View Full Version : How to Guide
- 2.0 LSJ Engine How to disassemble transmission case shifter rods
- Electrical Airbag/SIRS Bypass Wiring
- 2.0 LSJ Engine Crankshaft position sensor
- Drivetrain 06 Le5 Manual Swap
- 2.0 LNF Engine Proper Working Oil Catch Can setup For LNF (IMPORTANT UPDATE!!!)
- 2.2 LAP Engine Washer Fluid Tank Relocation
- Appearance How to prep and paint your supercharger and valve cover /engine parts
- All Engines How to Baffle a Cheap Catch Can
- 2.0 LNF Engine LNF Proper S257 Turbo system Install
- Electrical Program new key fob at home without tech 2: How to
- 2.0 LSJ Engine Intake Gasket Repair - Help!!
- 2.0 LSJ Engine option B tank hose path orientation
- 2.0 LSJ Engine zzp s3 install mounting
- 2.0 LSJ Suspension control arm bushing replacement lessons learned
- Electrical How To: LED third brake light Cobalt/G5
- 2.0 LSJ Engine Cold Air Intake
- 2.0 LSJ Engine Cam Cap Removal
- 2.0 LNF Engine lnf Valve cleaning and powell v3 oil seperator install
- Other/Misc diy vibramount for below pics if the one you got is wrong.
- Electrical 2008 Cobalt SS Stereo Wiring
- Other/Misc Brake Master Cylinder Replace
- 2.0 LSJ Engine OTTP return fuel system
- 2.0 LSJ Engine Anybody have a how to for an oil catch can on a lsj?
- 2.0 LSJ Engine how to remove LSJ injectors
- Electrical How To: Install WOT BOX on LNF
- Appearance sunroof removal?
- Appearance LED Side Marker Lights
- Exhaust How to fix afternarket exhaust leaks!
- Drivetrain MU3 F35 Stock shifter linkage adjustment!
- Electrical How to change headlight bulb
- 2.0 LNF Engine How to install injector seals (LNF)
- Meth Kit Install (Pics)
- 2.0 LSJ Engine How To: Gen 3/Gen 2 no sleeves in LSJ block
- 2.0 LNF Engine Updated guide on how to install ZZP's Borg Warner Turbo (ZFR)
- Other/Misc Brembo Swap on LSJ
- Interior How to: Remove/replace Steering Wheel (05-06)
- 2.0 LNF Suspension Brembo Caliper Rebuild
- Electrical How to use HID lights as Daytime Running Lights
- Electrical How to install load resistors Cobalt / G5
- Interior How To: Swap 05-06 radio for 07+
- 2.0 LNF Suspension ZZP Engine mount install by Hoagies Garage
- Electrical Clockspring Replacement
- 2.2 L61 Engine Cheap Intake Manifold Swap
- Electrical HOW TO: Install EGT Gauge in your Cobalt SS
- Wheels/Tires How to install OEM center caps on aftermarket wheels
- Interior Tip for installing your new gauge bezel
- Appearance CCFL headlights.
- Electrical DIY How To: install compustar remote starter in 2008 Cobalt SS
- Appearance How-to: BPS OEM Adapter
- 2.2 L61 Engine How to remove timing cover / front cover
- Other/Misc Itrader How-To
- 2.0 LNF Engine How To: Valve Gunk/Coking Removal
- 2.0 LNF Engine How To: Remove Intake Manifold
- Electrical Regaining High Beams with HIDWerks.com Retrofit Headlights.
- Electrical How to replace Steering Wheel Audio Controls Lamps
- Cobalt SS Shift Knob Removal, 6 Easy Steps *W/Pics*
- All Engines Chaos Six Dual Pass
- 2.0 LSJ Engine How To: Replace LSJ Clutch Master Cylinder
- HOW TO: proper two bucket wash. (pic heavy)
- Appearance "How to" remove SS High Rise Spoiler/Wing Fin Blade Insert
- Other/Misc How To "Correctly" Use the Search Feature on COBALTSS.net
- Other/Misc Injector size???
