View Full Version : Tuning
Pages :
2]
- Modification Help
- Tune Near Findlay Ohio
- tuner in washington?
- Tune questions. Pros and cons. ZZP vs Trifecta vs HP tuners?!
- 2007 LE5 Idle with or without AC\Heat ON
- Looking for some reference logs from a lightly modified (or stock) car
- Tune Question
- wanna learn how to tune.
- cleveland,oh- tune
- Looking for a tuner! Willing to drive to location!
- Zzp 1.0 pcm
- LNF K04 Forge VTA Tune Requirements
- 2 step and NLS
- Tuner needed in Spartanburg, SC
- tuner needed around Boston, MA area
- tuner in ohio
- Need a HPT LNF Config ASAP
- ZZP Hp tuners
- hpt tuner needed in peoria il area please help
- stage 2 updated tune
- cobalt
- Exhauast and tune question?
- Wideband Readings on LSJ Cobalt
- Tuning in Houston
- Lsj hp tuner
- Tuning and turning on performance mode
- Tuning LNF michigan anyone?
- HPtuners Cam Phasing Help
- stock lnf tune
- Tuner needed in Ottawa, Canada
- 2.2 base tune
- Tune halp
- HPTuners halp
- HPTuners question
- Need a Tune In NJ Area
- Different PCMs for different fuels?
- Need tuned near cleveland
- Wot-tuning or BNR
- Tuning LSJ with this Combo?
- 2.2l L61 Need tuned
- Need tuning. near or in wv
- TVS/E85 tune
- le5 supercharged tuning
- tuning question
- NEED to be tuned near dallas!!!
- cobalt 2.4 tuning
- HP Tuner n00b.. Please help
- Need help with tuning, to hell with Trifecta
- Music while scanning
- le5 na tuner in the La area, cali..
- Trifecta question.
- HPTuners experts chime in please...
- HP Tuners while key is stuck?
- tuning opinions
- Tuning steps
- Need tuned near Detroit.
- Looking for tuner in western Wisconsin
- 2008 coballt tuning questions
- looking for a tuner in Northern Alabama or Southern Tennessee
- Trifecta tune reaches rev limiter at 4k rpms?
- Tuning starting point
- How to use the AEM Uego Wideband
- Tuning
- Why does altitude affect transmission shifting? (Mine skips 2nd at WOT)
- lsj timing
- Finding out fuel rail pressure for tuning injectors
- Important Question
- Tuned by Terminator
- Can I see if my 08 SS was tuned if I have the red trifecta cable?
- need a tuner in ny
- Trifecta Tune
- LE5 misfire issue
- How to tell if dealer flashed hp tuned car back to stock?
- Fayetteville Tuner.
- Looking for a tuner around indianapolis
- Helpful tools for those tuning E85 and blends
- 2.2 supercharged
- Taking my car to walmart, Is it possible to adjust the rev limiter?
- What happened to Trifecta?
- E85 Conversion
- looking to get 09 lt sedan tuned in ohio
- 2.4 N/A soon to be supercharged... hopefully
- custom tunes for 06 2.4l
- Who can tune LNFs really well in DE, MD, PA, NJ area?
- Stage 2 maybe need help
- Wanting a stage 2 tune dont know how
- cobalt ss tune, e85 or 93?
- Looking for a tuner in Eastern Illinois (Kane County, McHenery County)
- HP Tuners in Colorado
- HP Tuner in Colorado
- Torque PID scan
- Tuning A/C timing? E37 ECM
- trans ?
- Need help with a basemap
- Tune ordered(trifecta) 2nd guessing??
- need advice with throttle body scaling
- Learn down after hp tune
- Downpipe Tuning Question
- Zzp Tune or OTTP Tune or trifecta? LSJ
- Tuner needed milwaukee, wi
- Help logging air fuel ratio using HP tuners standard
- need tune in CNY
- hp tuners
- tune causing wastegate not to open after 24PSI
- lean and rich caused by evap?
- Need help richening up my lsj
- Need a turner in oc california
- who can tune in Indiana
- HP Tune
- Jax FL hptuner
- Looking for a tuner in central Illinois
- Need a SC tuner
- Tuner needed western MA
- need tuner in NJ HELP
- GM stage 2 vci number?
- Trifecta tuning still in business?
- Looking for a new tuner
- How the tuner knows reached the limit ?
- Weird fuel trims and AFR's
- Negative advance at idle / jumpy idle
- My CSS "I am n00b tuner" Help Me Thread
- gmstg1 sensors for hpt
- tuners in houston.
- tuning
- Tuners in WA state?
- aem ems 4 calibrations
- looking for so cal Tuner
- VE Table.
