Official TVS Thread!!!
Old Feb 2, 2014 | 03:46 AM
  #8151
SPDDMN36's Avatar
Some of it is the work and some of it is wanting to try OTTP cams. Im still up in the air about it.
Old Feb 2, 2014 | 03:44 PM
  #8152
mrbelvedere's Avatar
their biggest cam is close to what I run
Old Feb 2, 2014 | 04:33 PM
  #8153
SPDDMN36's Avatar
And we had discussed it being a good way to go. I think ill toss em up for sale soon.
Old Feb 3, 2014 | 12:21 PM
  #8154
Mendomar06's Avatar
Random question, what is the normal coolant temperature on our LSJs? Mine never goes above 180* but its consistently at 176* someone was saying that was too cold and that the thermostat might be going bad? Am I concerned for no reason?
Old Feb 3, 2014 | 12:29 PM
  #8155
Hockeyman's Avatar
Perfectly normal temps
Old Feb 3, 2014 | 12:38 PM
  #8156
Mendomar06's Avatar
I figured, I just wanted to make sure though. Thanks.
Old Feb 3, 2014 | 12:46 PM
  #8157
Staged07SS's Avatar
Administrator
Administrator
Yeah, at the top of 3rd, I'm usually in the 140 degree range as well.
Perfectly normal.
Edit: I thought you were talking about IAT2's. My coolant temps are the same as yours though. 176-180.
They have been that way since the day I picked her up new.
Old Feb 3, 2014 | 12:52 PM
  #8158
Mendomar06's Avatar
Thanks Staged. That's a relief, I don't have the time to tear into it right now.
Old Feb 3, 2014 | 12:55 PM
  #8159
rico's Avatar
My thermostat has to be bad my redline won't warn up lately past 120 sometimes just up to 150
It's been cool here lately but still no reason for it not to warm up completely right ?
Old Feb 3, 2014 | 01:05 PM
  #8160
BlackielawlessSS's Avatar
Mine runs around 176-180.
Old Feb 3, 2014 | 01:17 PM
  #8161
Mendomar06's Avatar
It could be Rico, maybe try driving it a longer distance?
Old Feb 3, 2014 | 04:25 PM
  #8162
armcclure's Avatar
I had to replace mine. When the seal goes bad, there's up to 8 1/8" holes for Copland to go through. Mine wouldn't go over 130 while driving.
Old Feb 3, 2014 | 04:41 PM
  #8163
100% METH's Avatar
5th injector installed
currently running a .035" fuel jet (a tad excessive); ordered a .015" yesterday
Old Feb 3, 2014 | 04:45 PM
  #8164
Hockeyman's Avatar
That is awesome, Flit.
Old Feb 3, 2014 | 05:09 PM
  #8165
rico's Avatar
I did lol and nada ordered one already so we will see
Probably my problem lol
Old Feb 3, 2014 | 05:35 PM
  #8166
RooTBeeR's Avatar
The rubber seal goes bad on them and then won't warm up.
Mine when bad in NY in winter. Never warmed up past 140°
Old Feb 3, 2014 | 05:36 PM
  #8167
RooTBeeR's Avatar
Hope you got a smog guy lol
Old Feb 3, 2014 | 06:28 PM
  #8168
100% METH's Avatar
My car is stock
I have nothing to worry about as far as th state is concerned
Old Feb 3, 2014 | 06:46 PM
  #8169
you should have mounted the jet in front of the throttle plate
Old Feb 3, 2014 | 07:53 PM
  #8170
ThexGovenor's Avatar
looks good!
Old Feb 4, 2014 | 03:49 PM
  #8171
zrated89's Avatar
get the 5th inj from zzp?
Old Feb 4, 2014 | 04:41 PM
  #8172
armcclure's Avatar
No. They homebrewed it. Zzp's is an actual injector and maf based controller.
Old Feb 6, 2014 | 07:17 AM
  #8173
Staged07SS's Avatar
Administrator
Administrator
Steve, is this controlled like a nitrous system?
The reason I ask is, I wonder if I can run a similar setup, and use my nitrous setup within the GMR S3 PCM to have the injector spray to provide more fuel.
Old Feb 6, 2014 | 09:38 AM
  #8174
RooTBeeR's Avatar
GMS3 only triggers with WOT switch, right? Its not boost referenced?
Old Feb 6, 2014 | 09:57 AM
  #8175
armcclure's Avatar
It's basically the exact same as tuning a large meth shot on a boost switch.
