- Help!
- 2007 Cobalt 2.4 SS Speaker Issue
- NGK Spark Plugs
- Clutch master cylinder ?s
- ZZP Long tube header package
- ZZP DownPipe
- 4'' crack in my exhaust manifold? Wtf!
- What are you running for exhaust (with high flow cat)
- Fixing 2nd gear synchro
- which size headers would be best for le5
- Coolant Sensor Cable/Connector
- Bog In My 2.4
- Blown 2.4 with high mileage?
- Grinding the plastic Intake Manifold?
- zzp lsj throttle body for le5
- turbo on the 2.4 ss 5spd
- how much HP on these 2.4's?
- advice on my plan build.
- Cobalt Le5 Gas Octane Requirment??
- can someone help me out on picking out the best setup/combo
- Update time!
- Gas??? 93 or 95 octane
- Short Throw Options
- Engine Mod Questions
- Borla or Corsa Touring?
- Injen CAI
- Motor went finally
- the WHP
- would this turbo work on my 2.4? and what else do i need?
- Few questions with putting turbo on 2.4
- Unreasonable to pay...
- Injen Cold Air Intake
- Recommended Maintenance schedule for...
- Tuning/Chip
- should I upgrade exhaust
- would like some help
- I wanna become the hottest 2.4 in my area
- Belt sizing for 2.4s with SC's.
- Need help with exaust!!!
- header?
- header downpipe questions (confused)
- zzp turbo kit?
- My Exhaust
- Engine Life!! Please LOOK!
- Does anyone here even have a legit built 2.4? like with over 500 hp?
- new motor
- Performance Parts TBD
- GMPP Intake Filter Size
- Custom Exhaust
- 70%(water)/30%(methanol) mixture question
- Huntington Beach C.A ?s
- Free flow cat question?
- Stock tune
- Projector Headlights
- a deep tone exhaust?
- 08 2.4 boosted cars enter!
- Help! im new to site and have some ?s
- trying to push 20lbs on my 2.4
- Aem Dry Flow replacement filter for a 2.4
- putting a stock ss/tc on 2.4
- is this the gmpp manifold?
- intake manifold single pass
- zzp turbo ?
- What Should i get Turbo or Super *Im Alittle bit new
- Built 2.4?
- New TTR Ecotec Intake Manifold
- would i need to tune?
- Exhaust Set-up
- 2.4 roll pin
- Engine Power Reduced/Engine Disabled Code
- ZZP Turbocharger?
- Struts swaybars shocks? to compliment my new h&r race springs on my 2.4
- How much boost
- Stock Bottom End Rev Limit?
- Le5 Rods
- Tsudo exhaust
- supercharged
- 2.4 Manuel Tranny questions..
- 1000cc injectors
- Trifecta tune
- noob to track...just some questions....
- Help choosing magnaflow muffler
- Need Some Help with springs
- SS2.4 or LS1 TA
- Which Pulley Should I Get
- ZZP clutch !!!
- Lowering compression
- my engine has pressure under the valve cover??
- boosted 2.4 guys.....How much
- help for a new throttle body?
- will a 2.4 fit in the 2.2 bay
- 2.4 supercharged guys
- Whats the Best HID Color?
- supercharger kit
- im looking for a decent turbo kit
- Whats the best Strut Bar
- is this good at all idk??
- How many miles on your 2.4 ss?
- Help meee
- best weld-in muffler?
- dont know what to do next
- defouler help
- Winter plans
- need help asap
- Will The Hahn 3" Catback Work with the 2.4 N/A Engine?
- I need to know whats best for lowering my car.
- HIDs and automatic lights
- what size is inlet to stock SS/NA exhaust tip?
- Need some car help
- ZZP supercharger kit
- Eibach Pro springs..will I see any difference?
- need some help
- help with turbo build
- HIDs stopped working II: DRLs
- Stock Head Gasket Thickness???
- I want to go turboed
- CEL's! whoo hoo!
- Post SS/NA pics
- annoying serpentine belt
- radiator bent
- 2.4 ecu for turbo users
- havent been in here in a while. couple questions
- CobaltSS.net's 2010 Holiday Charity Drive!
