- JL Interiors??
- CD Jammed in the player
- 101 times please
- Help!!!!!!!!!!!!!!
- radio
- aux input for 06 radio
- Sound deading experts.... Have some questions. Non Cobalt.
- Do aftermarket radio's work with stock amp?
- speaker phasing
- radio harness help
- custom speaker placement...
- Can I hook up stock amp to non-pioneer system?
- Rattles and sound deading
- Stereo Finally Done!
- Fan help...
- Frekin rear speaker blown!
- car pc
- Alternator Whine
- stock speakers in a lt
- which sub box
- Stock Radio witTh AMP...
- Which Battery Should I Get?
- sound dampening in the cobalt SS/SC?
- hole in the firewall??? help needed
- First shot at a fiberglass box
- stop rattle
- Welp, Ordered a new headunit, and a bunch of other stuff!
- wiring lights to dome light??
- alpine imprint...
- Gauging interest Pioneer Z1,2,3
- Is this a good deal?
- headrest monitors.. can they be flush mounted to a wooden box?
- Emp Amp Pics
- MTX Blue Thunder Subs: opinions wanted...
- Someone that knows more about audio than me.
- Delay in ignition after swapping decks.
- How is this amp??
- GM factory Nav
- Need new speakers!!!
- Swapping steros with older and newer balts
- Quick Question: Where is a switched wire to tap into!?
- tweeters
- Help choosing a system
- help on speakers!!!
- just got the car back
- offbrand touch screen
- Weird Problem with headlight, Help if you can.
- Where do I splice the Resistor for LED's??
- question on Kenwood DNX7120
- need help with XM radio
- alpine type s/type r
- question about warranty
- so i set my gains for the final time
- Aftermarket XM parts
- anyone ever realize
- HID's in an 09 ss/tc??
- speaker wire
- Reconfig Display
- CD player trippin!!!!
- Somewhat Updated System
- Addin An Amp.
- Retained Accessory Power Harness
- stock cd player problem
- Dash control information
- possible new system, any thoughts?
- hid help
- question about rca
- Venturing into car audio
- Remote Start in my 09 SS
- Info: xo vision 7"
- Project Coby complete
- Radio Problem
- Amp stopped working
- Sub??
- Help!
- Anyone Use a Ipod Adapter For a 05 Radio?
- Avic-f900bt
- Micro sd help
- GPS Antenna Location
- Which Deck?!?!?!
- double din
- How did you mount your enclosure?
- 06 w/ PIONEER SYSTEM... HU/SUB/AMP Install Questions
- Songs that have BASS
- Stock Radio Question
- Sirius on factory XM radio
- Will this kit work
- installig an equalizer
- roof removal
- Would this work?
- What do these fuses do?
- JL 10w3's or Kicker 12L7?
- Help with sub install.
- Clarion max685bt
- Rattling
- Swapping radios?
- New Subs.
- dei 530
- anybody elses XM suck?
- audio help
- hi-output alt or deep cycle battery?
- Weird Speaker Noise.
- Dash Lighting
- Rev Iphone App
- How can I increase bass on 07 cobalt components
- Damn It
- a good audio..
- wiring new gauge (help)
- Stuck on HID installation
- wring harness help?!
- Bluetooth not connecting.
- Brand new speaker blown?
- For all the car audio Gods please help.
- Tmobile g1
- audio system install in the works..
- Keyless entry programming
- HID Relay
- Keyless Entry
- KCE-236B pins pushing in...
- help keep blowing amp fuses!!!!
- Installing radio at bestbuy!!!
- xm to sirius radio
- installing speakers into a factory pioneer system
- My Stereo Cuts Out! Help
- help with Kenwood KDC-138
- Kicker ZX350.2 Overheating
- my new plan, using stock HU stereo
- Alpine with factory steering wheel controls
- the best pop up screen
- 2005 Cobalt Single Disk. Ipod integration?
- where to mount 1/2 DIN size EQ ??
- HELP!!! i dont know what im doing!
- wipers and boost gauge
- best deck at best buy
- remove door panel
- xm
- Subs with stock head unit
- Stock HU & RCA Cables
- Whats Better
- How to instal a Voltmeter?
- stock ipod connector
- XM Radio Set-up ?
- Remote Start
- headunit
- amp kit ?
- Time for something better!
- aftermarket deck and steering wheel controlls
- Anyone Use This Passport Wire?
- Highbeam Problem
- to big of an amp?
- Hook underglow to alarm
- Double Din v. Single Din
- HID problem...
- Oil Life Meter Question
- Help with my pioneer deck
- lol funny story
- Rattle
- wiring harness
- will it fit?
- Finding an Accessory Fuse ?
- Neon problem
- i need help to install oil,trans, and A/F temp gauges
- factory stereo wiring diagram
- Wiring a Passport
- A "Sound" Idea!
- Question about stock SS/SC harness connections...
- Installing head unit need some help
- radio wiring harness
- headlight flash
- dedicated Ipod connection -> Diff type
- HP pavillion dv6365us webcam help
- Circuit City? Come On!!!
- CompuStar 2WSHR LCD
- Disassemble Rear Deck?
- Blown Speaker?
- Cobalt Install Record
- what do u guys think of this location for courtesy lights?
- Where to tap the LOC into??
- Car Alarm
- dynamat (well general sound deadening)
- my little setup
- How much did it cost to get it installed?
- how do I splice a 3rd wire?
- Kenwood DDX512 Installed
- Outside Temp Guage?
- Quick DVD install ?
- My Custom Stereo System, will be lots of pics!!!
- i may have to buy this GPS
- Amp help ASAP
- USB Radio in 2009s
- Fiberglass work in trunk...want ideas
- Home Video question
- Pinout Question
- dual 12 inch sub boxes
- factory head unit/aftermarket speakers???
- Charging system voltage and adding extra stuff...
- Upgrading Power Wire
- Ignition Voltage
- Couple of Audio Questions Not Covered In FAQ
- compustar alarm/starter combo
- how do i connect a shift Light ????
- Relay help?
- Will an 05 gauge cluster fit in an 07???
- Radar: Passport 8500 vs Valentine V1
- Flickering HID kit
- How do you undo + battery post
- Where to ground the amp/move cap
- i want a w6 i think
- adding speakers to pioneer system??
- Sub Swap
- In-Dash Monitor for computer
- trunk wont open
- Stock Audio in 08+
- Speedometer Needle Isn't Working.
- I got bored, so what!
- push button start??
- New amp and sub with no LOC or remote
- broke my sub?
- 08 SS/TC Sub Upgrade
- What amp to buy for W3s
- Halo Rings?
- How to change how long headlights stay on??
- Thinking of somthing new for subs
- 10.4" monitor
- built in head unit
- problem
- Blew my amp tonight, need suggestions on a new one.
- Bluetooth Retrofit
- Check Out My Cobalt Subs/Amp In My 08 Cobalt ls
- Remote Wire for Amp
- power wire fuse?
- please help
- A Few Audio Questions
- adding a kinetik
- XM and OnStar
- Need OnStar Wiring Diagram
- Choosing Amp Type
- 08 aftermarket head units
- outside air temp sensor
- mounting my box (6 pics)
- Infinity Kappa 6x9's....
- is this correct?! HELP
- Amp Help!!!
- Anyone installed a subwoofer?
- really frustrated
- Did I buy the right harness???
- Sub and Amp install with Stock HU
- Stock Head Unit Issues
- LCD screen, what can i do with it?
