Official TVS Thread!!!
**** I think he even made like 350 ft lbs on one run...
Big waste of $50 if you ask me... would of rather put that into methanol or gas.
That dyno operator has one funky reading dyno; that's aerodynamics for you though... remember what Infraredline's torque was on his dynodynamics lol. (240s)
hp/trq don't even cross @ 5250
He doesn't wanna post it mainly because it doesn't make any sense.
Though based on his setup, which is near identical to the setup I tuned out here on the dyno I always use. His car on a eddie current dynojet (loaded dyno) would make somewhere between 340-355whp/295-305 ft lbs
Setup Euthanasia and I dynoed here
TVS 2.6 - 60s - water/meth
badmab - 2.5" dp - 2.5" catback
3" intake - stock tb
peak timing 25* in midrange, 21* at the top made 334whp/295 ft lbs (originally @ 27.5* up top, but 91 octane unfortunately had other ideas and kicked timing down)
Tyler's setup is
TVS 2.6 - 80s - water/meth
badmab - 3" dp - 3" catback
3" cold air - ls4 tb
peak timing in midrange 25*, peak @ redline 28*
Now timing past 25.5* doesn't necessarily make more hp. But it does maintain cylinder pressure to hold a flatter broader torque line.
Tyler's setup is
i won't judge u Tstone. just wanna know wut ur puttin down so i can get some ideas wut i'll put down
shhh steve, no comments from u. lol
Check the war story's. Srt4 vs tc
The dude was nuts. Before we started, he set the max hp reading to 220.... Did the first pull & just watched to go straight up past 220... & it was a dyno dynamics so I was making like 280's.. But if you convert the numbers to Dynojet numbers like everyone else does, it'd be 330ish. I have a graph of like 283/290 on dyno dynamics & a graph of 333/345 with Dynojet corrections.
& I deleted it just to avoid those ****** fanboys. I'll post it in here if anyone truly wants to see it. & I didn't wanna have to explain to a bunch of amateurs the difference of Dynojet & dyno dynamics
But if things were as bad as you were making them out to be, you might want to go some where else...
His dyno is what most people use around here. I just used this oneee cause it was cheap. I'll call his dyno and see whats ip
$85/hour. & it's an actual dyno jet
and everyone will
