- Painted stock wheels
- high idle?
- Boost problems please help
- 08-10 SS brakes (pt#3; rear calipers)
- 09 cobalt turbo clutch question
- Secondary o2 issues.
- Installed an oil pressure gauge
- Wondering if anyone can help (LNF idle issue)
- Cobalt Ss boost issues
- Clicking/rattle sound
- Questions About LHU swap
- Won’t start
- 2010 SS/TC Steering Knuckle
- 2009 shifter linkage upgrade
- 2009 HHR SS Turbo
- Cobalt LS Fuse Box Compatable with Cobalt SS?
- Time to move on or stick with it?
- rear wheel hub torque for cobalt TC
- Bought car with motor in trunk can it be powered up to check mileage
- Any tuners in Ontario?
- Unusual tool under carpet
- Least restrictive muffler SS/TC
- 2010 SS question
- Underboost condition
- GMPP Clutch and LUK Flywheel Install Question
- Low compression / High leak in cylinders. Help?
- Questions on LNF Flywheels
- Tpms sensor learn
- Picked up a 2009 LNF Cobalt, couple transmission questions
- a no-start issue
- OE - but not GM "brand" parts?
- help me find it please :)
- Intake PCV Valve Identification
- Intermittent Starts
- Any comparable coils to ZZP?
- O-Ring size for A/C condenser?
- clibbins
- Brembo banjo bolt copper washers???
- Could use some help diagnosing LNF not boosting
- What items should be addressed to have a Track ready 2010 Cobalt SS?
- Chasing C0035 HELP
- no crank no start 09 ss
- Ss
- LNF with Automatic Trans
- P Codes and Boost problems
- ISO: LNF clutch and fuel lobe
- Gasket Part #
- Suggested General Maintenance Items at 100K - 2010 Cobalt SS
- PCV from intake to valve cover
- Lnf stock block
- Air Amplifier Setup
- 09 Cobalt SS LNF Build
- Noise coming from passenger side of motor
- LNF 2.0 Standalone Wiring Harness Needed
- F35 Trans Linkage
- P0011/P0014/P0300 Nightmare
- 2nd new EVAP purge valve at almost 120k now
- 09 Cobalt SS/TC 2.0 Brembo kit
- Need help!!
- E85
- New LDK motor Blew!!!!
- How much power can I expect to make?
- ZZP Turbo Upgrade Kit
- F23 > F35... Swap time
- 08 cobalt ss low boost no codes
- OTTP 2022 nightmare
- Corvette Inspired Chin Spoiler.
- Calling all Z57 owners
- looking for stock SS turbo
- Another how rare is my car thread...
- More problems, such is life
- clutch
- No read on MAF or Turbo Boost
- 09 Cobalt SS Alternator
- Alcatera Steering Wheel Options
- Help with lambda/afr issue
- GM IPod Pal connector. Bluetooth music.
- 09 SS with unknown resonator
- Fuel Filter On LNF
- Type of oil on E85?
- Mid Tennessee Area Tuning???
- break-in or gearing?
- Rebuilding BW S200s Turbo.
- 2009 Cobalt ss shift pattern
- Strange Noise -VVT Solenoid
- Break-In Smoke
- ZZP Radiator Meet God.
- Tuning help
- New Setup
- Gm Stage 1 kit
- Multiple misfires with maf code rough idle on start**
- longtime lurker, how to post in For Sale?
- 09 ss/tc please help!!!
- New 09 SS Sedan owner
- F35 upper trans mount issue
- LSJ throwout bearing VS LNF throwout bearing
- TPMS program issue
- Advanced spark question
- Hard to get into 5th gear
- Smoke from exhaust on e85
- Matching Yellow Brakes And Struts.
- Compact Oil Cooler Installed
- Air/oil separator idea
- Reverse lockout in first
- Parking Brake Sleeve?
- Bizarre issue with AC system/engine power (09 TC)
- Ect sensor problem
- Used LNF Engine Prices
- What is all needed for zzp z57 kit
- Regal F40 adjustments in HPT
- proper vacuum tank delete
- Throw out bearing bolts
- Cams, NBS and KR
- Flywheel shot?
- Crazy New 08'
- Stupid question on this engine bay picture
- Loud rattling/pinging noise under load
- Turbo kit for a 06 cobalt ss 2.4
- How to tell if I have Aftermarket LSD
- Opening 5th gear and have lots of questions
- P0246 over and over 5lbs max boost
- Bad transmission mounts?
