PDA
View Full Version : 08-10 SS Turbocharged General Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. 2010 SS TC Bolt-on suggestions
  2. better intake
  3. Installed Shift Light, Not Working Still. Need Help
  4. AEM Intake vid
  5. Oh Hai! look at what I did!
  6. Alright Guys How Bad Do You Think I Did?
  7. GMS1 Oil Change Intervals
  8. Airb Box Mod
  9. Sparkage!!!!!
  10. A/C Refrigerant Pressure Sensor replacement
  11. Warm weather = Sluggish Car
  12. Do urethane bushings make noise?
  13. for you bov guys....
  14. Acceleration Issues
  15. Upgrades that won't void our warranty
  16. Aeroforce Vs Dashdaq:Sedan Pillar Gauge Pod?
  17. Need help deciding what to do next
  18. Where to get color matching gauge pod??
  19. Check Engine Light after NLS
  20. Help please
  21. Turbo dead
  22. Any mod info for 2010 ss/tc>??
  23. trouble downshifting into 3rd
  24. shift linkage
  25. Brembo's Fading
  26. 2009-2010 Projector's fit
  27. key stuck in ignition when car is running.
  28. another rear brake ss/tc
  29. AWD Cobalt SS/TC???
  30. Stage 2 upgrade for Cobalt SS/TC
  31. Rear brakes sporadically binding?
  32. Cobalt SS Turbo Will Become The Next Eagle Talon!!
  33. Lost All Boost Today Any Ideas?!?!
  34. Hit a Deer Crossing the Highway (PICS)
  35. 2011 Buick Regal GS LNF Powered
  36. gold brembos + r1 concepts drilled/slotted (pics!!)
  37. What are people doing with their old rotors?
  38. SLP loudmouth
  39. Anyone Roadrace cobalts
  40. Stock Exhaust Sounding Sweeter by the Day?
  41. Few Questions about 2010
  42. Problems!
  43. Superchips cortex tuner
  44. Does lowering the car kill traction?
  45. Cold start .... and go ......Bog
  46. Adjusting the Speakers
  47. Stage 1 Turbo upgrade Bargains
  48. Scythe_Snake goes to Michigan to see ZZP! (Turbo Upgrade Build)
  49. broken intercooler
  50. Wanted: A how to on an intercooler install
  51. Should I put my AEM intake back on?
  52. SS on inter cooler
  53. New partz I haz them!
  54. Switch to penzoil ultra
  55. Dyno Numbers from my TC!
  56. Thinking about buying 2010 Cobalt SS
  57. White ss/tc with hahn intercooler pic request please
  58. Which Tune
  59. shift linkage broke 3 times in a row....
  60. 225 or what?
  61. Rockstar wheels on a SS/TC
  62. Crystal Red SS In Saskatoon?
  63. Is an oil catch can useful if...
  64. I'm baaaaaaaaaaack!
  65. Performance spark plugs
  66. OTTP Stage 1 mounts installed
  67. Turbocharged Badge REF
  68. I just need some reassurance
  69. Shifting for fuel economy
  70. Best quality 'blank' rear rotors?
  71. Dyno Wanted or Dyno Day
  72. Stock LNF dyno day. 09 SS
  73. Handbrake
  74. ASAP. MU3 Weight
  75. PI for RPD
  76. Interesting PI For the LNF
  77. Questions on my BOV??
  78. downpipe install.. question
  79. Had Car On The Dyno - GMS1
  80. question about parts
  81. Is the 3bar Map sensors worth it?
  82. Does the LNF ECM "learn" and adapt to how you drive ?
  83. Safest product to clean rims
  84. dp/exhaust
  85. GMS1..now my bov sounds different?
  86. Remote Tuning & Bulletproof Gears???
  87. goin to the dyno tomorrow!
  88. Cinco de Mayo! Time to break in to my car!
  89. MAF Relocation - Hot or Cold side?
  90. stock turbo
  91. Reverse Grinding
  92. Elbrus I05 Wheels
  93. Help with HAWK brake pads.
  94. How to read the base boost gauge
  95. spark plugs
  96. Time for new tires, what should I choose?
  97. 08 Cobalt SS Turbo or 06 GTO
  98. Went to the strip today. Videos...
  99. pookie025 dyno!!
  100. ticking noise in front left wheel on tc cobalt
  101. Shifter adjusting
  102. Drilled and slotted rotors
  103. Replacement Window Sticker
  104. got my rear brakes warrantied
  105. Painting Stock Intercooler
  106. 2009 or 2010 SS
  107. Moneyz>>>i haz them now
  108. Need OEM rear pads, where to buy?
  109. Trifecta Tuner now located in Indianapolis, IN
  110. cheap sunroofs.
  111. Need help. Check engine light just installed zzp charge piping.
  112. Anybody have the OEM part number for this DP gasket?
  113. Some1 Please get me a pic of where intercooler brackets go:
  114. Anyone know how to pair Bluetooth without using the wheel control?
  115. Already have a ss/tc Should i buy my brothers srt4?
  116. Tranny Failure
  117. Code P2906
  118. 2010 Cobalt SS status?
