OFFICIAL Blown 4-banger build updates!
it's not cheap, but I don't set the priceing. The only shop I trust makes them, the co-owner is a mater fabricator.
I'm sure andy could make u one in the just sub-thousand mark.
Not cheap, but baller material and workmenship.
I wanted to jet hot it, but I couldent, to dam pretty!
Ok, the events have been set into motion. My blower/intake manifold/intercooler pump and all plumbing are officially sold. It is time to start gathering parts for the NEXT part of my build!
congrats man.
and the major issue with the low tq on the hahn car was the 8.0:1 compression... not good.
Anyway I wish you luck with the turbo setup man, You're car is going to be quite the animal with the motor you have in there now.
yet they never got it....
tuned properly and you should be fine. with the **** gas out there you won't be able to run as much boost on pump gas, but with your head and cams and a good turbo mani, you should still see over 400whp
Yeah, and on race gas it will be a WTFBEAST!!! 9.5:1 compression and 30 psi!?!? 600 whp?
You shut up!!! I still think going turbo is the worse thing I could possibly do to this car!!!