- will this. laptop work for hptuners
- 09 ls tune?
- Boost issue....
- LSJ E85, VE changes question
- HPT / Trifecta Help
- could this work?
- What Rough Startup Idle with stock LNF PCM - to adjust with HP Tuners?
- Let's Talk About Timing Advance
- Need tuner in Indy for relearn
- 2.2 SC needs a tune
- will be in need of HPT, anybody local?
- How to HP tune my LSJ
- HP Tuners
- Tuning and State Inspections
- ZZP Tunes?
- Help With Wideband and HPT
- New tuning program for LSJ's. Need some help though
- Viewing a Trifecta Log File
- New to tunning
- trifecta
- New to Hp Tuners-turbo lsj-pointers
- LSJ e85 Kr with someone conservative timing
- first time tuning-made some changes- experienced tuners willing to offer advice?
- E-85 Cold Start Correction (INFORMATIONAL)
- tuner in dmv area
- will GM1 tune support upper charge pipe?
- tuning problem
- Need Info
- Tuning? for trifecta
- LNF tuner near Oklahoma City
- How to tell if tuned after used cobalt purchase
- 80lb Injector LSJ question
- Any tuners in las vegas
- Need a tuner in the hampton roads area of va for 07 ss/sc
- long island new york
- Tuning a Turbo LSJ-mistakes
- trifecta vs gm tune???
- In Need of A Tuner !
- LSJ Scanner Config files
- Tune after CAI, DP, and Catback
- LNF Kr question
- Just Got HP check out my log file.
- Looking for a GMS1 file for a 07 Solstice GXP
- how to properly prevent p0420 from coming up?
- Looking for a trifecta tuner in Cincinnati,Dayton, or Columbus Ohio area
- tunning
- 2.4 VVT Tuning...overlapping maps from HHR/Solstice/Cobalt?
- tunning
- lsj maf sensor
- Tuner in MD?
- Injector basics for LSJ
- Anybody with HPtuners in the Washington Area?
- Tuning with Elevation differences
- trifecta help! car wont start or load!
- Looking for a knowledgable tuner for 1000 ID injectors
- GSM1 Question
- short throw
- Looking for a Tuner in Northern Alabama Huntsville area
- Turbo LSJ Tuner
- recommendations from tuning experts, 2.4 NA auto (HPTUNERS)
- Help, turbo LE5 idle
- HP Tuners Software
- Would a dealer tune sufice??
- Tuning for St.Louis, MO and surrounding areas
- Tuner Needed in Tampa
- trifetca cable
- lucas #79 help
- where to get my car tuned?
- SS ECU questions
- Tuner - Chicagoland area
- zzp stage 2 custom tune?
- What is wrong with this tune!
- in need of some tuning in WI area
- Tuning in the Central, KY area?
- Some tuning vocabulary
- tune or not...help?
- Stock fuel system.
- P0300 - misfire on E85 LE5
- 93 octane ?
- Need a new tuner!
- Trifecta Tune Help
- New owner, does this car need tuned?
- Looking for a tuner near Pittsburgh
- New to cobalt ss turbo tuning.
- When should one tune their car?
- do i need a new tune?
- Tuner Close to Palm Coast, FL (Jax, Daytona)
- Review on a tune from 09cobaltss1
- Mid-Atlantic Tuner/Shop Recommendation
- Got Retuned AcesNEights!
- Domin8tuned, Pittsburgh area
- tuner in md?
- cheapest tune
- Need Tuner IL/WI area, anyone know shaun?
- Beware of James Rakes Tunes...
- ZFR Tune
- Tuner needed!
- pre-tune check list
- Initializing error unable to create log
- Who want to go to Tuning School with me in Dallas? July 13-14
- Needing a 2.4 HP tune...
- E85 Sourcery - Testing E85 for ethanol content
- How does tuning work exactly?
- E47 Tune ECM Swap
- 32 PSI, tune question, VCM scan inside
- local tuner or cobalt tuner?
- Tuning for motor swap, hptuners vs efi live vs dealership/mail
- Want to learn to tune using HPT for 2.2SC
- New Tuning Cable?
- HP Tuner Chronicles: Tuning your L61/LAP/LE5 for better throttle response (pics/vids)
- Have Trifecta wanna go HPT
- 2.4 turbo VVT Hptuners: Do i need a re-tune to lower boost?
- Trifecta question
- Unable to read 09 Cobalt SS TC PCM with HP Tuners
- DIY tuning options for LNF / 09 SS/TC?
- Hptuners help with base tune
- Untuned with bolt ons
- HPTune - 2.4L
- Starting out base tune with GMS1 differences using HP Tuner?
- Tuning Opinions