  119. help with a valve cover
  120. rear brakes, suspension upgrades
  121. Stock intercooler without grill
  122. anyone??
  123. HELP would be greatly appreciated
  124. now what should i do
  125. need some opinions
  126. 110 Octane.....
  127. Has anyone seen this IC?
  128. Stock plugs were gapped to .28 is this right?
  129. Sitting in the dealership
  130. TPMS/Speed sensor question
  131. staged cams
  132. shifting problems
  133. Able to tune Trifecta tune with HP tuner
  134. Wat site is cheaper to get gms1
  135. plastic rings on stock charge pipe
  136. If you were to pick one thing to upgrade on your cobalt, what would it be
  137. new 10 cobalt ss price
  138. Trifecta Tuned
  139. Stutters when taking off. Not lag.
  140. Different tire size in front VS rear?
  141. Weird Dyno Numbers
  142. Opinions on K&N Drop In
  143. overheating...
  144. Busted Passenger door!! :(
  145. Looking for Carlos.
  146. ZZP catted DP with 7 thrown codes
  147. Exhaust options, thread link please
  148. LNF upgrade
  149. Remove your intercooler condensation pipe
  150. Factory Turbo cooling?
  151. limp mode ?
  152. Drivers seat warning!!
  153. on the way to the dyno
  154. ZZP Catless + Muffler Delete video
  155. Static Noise coming out of front tweeter
  156. Anyone have the 2010 LNF Stage Tune yet?
  157. A confused car heart...
  158. This will bring up a lot!!!!!
  159. 09 SSTC. how much to replace the gray with black inside the car?
  160. Oil Change Help
  161. Downgraded tires
  162. Need Help from the experts!
  163. Number Crunching
  164. This is what the Cobalt SS/TC is meant for
  165. Holes in trunk lid for low rise/high rise
  166. looking for my first cobalt
  167. Defected from Mustang to Cobalts
  168. wtf car wont turn offf
  169. Who's highest in mi/km
  170. Can RPD be added to an 09 SS?
  171. hks bov. (videos)
  172. :)
  173. Clutch chatter?
  174. 08 cobalt ss vs 99 camaro ss
  175. Clutch squeek on 09 ss/tc... master cylinder replaced
  176. Trifect Tune Q?
  177. Slot and Drill Brembos? Wet driving
  178. dejon intake
  179. Drag Radials
  180. got me a 2009 ss/tc sedan
  181. blown map sensor?
  182. SS/TC wheels freshly powdercoated
  183. car goes into limp mode after boosting
  184. Picked up an 08 SS/TC
  185. wheels and tires
  186. RPD Vs. Dyno
  187. GMS1 Top Speed
  188. new to cobalt SS
  189. GMS1 + Downpipe
  190. Camshaft position sensor oil seepage
  191. Cobalt SS TRUE weight
  192. average time on GMS1
  193. 2010 tranformer edition camero v-6
  194. MPx catless downpipe
  195. Another SS noob
  196. Exhaust backfire/afterfire
  197. big problems with clutch change need help
  198. New 2010 Cobalt SS owner
  199. Extra PCM
  200. dashhawk question
  201. gauges!!!
  202. Front Plate Ideas
  203. so where can i find???
  204. just to see what you guys think....
  205. Air Conditioner
  206. Just got GMS1
  207. need some pics of hahn intake installed please
  208. Anyone have problems with flywheel?
  209. build options...
  210. Downpipe with electric cut out
  211. 2010 cobalt sstc trifecta tune
  212. 08 cobalt ss stage1 vs regal supercharged
  213. trifecta
  214. going to the track what time yiu think i will get
  215. CF Hood / Trunk
  216. Does Anyone Know....
  217. I have a pretty bad "road" noise
  218. turning 25 next month.
  219. New to me '08
  220. problem please help!!!
  221. n2mb wot box?
  222. this better get replaces
  223. Went to the track today, 1st try on trifecta 22 psi :)
  224. Reverse Idler Bracket Retaining Bolt Destroys My MU3 (Large Pics)
  225. Watch this he he he !
  226. GSM1 Dyno Numbers!!
  227. Metal in engine oil / filter - should I be worried?
  228. Battery help
  229. Tips for changing oil on SS/TC
  230. Anyone Drive GA 400 daily???
  231. Engine Oil and Warranty?
  232. opinion?
  233. Lowest fuel pressure reading?
  234. hooray for recall!
  235. Sometimes, innovation pays.
  236. Outside air temperature sensor incorrect
  237. Which Setup?
  238. I dont believe it
  239. What is the power gain from a catless DP on GMS1?
  240. Recall notice
  241. Dynojet time!!!!
  242. Gmpp
  243. The Most Ridiculous Brake Story Yet.....
  244. MODS/Waranty
  245. Sponsorship?
  246. Those with trifecta chime in.
  247. Tires
  248. CIA Short Ram Intake
  249. Annoying resonance sound in engine bay associated with speed
  250. ok i need some help.
