Jn2's goes the easy route
Nothing wrong with street tuning, if that all you have.
A professional Dyno tune will **** on a street tune EVERY TIME.
I guess it will take you getting tuned, Having the car run like ****, Then putting it on a dyno, and realizing the tune sucked. THEN HOPEFULLY you will take it somewhere worth a **** and have it tuned for real.
Street tunes are good for one thing.
Getting the car driveable enough to drive it to the real tuner. Thats it.
Do you think all these guys that run 11.5's and 10.9's etc etc are sitting in there car tuning it themselves? LOL the answer is No.
Who are "all these guys "running 11.5s and 10.9s? Ive never seen a street driven balt run 11's. let alone 10's. And of course as mentioned there is no live tuning suite available for his car, SOOOO it doesnt really matter anyway. All that aside I still fail to see how datalogs taking from a street run are superior to those taking on a dyno run.
yea, a ported blower/TB wouldnt change boost pressures. Im just saying when i ran a stg 2 pulley i was at like 11psi, and you're at 13psi. Now that i run a 2.9 im at 13psi, and a couple others running a 2.9 are at 15psi. Im always a couple behind..idk if thats because im flowing better, or if i have a leak of some kind though.
your the one who inspirated me to do my build so your car should be the shiznit. lol
no cuz he made me run alot more fuel in my car when he tune it. like i used like 95 percent of my injectors so that cause it to run rich and more boost cuz of the fuel. but when i was tune right i am only using 80-88 percent of my injectors. so that could be it. but not really sure.
here's a little something is pent a good hour making, made this for you blown 2.2's wanting something for a backround etc, image worked on using Cs3, i did not go into extreme detail, but i believe it looks nice, i was not able to paint the blower or valve cover, well i could but i could only get a matte/flat color out of it, i was not able to get a shiny black blower with a shiny black valve cover, only a flat black blower and cover, so i decided not to save it
i'd love to upgradenaw dude...fueling will not affect boost levels. boost is created in the manifold, and that is also where the MAP sensor is. Fuel injectors are downstream of that, in the head just above the valves. Adding things into the head after the manifold should have no effect on the manifold pressures.
lay it over the map mold it in shape and make a sort of holder to hold the map down into the manifoldps. here's a shot of how the image would look like a phone
im confused...it looks the exact same as the picture on google, only the colors are all brighter/more vivid
edit: nvm...just noticed the 2.2 valve cover
also, the sensor i circled here:
is a 1bar MAP sensor that just so happens to fit directly into the LSJ manifold.
it was the pic from google of the cavi 2.2, and the pic of a lsj on google, i saved them both, re-sized the lsj one as it was too small, copied over the blower section, and added it to the 2.2 image, than went back and cleaned up some areas, thats why u see that sensor there :p just to be clear i did not put a 2.2 valve cover on a 2.0 image, i put the whoel blower assembly on a 2.2 image
you don't need a map on the sc cuz we don't use it. but you can use it to plug the hole much better than finding something to put in it.
look at interview build he got a video of wat he had to grind down.
Last edited by stenguyen1; Apr 17, 2009 at 03:56 PM. Reason: Automerged Doublepost
I made up my own thread now since I'm the LAP and I don't want to intrude on people's threads. I have a question about the MAP sensor that totally doesn't seem right. Could you guys please start visiting my thread and possibly answer my question?
https://www.cobaltss.net/forums/2-2l-lap-performance-tech-168/genes-2-2-lap-supercharger-build-166563/
Thanks, Gene.
Thanks, Gene.
https://www.cobaltss.net/forums/showthread.php?t=166563
Thanks, Gene.
Thanks, Gene.