- P1174 and other issues
- Need Exaust Help
- Need Exaust Help (New to Cobalt SS.net)
- Meth Injection on a N/A car
- Opinion on iat readings
- Just installed OBX Headers and Down pipe is this normal?
- Whats a good Tune In Colorado?
- 2.4/sc troubleshooting help
- TTR Mounts
- Valve Cover Gasket
- crazy idea.. boost + boost lol
- going back for some new goals
- LE5 connecting rods - PLEASE READ
- 2.4l throttle body
- 2.4 sc build plan layout and questions
- HP Tuning
- Low tone exhaust
- sc problems
- high flow cat help
- Traction Control light on
- ECU reset?
- bigger throttle body?
- What to do next?!?1?
- OBX Header
- the time has finally come
- intake question! and yes I googled it!
- Got a question about the balt? looking for some ideas.
- ZZP cams for LE5?
- boost leak? 2.4/sc
- 30,000 mile Maintenance ??'s
- infamous high idle after throttle clean possible fix
- Freshly installed ZZP SC Kit, cranks but won't fire
- Those with Tsudo catback, enter!!!!
- help! bad start up after intake install....
- Question about the 2006 2.4 cobalt ss natural asperated
- Check engine light came on :-/
- Coil on plug questions
- Thinking of buying a Tsudo catback.. But I'm not 100%..
- Hardened Oil Pump Gears
- Headers????????????
- Spark Plugs & Injectors?
- 2.4 with Tsudo N1?
- need pics of 18's on a stock ride height 2.4
- JET Chip..??
- 2.4/sc ?'s
- Performance chip a good idea?
- car running funny
- Tuning VVT?
- Turbo 2.4 dynoing this Sat
- Delco Iridums.. Or..??
- Header/DP Question
- Other Weld-In Mufflers??
- what order to mod?
- ZZP Intake..??
- ZZP s/c or t/c kit..??
- Budget SRS Catback.. Anyone..??
- MSD DashHawk discontinued
- Did i just lower performance?!
- Voltage Stabilizer
- guys i need ur help!
- P37 PCM Pin Out???
- turbo spark gap?
- TVS 2.4 Ion Build
- looking for a tuner
- Not happy with dyno results
- engine swap, now car wont crank over
- MAP wiring?????? HELP!!!!
- wanting to go catless
- whats up guys
- What to write down before battery pull??
- Computer brain fart on abrupt stall?
- what is required to change to e85?
- 4k rev limit parked
- Help fitting a CA Header
- intake vs exhaust
- 2.4 Badge
- ZZP water to air setup ?????
- dyno ?s
- update
- is this a good exhaust
- ZZP Stage 2 Turbo Kit?
- Will buy a Eaton m62 supercharger
- wheel bearing
- Injector Question
- need clutch
- 2.4 L tb portin
- 2.4 tuning ?'s
- auto tranny maintainance?
- 2.4T dyno and numbers
- help..car shifts funny t/c light on
- ZZP 2.4L turbo 0-80mph
- Coolant Sensor
- original fuel injector part number
- Any other SC 2.4 Sedans out there!?!?
- What all do I need
- Xander's 2.4 SC build
- multiple codes
- 2.4l Turbo
- Question about P0010
- just thinking out loud
- how much psi?
- 2.4 ss 1/4 time slips
- High Idle Issues + Fuel Trim Issues
- oil pressure gauge question ??
- flex pipe
- b&m shiftplus
- My Car has a Virus...
- Do i need a wideband?
- Throttle Response
- DI possible?
- E85
- Oil pressure sensor location ?
- Very important Fuel smell
- Transmission?
- Maf screws
- performance chip....
- CAI vs RAI
- Ecotec OBX SS Header, what do you think?
- question before I take it to the stealership
- LSJ Throttlebody ?
- Weird Noise at 3k
- Escaping air sound on acceleration.
- Jdm turbo
- who make's 2.4 auto engine and trany mounts
- Lots of codes - where do we begin?
