For discussion of all things Powell!!
Old Jun 26, 2013 | 10:51 AM
  #476
Scythe_Snake's Avatar
Wow this thread has blown up! This is awesome. Ooo, I hope funds look right for those rails for CED.
Old Jun 26, 2013 | 11:33 AM
  #477
armcclure's Avatar
Hey! Sidepost:
Are there any more vids of your Chicago run?
Edit: just found the thread. Disregard
Old Jun 26, 2013 | 12:45 PM
  #478
steddy2112's Avatar
Its not money, its just difficult to find PSW to work beleive it or not. I had to cancel out of Steddy and Sara's wedding and that was a downer. Mum gets around no problem, but there are a couple of issues: she is British, so she would starve to death if she was normal ,as the British cant cook.
But she is 98, so she has reached the stage where she forgets to eat anyway, even if she could remember how to cook lol.
Brits live like forever too.
weird that I never put the two and two together.
No one has ever talked about "tarts" except my very British late grand mother
and
you
You'll make it down here or I'll make it up there. Don't sweat it.
Old Jun 27, 2013 | 10:45 AM
  #479
kdub1492's Avatar
Got my PCV hooked up, all is well so far!
Old Jul 7, 2013 | 12:49 PM
  #480
Killswitch's Avatar
Awhile ago Powell posted how to change springs without a spring compressor but I can't remember where I seen and I'm going to install my YYZ today. Anyone help a brother out?
Old Jul 7, 2013 | 02:13 PM
  #481
Powell Race Parts's Avatar
bring car to where you will work on it. before doing anything, loosen main shaft nut so the nyloc is clear of the shaft while still threaded on.
jack car up put on stands.
remove wheel
place jack under ball joint. compress lightly. remove drop link and loosen lower strut nuts.
remove top strut nut.
lower strut assembly, drive out lower strut bolts and remove strut assembly
clean and replace with new spring, orienting spring hat tab to 12 o clock facing inner fender.
install strut assembly carefully putting lower strut bolts in place. then with a screwdriver or punch centering the strut shaft through the top strut mount, making sure the bearing and strut spring hat is in place, jack assembly back up guiding the shaft through the mount so it does not catch on the threads.
put strut nut on hand tight.
replace all parts torque all nuts except top strut nut. torque that when the car is lowered back down, after installing wheels etc.
Old Jul 7, 2013 | 02:23 PM
  #482
^ that works great, did that last time I swapped springs after the cheap spring compressor broke (thankfully no one was hurt and the spring didnt launch and now I have a much stronger and better spring compressor)
Old Jul 7, 2013 | 03:04 PM
  #483
Killswitch's Avatar
remove wheel
Awesome thanks for the quick reply! Ill post up a review after I install the springs and hardcore bar
Old Jul 7, 2013 | 03:23 PM
  #484
colodude18's Avatar
Did you put your YYZ springs on yet?
Old Jul 7, 2013 | 04:28 PM
  #485
No...think i'm going to one night this week. Still need to find a set of blown shocks and Koni yellow inserts so the intall will go smoothly
Old Jul 9, 2013 | 03:21 PM
  #486
andrewcarr1993's Avatar
I was installing my koni struts/shocks and YYZ v3 springs today. Did the rear and it went flawlessly took me about an hour by myself. Went to do the fronts and the swaybar endlinks decided to ruin my plan and rather than the nut coming loose from the strut the bolt broke the rubber and is spinning. Got to pick up new ones tomorrow and cut off the old ones. My front is riding about 1'' higher than the rear at the moment though.
Old Jul 9, 2013 | 03:41 PM
  #487
Drop links are a pain. I keep power grids on the shelf and used spare stock ones for guys tight on money. I also keep PC used knuckles and new bearings because they are a pita as well. Sorry for your trouble you are not alone
Old Jul 9, 2013 | 05:32 PM
  #488
Killswitch's Avatar
So I got my YYZ springs as well as my hardcore rear bar installed over the weekend, and wow! Car feels night and day different from my old Sportlines. Ride is 100% improved and id say on par with stock, although it has been awhile since my car was stock The turn in is much sharper and under steer is all but gone, car is much more neutral. Ill get a chance to try out some more aggressive driving this weekend at my first autocross event the only thing I don't like about them is how much higher the rear sits, which really isn't that big of a deal and I'm probably the only one who will notice lol bottom line 9/10 highly recommend!
Side note: When installing I'd recommend changing the fronts without a spring compressor as detailed by John above /\ much easier and way faster (well for me at least)
Now on too the pics!
On Sportlines
YYZ
Old Jul 9, 2013 | 05:39 PM
  #489
looks good to me.
Old Jul 9, 2013 | 06:14 PM
  #490
Killswitch's Avatar
looks good to me.
Me too just when I thought I might be getting bored with it and you made me fall in love all over again! Thanks again!
Old Jul 9, 2013 | 07:40 PM
  #491
U in Grand Prairie you should chase after Amanda...well .... and her silver Powell built 2.2 Auto with Brembo's, redline wheels and a modified twist beam....
Old Jul 9, 2013 | 09:53 PM
  #492
ssyellow's Avatar
Chip @ Power Grid is currently out of the SS end links at the moment, think he said they will be ready next week or so.
Old Jul 9, 2013 | 10:43 PM
  #493
I got some. you want some? email me orders@powellraceparts.com ships tomorrow lol
Old Jul 9, 2013 | 11:43 PM
  #494
Killswitch's Avatar
Think I've actually seen that car driving around, figured you had a hand in it lol
Old Jul 9, 2013 | 11:53 PM
  #495
a babe for sure. car is good for what it is.
Old Jul 10, 2013 | 09:01 AM
  #496
ssyellow's Avatar
I decided to just get the Moogs for now. Reading into a discussion about them on the other website you mentioned the salt (winter driving) will eat away at the zinc coating.
Figured it would be best not to ruin a good set of sway bar end links
Old Jul 10, 2013 | 09:13 AM
  #497
armcclure's Avatar
Get the moogs, blast them, chromoly tube that slides over the shaft, cut in half, slide in tubing, tig. Boom. Power grid strength (almost) minus the adjustability.
Old Jul 10, 2013 | 12:05 PM
  #498
^^ melt the
Boots while welding and go
Nuts. KISS Moog and be done
Old Jul 10, 2013 | 09:46 PM
  #499
Pinky Demon's Avatar
That's interesting and I never considered that about the Powergrids.
How well do they hold up in salt, brine, snow, and Ohio nastiness?
Old Jul 10, 2013 | 10:13 PM
  #500
the zinc plating on Powergrids is really a cad plating I think, and it stands up better than zinc on the powergrids. Salt screws everything thats why I no longer drive the RL in winter and I have replaced all the parts that did get salt covered the one winter i used it.
I now use 10.9 cad plated bolts in our sway bar hardware packages. I tried stainless, which resists corrosion very well, but the bolts are as weak as grade 5 and more brittle so stopped.
The wntrbtr2 a SAAB 9-5 is stellar for corrosion resistance. But I wash it a lot in winter, and I oil it underneath prior to winter. The rear muffler will probably succumb first to salt, but the main system is good quality stainless and stands up well. LNF downpipes stand up well to winter I have found...
