PDA
View Full Version : Electronics, Audio, and Video
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
  1. 200watts vs 400watts
  2. Stock 06 radio changes EQ.....
  3. Are these better than stock?
  4. Install of Pioneer
  5. Negative Resistance?
  6. Wiring Questions
  7. Radio fuse help
  8. It had to happen eventually :/
  9. Need a good opinion
  10. iPhone/iPod touch mounting locations?
  11. Do I need a second battery?
  12. 06 cobalt stock radio turning on by itself!!??
  13. loudest test tone
  14. question
  15. Problems...
  16. How did you eliminate Rattling from Subs?
  17. Whine
  18. Sedan Owners
  19. Front Door Speakers
  20. Best In-Dash
  21. Installing a New System.
  22. Question about the Wiring Harness.
  23. hard wiring question..
  24. One touch switch for passenger window?
  25. Noob question
  26. Inquiry: Wiring the ACC ignition Cable
  27. Does anyone know where to get speaker harnesses for the cobalt
  28. Headlights and foglights what to do with them
  29. Relocated Traction Control Button!
  30. avic-f700bt install info
  31. The final step (one last question!)
  32. will my deck interfere with my steering wheel controlls?
  33. Quick Question
  34. What do i need?
  35. Can a 375 watt DHD amp...
  36. XM antenna on top?
  37. LED taillights
  38. Looking for an EQ... Suggestions
  39. Valentine 1
  40. which way to face your sub enclosure?
  41. My system
  42. Best SQ Subwoofer
  43. Bypassing New Deck Video lock
  44. Pioneer AVH-4100 help
  45. Quick stock/aftermarker sub/amp question
  46. AVIC-D3 trouble shooting need help!!!
  47. PassKey Bull
  48. Radio wont power up. Please help!
  49. Factory Sub Box
  50. Favorite speaker brand
  51. HELP fixing a broken subwoofer
  52. Tap VSS for Nav from behind gauge cluster?
  53. AFR wiring question..
  54. one quick questions!
  55. Steering Wheel and Radio Swap
  56. Amp Problem
  57. Ahh, how do I get this door panel off!
  58. Upgraded alternator
  59. 6.5" Kappas w/ stock tweeters?
  60. new sub box ...
  61. Question on Gauges....
  62. Doors radomly disable and wont let me out?
  63. is this a Speaker or Headunit Problem??
  64. How to help me please intalling tachometer gauge
  65. Rear speakers wont fit
  66. planning a setup, need opinions
  67. t10001bd at 0.5 ohms
  68. Aftermarked Double Din questions????
  69. link?
  70. which radio to get
  71. Stereo probs
  72. Speed sensing wipers. Can they be disabled?
  73. cant have anything nice around here!
  74. New system, few questions guys
  75. Stock/Stock Stereo Replacement- Read, you know this isn't stupid lol
  76. who has 2 12's in the trunk?
  77. computer question...
  78. Kenwood bt200 good?
  79. USB flash drive, retained accessory power - what to do?
  80. How Do you Use Wire Taps?
  81. what kind of isolator?
  82. PAC SWI-JACK Help Please
  83. Speakers have no sound?? HELP please!
  84. Problem bypassing the stock amp
  85. Help...horrible alt whine
  86. Red top or Yellow Top??
  87. Door speaker problem quick question
  88. h/u wiring help will not shut off
  89. power source for accesories?
  90. metal bracket behind stereo
  91. dash kit help
  92. Clarification
  93. My sound system - deadly.
  94. Stock CD player - no sound but power
  95. quick question
  96. Pioneer screen just installed
  97. Trunk lights do not work
  98. LED/HID dome light?
  99. amp cutout
  100. Phase one complete
  101. Carputer Is IN!! :)
  102. First Box Pics
  103. H/U Thread
  104. led resistors
  105. ask if you need a wiring diagram
  106. Please Help
  107. Anyone have a pocket under there radio with a door on it?
  108. Help With Gauges!!
  109. what subs to get
  110. Best place to install an xbox
  111. dome light grrrrrr
  112. New Fronts!
  113. Amp/sub question
  114. Inside speakers
  115. Stock headunit
  116. need help please.
  117. Battery?
  118. Pioneer Premium 7-Speaker Audio????
  119. Subwoofer Wiring
  120. Good Double DINs Under 400 bucks
  121. 08 Tc stock radio?
