- NLS fail..
- Launch control
- where to begin...
- LNF. Dp and exhaust install
- 09 SS\TC Wierd brakeing issue
- 120k miles on the LNF; what can I do to keep it running for a long time to come?
- New Owner Woes: Vacuum Lines, Battery, and MAP
- brake question
- Any tips getting upper charge loose from turbo?
- R P D trouble
- clunking noise coming from front suspension?
- Need help with some stock LNF/FE5 suspension data
- broken shirft cable
- Moisture in headlamp assembly
- How much is lnf sedan worth?
- The dreaded porus block bites again
- Front caliper bleeder valves leaking
- Need Help 08 LNF
- HP Tuner cable near Cleveland Ohio
- Vince still at trifecta?
- Rpd and trifecta tune reliable??
- Who limited first gear boost with tune?
- brake bite
- This is a little odd
- Does it look good?
- 09 BPV solenoid removal.
- Any issues with Turbo XS RFL?
- Maximizing Boost without beating it up?
- Catted downpipe vs Catted downpipe with muffler delete
- Buying Advice
- Will a trifecta tune tune my car back to stock
- New Turbolt owner looking for previous owner(s)
- Whats my car worth? 09 SS, Summit White,G85, RPD, 70k miles
- Plasti dip with curb rash qusetion?
- When to change brembo rotors
- 2009 Rally Yellow SS Sedan Detailed Production Figures and Info
- Wtb cobalt ss front lip
- Brake time!
- Chassis stiffening
- Need Help!!!
- Tuned w. bolt-ons, new tune for new downpipe?
- eng Reduced power/service ESC/number of codes
- Previous 09 SS owner in Paris Tx. area
- Need buying advice
- Problem getting into gear
- Boost leaks 'n Stuff
- Give me your best guess
- LNF head on LSJ block will it work
- Driver side gray "seat back" part number?
- Tuned?
- Boost leak or what?
- Finally picked up my first cobalt!
- who has best price on hp tuners??
- valve cover leaking, any other seals/orings to replace at that time?
- quick intake question
- Considering a '09
- Help with a couple issues please.
- injen sri
- LNF Stock Resonator Question
- I want to rebadge the car.
- New Motor Mounts = TONS of knock
- help!!
- fastest sedan 93 octane?
- Haynes Manual?
- Helpppp
- want to buy mint red & black SS seats
- Cruise control stopped working, then started working again...
- Buying another LNF this summer
- car stalls and dies out HELP!
- Road trip
- LNF OEM Wastegate Questions
- Thinking about going to e85
- Stock tune and GM 3 Bar's
- How much does the TC coupe and SS sedan actually weigh?
- Trying to get my butt back on an LNF
- downpipe
- 2.0 LNF Intercooler
- SS Bottom Subframe same as other Models??
- Rev limiter
- Multiple DTCs
- Best options for suspension and when should I change the springs/shocks?
- 2009 SS fuel filter location
- My 08 LNF build thread.
- Black smoke while starting.
- Bypass Valve Solenoid Testing
- Clutch recommendations?
- Hahn Charge Piping setup with BOV
- 2009 ss sedan rally yellow for sale
- how much dexcool for zzp radiator?
- code p0101
- What to upgrade on LNF?
- Cadillac ATS 2.0T Problems?
- How to upgrade your LNF?
- p0087 & p0089 codes/ power reduced
- OTTP Rotated Trans Mounts trashed
- crate engine LNF new production model
- Back to stock from Hahn CAI?
- Clutch Master Bad
- Rear Brake Caliper Piston
- muffler delete with resonator
- Looking to tune my lnf.
- bpv issue?
- changed crankshaft position sensor now vacuum cleaner whine when engine is running
- best 0-60 tire for TC's
- Dyno Numbers?
- where to get billet oil pump gears?
- map sensor location??
- Injector Seal Tool Loan Program
- Anyone in Northern CO with an LNF and an EZ-cable?
- Coilovers or Springs?!?!
- Cobalt SS loping/running rough
- Front Mesh Grill color and removal?
- p0017 and 30psI on gms1
- zzp 3 inch exhaust
- Pick My New BPV or BOV Setup
- camshaft position sensor....intake/exhaust the same?
- who all runs the s259 billet turbo setup?
- sticking Brembo caliper
- replacement brembo caliper
- Hit a bump no boost
- LDK Swap List
- Car rolls in neutral ?
- Rebuilt the front calipers today
- ion redline rims clearing brembo brakes
- fuel system
- Has anyone's stock turbo ever rattle at 3100 rpm?
