PDA
View Full Version : How to requests and questions
  1. SS axle lengths
  2. engine swap 2.0 supercharged
  3. 08 cobalt lt crankshaft position sensor
  4. Turboing a 2.4
  5. Air Bag Senser replacement on Cobalt SS 2008
  6. Air Bag Senser replacement on Cobalt SS 2008
  7. Exhaust
  8. Tail light halo questions
  9. Timing
  10. Rearview Mirror replacement
  11. Replacement of coolant return tank on 2007 SS Supercharged
  12. Acceleration surge under constant load & psi loss
  13. Adjusting boost
  14. 09 Cobalt Broken Door Knob (manual lock pin)
  15. Oil pan removal
  16. Intall non-factory radio
  17. 06 SS Trans/Motor yanked...HELP!!!!
  18. How to rewire steering wheel controls?
  19. Change rear end of 4dr to 2dr style
  20. How to Install Fuel Lobe
  21. Closed loop idle issue
  22. help
  23. LSJ Heat Exchanger Removal
  24. security
  25. Requesting a retrofit install how to
  26. No power..
  27. LNF to LSJ brake conversion
  28. BRFPS How To Install
  29. HELP ! - OTTP RSFS How-To
  30. looking for some retrofit headlights !
  31. Help installing aftermarket HU.
  32. how can I remove front chevy bowtie?
  33. Removing Front lip on cobalt ss? help
  34. Treadstpne block off plate
  35. Ucr
  36. Trying to remove balance shaft bearings
  37. Aftermarket tachometer
  38. Trunk open message
  39. Dash Dissembly Help
  40. Code PO010
  41. Oil Pressure Gauge
  42. need 2 things
  43. painting valve cover
  44. How to make sunroof automatic
  45. cobalt ss lsj wot box install
  46. Can't see pictures in HOW TO
  47. HELP! need to add a/c
  48. washer pump and wiper issues
  49. cant install hp tuners software
  50. Can you swap a 06 motor with a motor from an 08?
  51. Can i swap my shift knob?
  52. Shift cable help please!!!
  53. How to Camshaft position sensor 06 SS/SC
  54. How to install trailer hitch
  55. remove timing cover
  56. Fuel feed and return lines
  57. Battery Replacement
  58. ion to cobalt ss front end conversion
  59. MAF Sensor
  60. Installing GlowShift Digital Wideband
  61. Fix Trunk Release Button
  62. How To Install Stock Pioneer Sub in a Base Model
  63. How do I remove single din pocket?
  64. How to put in HID
  65. Sell or part out my 79000 mi f35 (mu3) (g85) 5 sp tranny??
  66. How to remove headliner and A-pillars
  67. How to paint badges around car
  68. Camshaft position sensor
  69. Set up/wire Nitrous Oxide system.
  70. aftercooler pump rebuild
  71. How to install phenolic spacer
  72. how to change rack and pinion
  73. How to run wires from Engine Bay to the Interior?
  74. need help on RBD
  75. How to get sedan rear windows rolled all the way down?
  76. how to...
  77. Coilover how-to/tips
  78. Welcome to the how-to request sub-forum!
