- wiring :(
- How to install a dual stage boost controller?
- OLM and Limp mode question.
- Can anyone recommend an air filter?
- What color should I paint my Brembos?
- Replacing Exhaust Tip???
- Key fob issue
- Who is running wheel spacers??
- Plans for my balt
- selling the cobalt, a couple questions
- The "How I officially f*****d my clutch" thread!
- downpipe.
- Mustang Owners....
- curiosity
- Transmission gear sound
- water leaking into car from apillar,throguh the air bag cap.HELP!!
- Possible BOV for our stock turbos ? Anyone interested?
- Aftermarket Parts
- Where did everone buy their GM Stage 1 kit?
- Just bought a 2010 Cobalt SS!
- Driving with a CEL
- LNF Spare PCM question
- trifecta dealer kit
- Going to the track!
- competitive mode
- Do I need a camber kit?
- I need help!!!!
- Just bought an SS/TC! Couple questions...
- Tune
- My '09 Cobalt ss sedan
- Upgrades
- Door Emblems
- MPG display or throttle sticking?
- guys running e85
- BOV not hooked up
- ordered the hahn s20g !!!!!
- Did the rear brakes yesterday - at 26,1xx miles ...
- vacuum tank test
- p0303 question
- GMS1 question
- Taking out the DRL fuse.
- question for you Hahn DP guys
- Trifecta to HP Tuners
- I need your guys help/opinion
- cant decide hahn 20g vs precison turbo 5557
- Removing valve cover, what should i check?
- seat belt noise
- CAI Install question.
- Quarter-sized vent by Sunroof Switch?
- tires
- nonselectable trifecta :(
- Shifter frozen
- Need help, can i get some opinions?
- Zzp efr, question
- Question about side exit exhausts
- Tune
- What rpm should i reach full boost?
- trifecta tune
- Superchips vs GMS1
- running open downpipe will i loose power?
- Turbalt or SRT4?
- GMS1 and spark plugs?
- Is the cobalt right for me?
- Finally got my 09 turbocharged!
- tuner who never tuned a cobalt before
- Headlights & HID questions
- possibly water?
- Trying to find the previous owner of this cobalt..
- hp tune
- Tire question
- Changing oil too often will harm your engine
- How to spike 27-28 psi stock K04?
- Muffler delete??
- tune plus high miles
- synapse turbo kit
- E85 full tank or half and half with 91?
- Lowering springs
- Bolt on SS/TC vs full bolt on 3v 4.6 Mustang
- Need wastegate solenoid in Phoenix asap!!
- I think I am getting ripped off? Help ?
- My girl has an LNF, trying to make it quicker than my Vette.
- 5th injector anyone
- 87 Oct or 91oct
- Need info to install blackhousing headlights
- difference between a gms1 and just regular ssTC?
- hesitation going into gears at high rpm
- Stuttering
- upgraded exhaust ideas
- Who's replaced the heater hoses?
- Wingless swap the best?
- Tires
- Catless dp question
- I got called out! My 09TC vs 2012 V6 Camaro...Race set!
- stupid question
- Cobalt ss onstar module
- Help door stuck and latch screwed
- Not boosting over 3-5psi???
- Modern Performance
- eco fuel saver
- KY Clutch! What Flywheel?
- parking brake problem
- launch control
- nasa is coming to virginia international raceway.
- K&N typhoon installed!!!
- signs of wear / tear / abuse
- kms
- k&n
- 3" straight pipe + BNR2871 untuned.
- TWM install complete!
- lambda question
- Gas mileage
- turbo swapped car sounds wierd
- I'm deciding what to get....
- Bad wheel bearing already?!?!?
- Gas Type Question
- BNR installed! have a few ?'s
- anyone had to change O2 sensors cus too low?
- Turbo not spooling? P0236 & P0237
- Top speed for a Cobalt SS/TC 08 stage 1?
- Which engine support bar do you guys use?
- mpx
- What Mods Are On This Car?
- Battery Light?
- TWM STS Wont Fit?!
- Should I Consider This??