- Say I wanted 500whp
- Need help with a few issues on my SSTC (cold start and ratteling in suspension)
- Loud whine from driver front wheel possible wheel bearing?
- My "Buy a LNF they said..." Problem/Build Thread.
- would a catch can fix it?
- Quick Exhaust Question
- Launch Control
- I love the Cobalt SS, but mine has been a huge money pit
- 2009 SS/TC Battery
- Horrible Suspension Noise!
- rpd gauge
- NEW Cobalt SS
- e85 and LNF...
- p0011
- Want to buy ski rack
- new ecm question
- Brakes and Clutch Question
- 2009 SS/TC LSD Option Question
- 18x8.5 wheels
- What is the max lbs of boost set from factory a bone stock LNF?
- What are u after on Black Friday??
- crank relay wiring question
- sputtering only at wot and after 4000rpms
- amount of Moble1 grease on Forge bpv
- Question about selling a Trifecta ECM.
- Bullseye Turbo Wheel
- MAP sensor waveform
- cracked intercooler
- Those running bigger turbos, deep sounding exhaust
- Lost Digital Outside Temperature and Tire Pressures
- HHR SS tune?
- Advice/Thoughts/Suggestions
- Storing Car For Winter With E85/E47
- change radiator hoses
- Custom Exhaust
- She's alive!!!!
- drivetrain noise
- Question on camshaft upgraded fuel lobe zzp
- Torque Steer
- Brakes Scary when WET !!!
- Misfires and Low coolant
- 2008 Cobalt SS/TC 88k Miles - Cracked Block
- Harder Question: What is the oil pump flow rate?
- 2010 SS Front Brakes
- Car cover reviews
- complex issue with new ride
- Option B zzp
- Quick clutch question for someone with an available throw out bearing
- 2010 ss tc
- 2010 cobalt SS AEM wideband install
- Shift knob removal
- part # for vacuum tank?
- how much PSI should i be at?
- HELP! So I ran into a median in the road....
- Hahn DownPipe
- Coolant leaking on to turbo
- taking your car to a dealership with careless dp
- Wrx vs SS
- For those that have the ZFR installed and an aftermarket exhaust
- turbo solinoid
- Hunt for clutch's disk
- '10 SS/TC factory shift light?
- 2009 SS/TC: Backfire
- No transmissions available
- AIr Filter
- Random Misfires PLEASE HELP
- Finally paid off the cobalt
- Powell Racing. .GURU of DELTA!
- help ! 09 ss wont turn over
- New LNF! Few minor issues and questions
- G85 question
- imagine a LNF transplant in/to this..
- Pulling the trigger on an 09 Sedan
- tuner for cobalt by Chicago and build opinions
- Brake pads for an 08 SS/TC
- HKS BOV question
- What to do with old, broken, stock intercooler?
- GMS1 40 roll pull and 60 roll to 160!
- Muffler Delete
- 17's in front 18's in rear
- Should I put it on?
- Do I need it?
- Can anybody tell me from this video if my mounts are bad?
- ZFR + TurboXS FL Exhaustt
- RWD LNF Cobalt, how hard could it be?
- ZFR Help
- Official Porus/Cracked block complaint
- Charge pipe question
- Brake questions?
- Surging in gear at speed?
- Banjo bolt washer size for front Brembos
- Boost stops at 5psi, but only sometimes. This has happened twice now.
- How to change serpentine belt.
- K&n 69-4518ttk
- fe5+yyz and xxx vs tuned coils
- Electrical Problems?
- Fuel pump noise and sound insulator? WTF
- Cleaning MAF and MAP Sensors
- Louder Clicking noise
- Coilovers vs Koni Yellow + Pedders
- Custom AN lines
- Clutch + Flywheel Poll - Best 300ft*lb setup?
- plasti dip help
- Challenger R/T.. Good kill or Easy Mark
- Catless down pipe with cutout
- Drilled and slotted rotors
- Turbo upgrade?
- K&N intake w/ GMS1
- 03 nissan 350z vs 09cobalt ss/tc
- Dart srt4 awd
- Serpentine Belt Replacement 2009 SS/TC
- What do you guys think of this SS?
- Finally having an issue not related to mods or power. P0013
- Rear Caliper Boot!
- Downpipe catted questions
- Oops ! Loose Rear Door Bolts.
- Loud steering rack
- holset
- Newbie Question
- 08 sstc losing coolant all the sudden
- RPD stopped working
- Forge Atmosphere BPV with Rfl Exhaust
- Soooo that fuel gauge problem...
- OEM upper charge pipe rubber connection..
