PDA
View Full Version : 08-10 SS Turbocharged General Discussion
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. Small oil leak
  2. 09 cobalt turbo flutter (vid included)
  3. Straight Pipe Exhaust
  4. Turbo problem question
  5. Bleeding clutch
  6. Question about different spoilers
  7. Help Find Old Owner
  8. Finished cleaning intake valves & other upgrades
  9. Original Battery
  10. turbo stopped spinning
  11. Weird turbo noise when holding rpm
  12. ZZP LDK Black Friday
  13. Has anyone rebuilt or built an LNF?
  14. Should I buy this Cobalt?
  15. Shifter linkage ?
  16. fuel pressure lnf
  17. LNF Coked Valves - Who walnut blasts?
  18. LNF clutch feels weird
  19. Temporary Clutch Fail?
  20. Chain tensioner issue
  21. Horrible Vibration
  22. trans mounts? steering rack spacers?
  23. 2009 LNF sedan Brembo Brakes, Pads
  24. Upgrades good exhaust and intake recomend uder 1600$
  25. Need a transmission
  26. Advice
  27. p0030 with brand new sensor
  28. Does the S/C analogue gauge work in the T/C
  29. Almost 10 and still looks great
  30. LDK CRATE MOTOR coolant won’t read on the dash
  31. Air intake swap?
  32. 2009 Cobalt SS/TC High HP Build Advice
  33. No start
  34. Finding Lnf replacement axles.
  35. Ecu questions???
  36. Anyone know what this part is?
  37. need help 2009 cobalt ss tc
  38. Also vacume tank line question
  39. Doing he vacuum tank delete
  40. New clutch ?
  41. Diagnosing a bad bpv
  42. Ecu
  43. DF Goblin from a 2008 SS TC Build Thread
  44. Lnf cooling fan issues
  45. 08-10 Brembo questions
  46. Cylinder bore
  47. 2010 SS Passenger airbag sensor problem
  48. Discovered that my old SS/TC sedan got wrecked by the kid I sold it to
  49. Cobalt ss turbo engine light p0420
  50. SS/TC wheels
  51. greddy bov and do i need a tune?
  52. Making more boost than normal
  53. Loud noise under heavy boost.
  54. 2010 HHR SS - P2261 Code
  55. P0113
  56. Odd sound coming from turbo
  57. stalling
  58. 09SS, keep getting P0100, P0532
  59. oil sprayed everywhere
  60. Trade // High Rise for Bald Lid?
  61. Boost Flutter Chevy Cobalt SS/TC
  62. Stage 3 disc shattered
  63. Boost and mass flow questions
  64. Rotated mounts cause exhaust clearance issues?
  65. P0234 at 16 psi ???
  66. Brand new z54 blows up after 1600 miles
  67. Water in lower o2 sensor
  68. Minnesota street tune?
  69. 2009 ss
  70. Cobalt ss/tc Shortshifter
  71. Need some Advice
  72. 06cobaltss/ss buys an LNF
  73. Rpd gone bad options for pillar?
  74. Need new cluitch
  75. Boost question
  76. Noise increasing with MPH (40 MPHish loud)
  77. Cobalt ss/tc 09 boost question
  78. do they make the gmpp clutch anymore?
  79. 2010 lnf
  80. Adding back an Aftermarket Muffler for 2009 Cobalt SS LNF Sedan
  81. low boost
  82. suspension
  83. SS TC lower grill insert
  84. Opel injectors
  85. Need parts
  86. Changing Wheel hub bearing
  87. LNF 2.0 turbo transmissions!
  88. Just picked up my new LNF
  89. Bang for the buck upgrades Advice?
  90. Cold start noise
  91. F23 Swap
  92. Looking for new tuner
  93. Looking at a 09... questions
  94. stiff steering
  95. engine ran like a tractor
  96. New 2010 SS owner. Easy questions
  97. Engine Misfire Codes
  98. Knock sensors
  99. LNF Common Questions (2018)
  100. Rfl?
  101. Value?
  102. ZZP radiator for LNF
  103. 100K Mile Maintenance
  104. Z54 turbo failure 5 months old!!!!
  105. OTTP catch can
  106. I believe we have a problem Houston.....
  107. fuel pump fuse
  108. Traction mods for street & track use?
  109. Borg Warner s257sxe
  110. No Turbo boost sometimes, severe oil use sometimes
  111. Turbo not working at times, Excessive oil cunsumption at times
  112. Wideband question
  113. install oil pressure gauge
  114. 2010 ss/tc gmpp clutch questions
  115. atmospheric Bypass valve
  116. What is normal temps?
  117. Recommendations for mods
  118. Helppp question project LdK setup fit in lsj cobalt?? Or Saturn ion
  119. Things to look for on used SS
  120. Alignment Woes?
  121. Porous Block still an issue?
  122. Front seat belt question
  123. too much camber
  124. Idle memory
  125. Anyone please help
  126. i wanna run e85
  127. Misfire under heavy boost
  128. Smelly throwout bearing
  129. Walnut blasting in Metro Atlanta
  130. Seat stuck reclined all the way forward put of car
  131. Bps shifter knob thread size
  132. E47 quistion
  133. hahn intake
  134. Catless, bov, 24.5 psi, what's next?
  135. knuckle spacer part: 25794670
  136. valve cover torque specs
  137. 09 SS/TC Low Heat...New Heater Core & Thermostat
  138. 08 Cobalt ss lnf crank no start ( SOMETIMES )
  139. slight burning oil smell at startup
  140. 24 gauge engine ground
  141. how to take this off??