  122. pioneer avh-4000 usb issue
  123. Custom Flooring for Trunk.
  124. need quick little head unit help
  125. What sub to use
  126. How does this headunit setup sound
  127. Can I have 2 STOCK Pioneer Subwoofers hooked up?
  128. best patch / rca chords
  129. Adding foglights.
  130. For anyone wanting a carputer.
  131. bench testing
  132. Finally guna gut the aftermarket audio stuff from my Cobalt..
  133. Pioneer DVD Receiver Questions
  134. Engine fan and temp?
  135. Sub Position
  136. Hood Pin Placement
  137. Battery up front.....??
  138. ugh! help please!
  139. subwoofer question
  140. Radio Delete/gauge pod
  141. free battery?
  142. help rear speakers
  143. sequential tail lights?
  144. Need some help
  145. Stock speakers question?
  146. question about bandbass sizes
  147. Pioneer Avic f90bt
  148. Balt PC Installed...errrr well..
  149. Amp Overload Problem
  150. 07 wiring harness help!!!!
  151. need help with the remote cable of the amp!!!
  152. need some help!
  153. Need HELP!! sound deadning -
  154. aftermarket double din?!
  155. Auto Sunroof Button???
  156. need help wiring new hu suggestions
  157. 2005-2006 Cobalt Head Unit install with pics
  158. sick runs and cars!!
  159. Metra Dimensions - NEED FOR CAR PC
  160. audio help plz :)
  161. No remote start after pulling battery cable?
  162. OnlineCarStereo.com
  163. Type R with ZX400.1 enough?
  164. Double DIN screen Backgrounds for the Cobalt.
  165. Passenger Air Bag Sensor Question
  166. my new sub box
  167. Broke the antenna...
  168. Oil Pressure Sending Unit 2.2?
  169. '06 SS Wire Harness?
  170. Power Acoustik BAMF 2000.1
  171. Are hid bulbs interchageable?
  172. HID Not as expected
  173. 3 15's in a cobalt!@*$
  174. ipod mounts
  175. Best Type of Box for These Subs...
  176. Subwoofer Wiring Question
  177. Need a stereo shop installation in PA....
  178. wanna put a headunit in my 07 LS
  179. jl audio ?
  180. Need help with troubleshooting my Avic-D3
  181. Fuse
  182. Installing a PS3 in my Cobalt
  183. key fob programing?
  184. help! speakers cutting in and out. (yes...not a cobalt)
  185. questions about adding more subs
  186. Wiring Gauges.. Questions..
  187. hid lights---help
  188. dynamat or other brand?
  189. going back to stock radio..?
  190. CD stuck in player help?!!
  191. Viper 5901 cause window malfunction???
  192. Looking for a How To Thread
  193. PTY message in display all the time??!!
  194. Power Tap
  195. 2009 head unit
  196. How anyone attempt this
  197. capacitor??
  198. Need help!!!
  199. Stereo Question
  200. Another BASS Question.
  201. battery died, i believe my sound system ran it dry
  202. Bass Question
  203. What all do I need to get a new headunit?
  204. USB iPod Shuffle issue
  205. soldering ground terminal ring to chassis?
  206. Fog Light Harness I made.
  207. Power Source
  208. Anyone have the pioneer p4000?
  209. Correct In-Dash
  210. Inside Rearview Mirror Swap?
  211. Putting Stock Pioneer Sub In 2.2
  212. HU and speaker help
  213. help please (prolly stupid question)
  214. Swapping stock radios?
  215. LED Wiring...
  216. digital audio
  217. HELP... Pioneer AVIC-F900BT problem
  218. Mount DashDAQ where Boost gauge is?
  219. Alpine Type R ?
  220. Stock 6x9 in 09 Cobalt SS
  221. Interior Fuse panel question
  222. new help please!
  223. Removing trunk carpeting
  224. '07 SS/NA: Aux-in is messed up!
  225. power questions
  226. 06 LT Front Door Speaker Size
  227. Factory systems, Bose vs Pioneer.....
  228. Aftermarket sub in stock sub enclosure
  229. Factory Radio Swap
  230. Door Speaker Recs
  231. anyone know how to set up a 6x9 as a sub?
  232. Stock XM to Aftermarket Head Unit
  233. Where can i get a converter from
  234. question about making a ported box
  235. Hyper Grounding System
  236. triple intercetors
  237. Head Unit Install Time?
  238. Double amped speakers?
  239. innovate LC1 CB gauge...
  240. Front Speakers
  241. attaching amp to factory battery
  242. Interceptor question
  243. 12' alpine type x or 2 10' boston g5's
  244. Redoing a sub box
  245. Amp Overheating
  246. thoughts on the stock sub enclosure and upgradinbg the sub
  247. Really? speaker question
  248. How to install a 7" LCD H/U and Slim PS2 on 2007 Cobalt SS/SC
  249. Hid Help!!!!
  250. Bluetooth Connectivity
