
Me personally, I recommend meth to people who don't have access to E85. I ran meth for about 6 months quite a while ago, had a fuse pop where my power line was tapped (no ones fault but my own) and the pump quit because of it and I saw quite a bit of KR and a bit lean for a few pulls, but was only on a 5gph or 7gph nozzle, can't remember, and I caught it in time and didn't do any damage. I ripped the kit off the next day and ordered some injectors and started with E85 and the car hasn't seen a drop of 91 since, promised my car I'd never put it on pump gas nonsense again. That was nearly 5 years ago now. So in short my opinion is run meth if you can't run E85, don't get the TVS if you aren't going to run meth (or if you want my real opinion I'd say don't run the TVS if you can't run E85), and if you run meth get a good kit with as many failsafe features as possible because you will need a large nozzle to make it worth your while to get some decent gains.
Old May 21, 2014 | 10:45 AM
  #8665
armcclure's Avatar
Well said
Old May 21, 2014 | 10:52 AM
  #8666
Again, that is just my opinion lol
Old May 21, 2014 | 01:36 PM
  #8667
Powell Race Parts's Avatar
Originally Posted by mezzanno
yes
alky control
cheap kit
this
Mezzano knows. And frankly, nothing wrong with a 300 whp TVS dd on 93 octane.
Old May 21, 2014 | 08:07 PM
  #8668
TStone's Avatar
Besides the car not being able to move out of its own way
i kid i kid
Old May 22, 2014 | 11:22 AM
  #8669
KTM's Avatar
KTM
I could run e85,have one station like ten miles from home but the others are Morgantown and Pittsburgh. So I'd be limited to where I drive.
Old May 22, 2014 | 02:34 PM
  #8670
RooTBeeR's Avatar
i need to put this back in use already. takes up too much trunk space as is.
Old May 24, 2014 | 01:16 PM
  #8671
SSfamilywagon's Avatar
Just showing off some TVS love and how ours is coming along since I've been cleaning up the engine bay!
Old May 24, 2014 | 01:56 PM
  #8672
Got Bewst?
Very nice! So clean!
Old May 25, 2014 | 05:10 PM
  #8673
gibsonj4's Avatar
Here is my dirty ass engine bay haha
Took it for like a 10 minute drive after getting the base tune and IAT2s were 180+. Came back and the IC pump had gone out went ahead and ordered a new one.
Old May 25, 2014 | 05:16 PM
  #8674
RooTBeeR's Avatar
stock "t-bottle" and aluminum intake?
tsk tsk
Old May 25, 2014 | 05:26 PM
  #8675
gibsonj4's Avatar
tsk tsk
haha well the intake came on the car. Ordering a 3in from OTTP this week. Not going with the LS4 TB.