- Interior How to Easy inner door handle re-assembly
- Interior Brushed Aluminum effect for chromed plastic
- 2.0 LNF Engine Treadstone TR8 Kit DIY install.
- Electrical how to install a traction control button/false ebrake for autos
- HOW TO: Disassembly of rear (damaged) LNF brakes
- Appearance Led third brake light
- Interior How to adjust any short shifter Hurst BPS TWM B&M
- Appearance How to Install Sideskirts on base models with 3M Tape
- 2.0 LSJ Engine "How to" Install COMP/ZZP S1 Cams, Supertech 75# Valve Springs, & GMR Cylinder Head
- Drivetrain How To: Replace Axle Boot
- Appearance V-LEDs V3 Triton Switchbacks Install
- Other/Misc How To: Make a Functional Spare Key for 9$
- Electrical How To Aftermarket Fog Lights Use OEM Fog Light Switch
- Interior hide away buttons for under steering wheel compartment
- All Engines How To: Remove Fuse Box
- Wheels/Tires How to Reset TPMS - if you dont have your manual
- All Engines HOW TO FIX: P0010-P0015, P0100-P0104 CEL FIXES T/C light, hard shifts problem
- 2.0 LSJ Engine how to: replace thermostat(with pics)
- 2.0 LNF Engine ZZP's ZFR Turbo Installion
- Electrical All electrical related how tos (includes gauges)
- Interior All interior related how tos (includes speakers and radio)
- Appearance All exterior appearance related how-to threads (includes headlights)
- All Engines How To K04 Install
- Drivetrain disassembly f35/mu3 transmission
- Appearance How-To: Install Reverse HID Kit
- Interior VIDEO How-To Pop Out Steering Wheel Airbag
- Appearance How To : Headlight Removal and HID Install (pics!!!)
- 2.0 LSJ Engine How To: Push down the Tensioner if you stripped the nub
- 2.0 LSJ Suspension 10 Minute Spring/strut/shock Swap without a sprig compressor
- Appearance HOW TO: Mini H1 Retro install
- Other/Misc How-To: Contact GM if dealerships fail to help
- All Engines Trifecta EzFlash Operation on Mac OS Machine via Parallels
- Other/Misc How to: Make a milkshake
- All Engines Blower motor instal procedure
- All Engines Door Fix
- Electrical How To: Install a starter kill relay
- Appearance Reverse light delete/All red lights
- Appearance Replacing dull sandblasted stock fog lights with new hotness.
- Appearance How To: FXR Headlight Retrofits [Noob Guide with Pics]
- Interior How to install double din mounting kit properly
- Appearance How to shave trunk lid wing and lock holes
- Appearance How-To: Custom LED Tail Light Retrofit
- Electrical How To: Reset Speedometer/Tach needles
- Interior How To: Wood Backed Trunk Liner (Solid Base Trunk)
- Interior How to relocate usb port on factory Headunit 08+ Cobalt
- Drivetrain HOW TO Replace Shift Linkage Bracket
- General Suspension All suspension/brake related how to threads
- 2.0 LSJ Engine How to install Injen Hydroshield
- 2.0 LNF Engine How to test and Replace Evap Solenoid
- 2.0 LSJ Engine How To Change Timing Chain Tensioner
- Appearance How-To: Wire Up Bi-Xenon HIDs
- Appearance How-To: Install Switchback LEDs W/ Resisters
- 2.2 LAP Engine How to Seafoam a LAP 2.2L
- 2.0 LNF Engine How to intall oil pressure gauge sending unit, relocation from under turbo mod
- 2.0 LSJ Engine How to Log AFR Using A/C Pressure (Big Pictures)
- Other/Misc How to: Install Aftermarket Speakers Using Stock Speakers
- 2.0 LSJ Engine "How to" Install Dual Pass Endplate w/o Removing Your Alternator
- Exhaust Putting Back On Stock. Question
- 2.4 LE5 Engine How-to Seafoam/Remove the intake cover 2.4L
- Interior How to install IRL Recaros in a Cobalt
- 2.0 LNF Engine How to get women, $, and strength while fixing your breather hose!