- Lnf random miss fires.
- need a new belt
- Maf not reading
- Bpv sticking. Time to replace
- Blown trans?
- P.S.A *Calling All GMPP/LUK LFW285 Flywheel Users!*
- A "no problem" post
- Another P0010 Conundrum
- P0101 persists
- Downpipe Destruction
- Looking for a Dyno tuner in Michigan
- Lnf for $500?
- LNF Valve Cover Seepage
- Where to buy BPV?
- Trifecta Tuning Ottawa
- build
- P2261 sticking bypass valve(Stock bpv)
- Question about RPD gauge/COBALT SS TC!
- I have a stupid question to ask
- Clutch noise
- Full E85
- LNF w/57k miles going in my swap project. Maintenance to do before fitting it?
- Lnf stock rotors
- K04r turbo
- 27psi on S256?
- Clutches
- LNF Build starts Tuesday
- Porous block????
- 2010 SS build
- Car revving in neutral by itself
- Turbosmart IWG
- Valve Cover Breather Elbow
- LNF compression test numbers
- LNF axles
- Help identifying this ring
- Intake Manifold
- 08 SS is not boosting right
- Untuned 2 step hurting car/turbo?
- On the fence here- 09 LNF sedan sell or start to mod???
- ZZP Downpipe Shaking/Rattling
- Should I buy it?
- Intake Temp ?
- Anti Boost Lost Between Shift Ideas.
- HPT Tuners
- 09 lnf swap for an 05 lsj HELP
- Hose Attachment For Valve Cleaning/Blasting
- LNF going into limp mode
- Passenger side oil leak behind engine
- Valve Coking
- Convert Injen CAI to a Short Ram
- If you ever need to rebuild your Brembos...
- Opel HP Direct Inject Fuel Injectors
- air oil separator/ttr manifold/big turbo help
- CRC Turbo And Intake Valve Cleaner aerosol.
- Passenger Rear clunk
- 08 ss e47 upgrades?
- Clutch pipe / TOB HEADACHE
- Anti thefit light while driving, car still starts
- 350/350
- Ok, a bit unique question about the intermediate shaft
- Extra plug in headlamp harness
- Here's An Idea To Cool Your Engine Bay.
- Powell Oil Separator
- 08 hhr been sitting 7 years
- 8 years on these plugs
- Possible to replace just Wastegate Actuator?
- Manual lnf transmission fluid change, yea or na?
- K&N Air Filter Mod.
- Has anyone run hard for long without issue?
- LNF Axle Shortage Solution?
- Brembo brake misery
- Additional Cooling Fans.
- Latest consensus, Seafoam is ok for upper intake?
- Protecting new IC
- Front end all 8 up, help me diagnose
- 02 sensor Problems
- Finally upgrading my suspension
- Hope you guys can help me!
- E47/ clutch upgrade opinions wanted
- Stock clutch/ e47 dyno tune question
- Gen 4 Projectors
- Eibach anti roll bars
- Looking into buying one and wanted advice
- 2009 cobalt ss turbo pcm problems?
- low to no boost
- did anyone save the information or pictures...
- forged vented bpv
- Looking for Lnf mods
- Starter problems
- Clutch
- Check engine light ldk/f40 swap
- tpms troubles
- Haven't been on since 2015. Thinking about coming back to the Cobalt SS world
- 08 SS TC having weird CELs
- 09 cobalt ss trim kit
- maf tuning
- locked pcm
- LNF Rear Hub Information
- Boost/tune question
- Boost HELP
- Turbo upgrade
- Stripped bpv bolt
- So I Swapped the timing chain .... Buttttt 😲
- engine alignment after motor replacement, alignment problems?
- Check valve in line from engine to expansion tank
- 09 Cobalt SS questions
- The TRUTH about "learn down" feature
- Brakes squeak bad
- Part out 2009 cobalt ss !
- LDK/LHU knock problems STILL
- The right downpipe for LNF cobalt??
- Downpipes
- only 17 psi
- Possible Leak
- Does anybody regret getting an F40?
- Bad Pic of downpipe can you see what it is?
- Best gear option for ss/tc
- AC delete question
- Exhaust question for 2010 ss
- New owner and huge thanks!
- muffler recommendations?
- straightpipe w/ resonater
- Compression test and used oil analysis
- LSJ rear brakes on LNF ??
- Should I get this 2010 cobalt ss?