- Customize Interior
- dual exhaust kit for 09 cobalt tc
- DC Sports Strut bar
- How Does The Cobalt Look?
- New to this. Opinions on exhaust setups.
- Does Cobalt Seem Good?!
- 2010 Cobalt SS/TC Mods??
- Changed my spark plugs and...
- Brake squeal
- muffler swap
- 08 SS/TC coupe vs 09 Infiniti G37 base sedan
- oil in my intake
- Rip 08 srtc G85
- been thinking about some heated seats
- SS/TC... How does it compare?
- GMS1 before or after bolt ons
- BYT tune
- 2008-2010 SS brakes?
- Trifecta dissapearing tune... wtf?
- Aftermarket Wheels
- trifecta
- bike rack
- Removing that Pesky Valve Cover Hose - Catch Can Install
- Another BOV thread?!
- powder coating
- Boost gage
- wheels and tires
- doin brakes tomorrow couple of quick questions
- downpipe
- Winter Steelies
- help plz
- injen charge pipe
- D I have a panel missing?
- HID relay harness problems
- sputtering at idle!
- Me vs old 5.0
- new couplers for hahn charge pipes
- LNF tunes
- Head light and Fog light bulb sizes.
- GMS1 with bolt ons.
- Where to Lift?
- How do i know what stage my TC is?
- How many oxygen sensors?
- NGK Laser Iridium gapping question
- ac delco part# question
- Anyone wanna help me out here
- fuel?
- help please.
- custom tune vs reliability
- Regular or permium?
- Looking back at my 09 Cobalt SS (Review)
- R1 Concepts Ceramic pads
- my 09 ss/tc exhaust set up
- Possibly buying....
- Blow off valve installed cel light an no boost
- Plug Recommendation
- looking for some info
- aftermarket exhaust.
- cammed LNF
- 09ss rear brakes
- gas mileage dropped
- What clutch & tranny fluid do you use in the lnf ss?
- cobalt ss rims
- who can tune 09 cobalt ss turbocharged?
- Summer Tire Time? (NJ/NY/PA)
- bov vs forge bpv
- modern performance muffler delete
- Any Trifecta dealers in Birmingham here?
- Possible Idea
- Will i have to get retuned?
- Gas over flowing!!!! HALP
- forge BPV
- Trouble Codes
- How to adjust E-Brake
- Are dealers farmiliar with the GMS1 tune upgrade
- no boost in turbo 2008 ss
- Reputable shops to do a clutch job near Northeast Ohio??
- LNF Map/Maf Question
- HHR ecu?
- Wanted to clean MAF and found this
- Nurburgring Time
- leveling kit?
- O2 Wideband gauge?
- Exhaust Smells like Propane
- used parts prices. help needed
- Make a shopping list!
- Story of a ZZP Engine Swap
- something rattling in high boost
- Looking for some Cobalt SS LNF Pictures to use in our advertisment
- Clutch Slippage after Tune?
- Thoughts on Me vs. 98 Eclipse GSX
- Some vids of my HKS BOV
- cobalt ss/tc vs mazdaspeed3
- ported intake manifold
- guys with painted brembos..
- can anyone listen to music from there phone pluged into the USB port
- muffler delete
- front rotors
- Damn UPS Tjin DOWN!
- Clean mass air flow sensor 2009 SS
- Thanks to ccss3
- Boost Leak Test MPx
- Oil leak
- Fk You Clutch Master Cylinder...
- Direct Injection Question
- ran into a problem doing rear brake job
- Scion vs SS video.
- production numbers?
- do i need a tune?
- Looking into buying a SS/TC
- Which one???
- AWESOME CUSTOMER SERVICE - rant thread
- rpd gauge questions
- BAD-MAB down pipe?
- need 2nd opinion
- Am I missing something? Scion vs SS
- New Guy with a few questions
- HP tuner question
- SS/TC vs SRT8 Jeep
- Where to get SHORT RAM INTAKE???
- what tune?
- quick question
- Intake help
- Engine/TC noise
- Rear Disc Brake Caliper Tool