- Other/Misc Adding the Boost Parameter to Your Dashdaq
- 2.0 LNF Engine How To: BNR turbo swap
- Electrical How-to: Replace trunk release button in the dash
- Appearance How-To: Install LED Taillights W/ Resisters (Coupe)
- Drivetrain How To: Clutch Job on Cobalt SS
- Drivetrain Chevrolet Cobalt SS Short Shifter Install DIY
- General Suspension How to install SS/SC front sway bar,Moog endlinks,and spacers on LS. With pics
- Interior Shift Knob Threaded Insert Install DIY
- All Engines How to: Trifecta Tune
- Appearance 3rd Gen Projectors Install with HID kit, halo's, and LED's
- Appearance HOW TO: Installing HID Fog Lights
- All Engines How To: Drain The Tank
- Other/Misc How to : Bed-In Your New Brakes
- 2.0 LNF Engine How To: Install GM Stage 1 LNF Kit (GMS1)
- 2.0 LNF Engine How To: Seafoam (VIDEO)
- Detailing How to: detail your car
- Electrical How To: Add Heat with no HVAC
- Appearance How To De-Badge the Right Way
- Electrical How to Replace Blower Motor Resistor (Get Back Fan 1-3)
- Appearance Remove front license plate bracket
- Electrical How To Hard-wire an Accesory to Turn on With Car
- Interior How To: Replace a turn signal switch
- 2.0 LNF Engine How to install Turbo XS intercooler pipes
- Detailing Wash an engine bay
- 2.0 LNF Engine How to install Turbo XS cold air intake!
- Interior Front Speaker Tutorial w/Pics!
- All Engines How to: Make a perfect 50/50 meth mix
- Appearance How To Remove Headlight (PICS)
- Appearance How To: Change interior to LED. *UPDATED INFO*
- Interior How To: Winterizing Floorboard
- 2.2 LAP Engine N2MB LAP Installation Instructions
- Appearance How to: Glowing interior trim. (long read, pics)
- Interior seat belt
- 2.2 L61 Engine How To: 2.4 Intake Manifold Swap on 2.2
- 2.0 LNF Engine O2 Sensor Replacement Bank 1
- Appearance How To Install 3 Piece RK Sport Wing W/o Drilling holes
- All Engines Sea foam (CORRECT HOW TO)
- Appearance How to: Antenna shave!!
- Interior How To: Make a Dual Gauge Cluster Bezel
- Interior How To: Install a Double-DIN Aftermarket Headunit in your 05-06 Cobalt SS
- 2.0 LNF Engine Removing Stock Airbox
- Detailing How to: Clay bar your car
- Drivetrain How To Rebuild a Turbo (Garrett)
- Appearance Change Headlight Bulbs in Cobalt/G5 Video
- General Suspension How-To Replace Rear Shocks
- 2.0 LNF Engine How To - Add the analogue boost gauge on a factory RPD car
- 2.0 LNF Engine (MPx) ModernPerformance FULL Exhaust Install and Stock Removal
- Appearance How To: Make your own removable license plate mount
- Other/Misc Post pictures on CSS.net
- Appearance Dual projector Gen 4 headlights
- 2.0 LSJ Engine Install Fuel Pressure Sensor. Mechanical Only
- Interior Install Subs and Amp without splicing existing wires
- Appearance How To: Color Matched Headlight "Eyelids"
- Exhaust Quick Question (Noob)
- Electrical glowshift questions
- Interior How to change cabin air filter
- 2.0 LNF Suspension R1 Concept front brake install
- 2.0 LNF Suspension R1 Concepts rear brakes install
- Appearance How To: Custom 3rd Brakelight Vinyl [56k Warning]
- Interior How To Install An Auto Dim Rear–view Mirror
- 2.2 L61 Engine How to install a vacuum gauge (2.2L or 2.4L)
- 2.0 LNF Engine LNF Evap Vent Valve
- All Engines Valve Cover- Removal and Installation.