  142. 245/40-18's on 2010 Stock Cobalt SS Rims
  143. Cobalt vinyl decals
  144. lnf zzp intercooler rubbing
  145. reduced engine power
  146. Headlight help
  147. Hesitation during heavy rain?
  148. Considering buying 2008 Cobalt SS, have questions
  149. Belt # for SS/TC without A/C
  150. 2009 ss/tc
  151. Power on 91 octane
  152. Could use some help locating body parts for 2010 SS
  153. What is it and what's it do?
  154. Cam Position Sensor location
  155. Blown turbo?
  156. Intake filter sleeve
  157. Airbag warning wont turn off
  158. Radiator fan wont stop!
  159. Aftermarket radio w/ Sirius xm question
  160. Questions about injectors, rear diff, trans
  161. Help ! 2009 cobalt ss issues
  162. '09 popping out of 5th
  163. 2009 / 2010 SS.TC should I buy?
  164. Which Shifter Cables to Get
  165. Engine Coolant Temps
  166. 2009 Silver Ss
  167. OBDII device question
  168. Turbo whistle and boost only up to 10 PSI?
  169. For Sale 08 Cobalt SS 324 whp
  170. Shifter issue??
  171. Why are the 2008-2010 selling for so cheap
  172. Shifter bushing stuck
  173. Cobalt ss tc wheel size info
  174. ZZP Strut Bar
  175. From trash to fast! 2008 SS build!
  176. Intercooler finally cracked
  177. Need a new tuner
  178. Brembo caliper replacement??
  179. IAT and IAT2 Temps
  180. LED halo projector headlight installation issue
  181. Retrofit headlights
  182. Replacement Clutch???
  183. Adding gauges
  184. Headlights
  185. Électric Fan mystery!
  186. Fuel Pulse Dampener
  187. Knock after cleaning Intake Valves
  188. Help low coolant over heating
  189. help with p2188 code
  190. Any E47 tuners in Phoenix area?
  191. Will MICHELIN PS4S 245/40ZR18 fit without rubbing?
  192. Water under back seat
  193. E-brake driver side not grabbing so well
  194. Possible PCM issue?
  195. Intercooler
  196. I'm back!!
  197. E47 tune question
  198. Powell Oil separator/PCV relocate
  199. 2008 Cobalt SS Engine Power Reduced
  200. I need help
  201. 2008 LNF Brake Pads Confused...
  202. GMS1 users
  203. Clutch position sensor- no crank
  204. shifter noise
  205. Looking for previous owner
  206. proper coolant drain.
  207. cobalt ss battery TC
  208. Installing ZZP Fuel Cam
  209. 08 cobalt ss 10 psi max??
  210. I need a part number
  211. Turbo question.
  212. Crankcase vent hose?
  213. LNF E85 Fuel(ing) Question
  214. High pressure pump problem
  215. Clicking noise from drivers rear wheel
  216. Air Fuel Ratio- Data not available on LNF Screen
  217. 388HP/415lb/ft Gobalt SS Turbcharged Spec Video!
  218. How to detect a bad MAF sensor?
  219. HID /Retrofit quesitons
  220. Horn stays on when headlights are running ?
  221. Sticking brakes
  222. Slight clunking / clicking
  223. 7-8 grand to build
  224. Zzp pcm tune?
  225. Blown short block - Anyone here selling a like new shortblock
  226. Rough start up with maf plugged in
  227. What's My Limiting Factor, Fuel or Turbo?
  228. Cam Phaser Issue!!!
  229. My first "accident"
  230. Having to sell my TURBOCHARGED Cobalt SS CHEAP!!!
  231. What to check on a used car?
  232. New to the SS world, question about intake and check engine light
  233. new to me LNF, what should I look for before buying?
  234. No Drill, Front-Plate Mount
  235. Newbie here. What motor is in my cobalt ss
  236. Tuners in illinois?
  237. tranny shift cables
  238. Putting back stock cat
  239. Cobalt rear bumper cover differences?
  240. Ldk brake vacuum pump
  241. Few question regarding lnf big turbo setup
  242. Smoking real bad...
  243. Suspension Mods Help
  244. Boost Spike Tuned LNF
  245. Possible tune
  246. Lnf insurance trying total car out!
  247. P0087 code, have tried everything
  248. My 2009 SS Sedan
  249. New to me LNF - I think it's tuned. how to tell?
  250. In the market for a LNF SS... What do I look for?
