Jn2's goes the easy route
Old Apr 15, 2009 | 01:04 PM
  #226
Maven's Avatar
Originally Posted by TwoStep
Nothing wrong with street tuning, if that all you have.
A professional Dyno tune will **** on a street tune EVERY TIME.
I guess it will take you getting tuned, Having the car run like ****, Then putting it on a dyno, and realizing the tune sucked. THEN HOPEFULLY you will take it somewhere worth a **** and have it tuned for real.
Street tunes are good for one thing.
Getting the car driveable enough to drive it to the real tuner. Thats it.
Do you think all these guys that run 11.5's and 10.9's etc etc are sitting in there car tuning it themselves? LOL the answer is No.
If you drive your car on a dyno a Dyno tune is perfect, if your drive your car on the street, theres nothing wrong with a street tune.
Who are "all these guys "running 11.5s and 10.9s? Ive never seen a street driven balt run 11's. let alone 10's. And of course as mentioned there is no live tuning suite available for his car, SOOOO it doesnt really matter anyway. All that aside I still fail to see how datalogs taking from a street run are superior to those taking on a dyno run.
Old Apr 15, 2009 | 01:27 PM
  #227
stenguyen1's Avatar
Originally Posted by HunterKiller89
yea, a ported blower/TB wouldnt change boost pressures. Im just saying when i ran a stg 2 pulley i was at like 11psi, and you're at 13psi. Now that i run a 2.9 im at 13psi, and a couple others running a 2.9 are at 15psi. Im always a couple behind..idk if thats because im flowing better, or if i have a leak of some kind though.
yea i know wat your saying. but maybe you should check your lines and etc to figure out why your not boosting more than 13psi. cuz i'm runnin that right now. but it can be the tune also or maybe cuz its auto?????
your the one who inspirated me to do my build so your car should be the shiznit. lol
Old Apr 15, 2009 | 02:45 PM
  #228
Jn2's Avatar
Jn2
ur 13psi on a 3"??? Shut I'ma me running a 3.1" I was hoping for a good 14psi
Old Apr 15, 2009 | 03:00 PM
  #229
MP81's Avatar
I'm hoping for around 13 psi...
Old Apr 15, 2009 | 04:11 PM
  #230
ebristol's Avatar
General rule of thumb. If you are running the same size pulley as someone else and getting less boost then you are better off then they are.
Old Apr 15, 2009 | 04:16 PM
  #231
HunterKiller89's Avatar
ill figure it out soon enough. I have a new pypass valve actuator that im gonna install one day soon
Old Apr 16, 2009 | 01:00 PM
  #232
stenguyen1's Avatar
yea i got the gm stage 2 pulley running around 13 psi.
was runnin 15 on the pulley but thats when i was runnin way too rich. so when vince tune it than now i'm runnin 13psi
Old Apr 16, 2009 | 01:08 PM
  #233
...thats kinda weird... AFR's dont affect your boost pressure at all...
Old Apr 16, 2009 | 01:59 PM
  #234
MP81's Avatar
Yeah, that is kind of odd...
Old Apr 16, 2009 | 03:58 PM
  #235
stenguyen1's Avatar
no cuz he made me run alot more fuel in my car when he tune it. like i used like 95 percent of my injectors so that cause it to run rich and more boost cuz of the fuel. but when i was tune right i am only using 80-88 percent of my injectors. so that could be it. but not really sure.
Old Apr 16, 2009 | 04:27 PM
  #236
naw dude...fueling will not affect boost levels. boost is created in the manifold, and that is also where the MAP sensor is. Fuel injectors are downstream of that, in the head just above the valves. Adding things into the head after the manifold should have no effect on the manifold pressures.
Old Apr 16, 2009 | 10:58 PM
  #237
Jn2's Avatar
Jn2
here's a little something is pent a good hour making, made this for you blown 2.2's wanting something for a backround etc, image worked on using Cs3, i did not go into extreme detail, but i believe it looks nice, i was not able to paint the blower or valve cover, well i could but i could only get a matte/flat color out of it, i was not able to get a shiny black blower with a shiny black valve cover, only a flat black blower and cover, so i decided not to save it
Old Apr 16, 2009 | 11:02 PM
  #238
ebristol's Avatar
Very cool man. I have CS4 on my work computer. I had no idea how to use it...
Old Apr 16, 2009 | 11:11 PM
  #239
Jn2's Avatar
Jn2
wanna share ur license key with me i'd love to upgrade
i still need to figure out how ima mount my MAP, the hole on the manifold is bigger than the nipple on the MAP, and also my map is a twist on map, i dont have the plastic flange o'rdeal thing to bolt it, so ima have to find a way to put it on and keep boost from blowing it out, im thinking of using quick steel to mold my own plate lay it over the map mold it in shape and make a sort of holder to hold the map down into the manifold
ps. here's a shot of how the image would look like a phone
Old Apr 16, 2009 | 11:12 PM
  #240
im confused...it looks the exact same as the picture on google, only the colors are all brighter/more vivid
edit: nvm...just noticed the 2.2 valve cover
also, the sensor i circled here:
is a 1bar MAP sensor that just so happens to fit directly into the LSJ manifold.
Old Apr 16, 2009 | 11:33 PM
  #241
Jn2's Avatar
Jn2
it was the pic from google of the cavi 2.2, and the pic of a lsj on google, i saved them both, re-sized the lsj one as it was too small, copied over the blower section, and added it to the 2.2 image, than went back and cleaned up some areas, thats why u see that sensor there :p just to be clear i did not put a 2.2 valve cover on a 2.0 image, i put the whoel blower assembly on a 2.2 image
Old Apr 17, 2009 | 07:51 AM
  #242
stenguyen1's Avatar
well alright. i was just sayin. i didn't really know if that was the case. thanks for the info tho. just weird how i could be boostin 15 than go down to 13.
Old Apr 17, 2009 | 02:54 PM
  #243
Jn2's Avatar
Jn2
Ok so I have to grind a part of the engine, can someone label the specific part in a pic?? Like circle it?
Old Apr 17, 2009 | 03:37 PM
  #244
ProjectBolt08's Avatar
so will our (2.2) map work on the blower? from what i seen. a few 2.2's just plugged it off.
Old Apr 17, 2009 | 03:56 PM
  #245
stenguyen1's Avatar
you don't need a map on the sc cuz we don't use it. but you can use it to plug the hole much better than finding something to put in it.
look at interview build he got a video of wat he had to grind down.
Last edited by stenguyen1; Apr 17, 2009 at 03:56 PM. Reason: Automerged Doublepost
Old Apr 17, 2009 | 04:00 PM
  #246
oh ok thx. i was like what lol. but yeah you have a nice setup stenguyen1
Old Apr 17, 2009 | 08:01 PM
  #247
Gene Culley's Avatar
I made up my own thread now since I'm the LAP and I don't want to intrude on people's threads. I have a question about the MAP sensor that totally doesn't seem right. Could you guys please start visiting my thread and possibly answer my question?
https://www.cobaltss.net/forums/2-2l-lap-performance-tech-168/genes-2-2-lap-supercharger-build-166563/
Thanks, Gene.
Old Apr 18, 2009 | 12:46 AM
  #248
MP81's Avatar
https://www.cobaltss.net/forums/showthread.php?t=166563
Thanks, Gene.
Subscribed to your thread.
Old Apr 18, 2009 | 01:54 AM
  #249
replied
Old Apr 19, 2009 | 11:32 AM
  #250
Thanks guys. Will check it out.