- All Engines How to: Replace your Radiator
- Other/Misc 2009 Cobalt lt upgrade
- Interior 194 Ebay LED Load Resistors.
- Other/Misc How To: Add Pictures in your Forum Posts
- Drivetrain TWM Cable Clamp Install
- Other/Misc Retrofit Heated Mirrors **(56k Run Away)**
- Exhaust LNF: Installing Bad-Mab Catless downpipe
- Other/Misc How to format USB drive on a MAC for radio compatibility
- All Engines J-body.org: Balance Shaft Delete Install
- Appearance How to : Door moldings removal!
- Appearance How to: Pinstriped wheels
- Appearance How to/Review: Plasti-Dip Evo Mod (Lots of Photos)
- 2.0 LNF Engine How To: Remove SS/TC bumper and install MPx Intercooler
- All Engines Collision Tech Repai Info
- Appearance gen 3 wiring, need help
- Wheels/Tires How-To Outsmart your Tire Pressure Monitoring System
- General Suspension How To change Control Arm Bushings
- 2.0 LNF Engine Boost leak test a stock SS LNF.
- Electrical How To Replace Your Reverse Light Switch MU3
- Appearance How-To Install a Hide-A-Plate
- 2.0 LSJ Engine "How To" Install OTTP's 4th Gen Heat Exchanger w/o Removing the Bumper
- Interior How To: Change Your Speedometer/Gauge Cluster
- Appearance Halo Projector Install Guide
- Electrical How to install LED brake / turn load resistors
- Electrical Installing the FIC6
- 2.0 LSJ Engine HOW TO: OTTP Longtube Header
- Appearance how to: tint your tail lights the pro's way
- General Suspension how to change your front wheel bearing
- Other/Misc How To: Install Custom Vehicles On Garmin GPS
- Appearance How To: Paint Brake Calipers
- Electrical HOW TO: Install LED's on your center console (PICS!!!)
- Appearance How To Install Billet Grilles
- Drivetrain How to release shifter cable latches
- 2.0 LNF Engine Intake Fixes
- Appearance how to: paint stock headlights
- 2.0 LNF Engine How to install Injen intercooler piping
- Appearance Make HALO LED Replacement bulbs.
- Other/Misc How-To: Install a rear tow hook
- General Suspension Pressure Bleeding
- 2.0 LSJ Suspension How To: Rebuild Front SS/SC Brake Calipers
- Interior How to change cluster, HVAC control, window and door lock to LED
- Appearance How To: Install new quarter window
- How To Change HVAC Light Color
- Exhaust How-To: Installing HIDs W/ Relay Harness
- Appearance How-To: Install HID Foglights
- Appearance How To: Remove Front Mudflaps
- Drivetrain HOW TO: Rack and Pinion Removal/Installation
- 2.0 LSJ Engine how to-timing chain tensioner
- How To: Install PowerGrid Inc. adjustable swaybar endlinks from OTTP
- Appearance 3rd Brake Light LED
- Other/Misc How To: Fix your unresponsive Keyless Entry Remote
- Interior how to remove air bag sensors in a 07 ion redline & 07 cobalts
- Appearance custom third break light..
- Appearance How To Make Your Blinker and Parking Light Flash Together and Stop LED Fast Flash
- 2.0 LSJ Engine how to Rebuild IC pump
- Interior How to replace the Ebrake assembly in a SS/SC
- Turbo Tech Racing STOP Transmission Mounts Install Instructions.
- Interior How to Upholster your A Pillar
- 2.0 LSJ Engine HOW TO: DIY Dual Pass Endplate (pics inside)
- General Suspension FE1 poly cab install
- Electrical How To: Key Stuck In The Ignition Fix
- General Suspension How to build your own traction Bars
- 2.0 LNF Engine How to make a boost leak tester
- General Suspension How-To: Sway bar bushing replacement
