PDA
View Full Version : Electronics, Audio, and Video
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
  1. Convert RPD to earlier OEM boost gauge
  2. Led map lights staying on
  3. Wiring and PCM issues
  4. need wiring help,removing bcm?
  5. programming omega alarm module
  6. hid no low beam
  7. 06 cobalt ss/sc fuse problem
  8. throttle postion dropping out
  9. Help with flickering lights and power steering
  10. HVAC help
  11. Pics of Blue Aeroforce Interceptor Gauges in a black and red interior
  12. How to use empty fuse slots in BCM???
  13. what to connect aftermarket gauge lighting to
  14. How to swap Hi/Lo beamm after HID install.
  15. New owner, trying to install aftermarket HU.
  16. Stock Sub Wiring Guide
  17. 2007 Cobalt SS NA - Radio not turning on and no turn signal noise? Help please!
  18. Viper Turbo-Timer Removal
  19. False laser alerts in 9500ix
  20. Front speaker connector
  21. HID question
  22. Jl w7 vs psi
  23. Adding a port near rear windshield
  24. Speakers problem
  25. No start: Clutch position sensor 09 TC
  26. retrofits
  27. Chime/Radio Volume too lound after upgrading to GM USB radio
  28. turn signal, door speaker problems
  29. Angel eye
  30. Water leak almost ruined my component speakers
  31. Audio wiring/resistance/all that jazz
  32. License Plate Light Socket/Harness
  33. Need Antenna Help Please
  34. Spyder Halo Headlights
  35. taillights not working properly
  36. Can you shut off the headlights when key off
  37. CD Player Elapsed Time
  38. Issue with K2 Motor LED tail lights.
  39. HID down!
  40. high output alternator
  41. New Retros
  42. Ss Lights
  43. factory remote start
  44. Anything a lil better then a type R?
  45. Head unit recommendation
  46. radio faceplate circuit board
  47. Projector Predicament
  48. 08 ss radio to 09 ss usb radio, same connector?
  49. dual interceptor connection
  50. headunit not dimming.
  51. Speaker Whine (Speaking to you EMPJJ)
  52. Radars
  53. Wiring diagram/location 09 LNF
  54. Wiring help
  55. OEM '08 radio swap to OEM '09 radio
  56. Door Speaker Q
  57. Parking Lamps and turn signal
  58. Aftermarket Boost Gauge Install
  59. How to power a 3500 watt system
  60. Best Fitting Stock Headlamps
  61. ID3 tag error check file
  62. Trying to find pioneer sub wires
  63. Double din radio
  64. 3 12" jl w6 vs 1 jl w7 12"
  65. 2005 - 2006 Cobalt Amp & connector pictures
  66. OEM Connector for 06 Cobalt Amp?
  67. Those who have LED's their speedos!!!!
  68. Where to buy CCFL rings?
  69. Buttons not working!!
  70. Tablet as head unit
  71. Bluetooth Question
  72. Backup Camera Wiring
  73. subs in cabin or trunk?
  74. Does it matter what i ground the alternator to?
  75. New radio.
  76. no sound after installing clarion nz500 radio
  77. Oil pressure gauge question
  78. Help with power issues
  79. Rear Deck Subwoofer
  80. Installing PAC SWI-RC
  81. Lo Beams / Fog lights not working
  82. Boost gauge no worky :(
  83. head unit wiring harness for 07
  84. HPFP Connector - harness side - help
  85. HID Conversion Kit
  86. head unit questions
  87. Double din and dic?
  88. Double-din and keep dic?
  89. Double-din with DIC?
  90. Were is the keyless module??
  91. Really Screwed Up...
  92. Anyone put a Tablet in the car?
  93. Advancedkeys push button start walkthrough/review
  94. issues with continuous brights
  95. Pioneer sound package, Radio Issue
  96. What color are the F&R Turn Signal Bulbs
  97. Door chime not working properly?
  98. Defroster, AC, and recirculate buttons not working
  99. LED interior light issues
  100. Cobalt ss SC speakers not working
  101. Amplifier Ground
  102. USB issues
  103. Im lost!!
  104. For Sale
  105. What do i need?
  106. Where to mount Load resistors - Front
  107. Cobalt BASE Fog Lights
  108. Problem need help
  109. Aeroforce turns on ignition and cant shut off car without unplugging it?
  110. Crazy loud alternator whine through RCA's
  111. Problem with my head unit
  112. Help Wiring Aftermarket Single DIN Radio
  113. Strange Door Lock Issue
  114. speedometer bounces around at 75+
  115. Pioneer system front speaker replacement
  116. Started some minor upgrades
  117. killswitch
  118. mystery button
  119. Any audio buffs around? Does this look okay? 06 LT
  120. double din question w/onstar and xm
  121. LED lights identification
  122. Auto dim/compass rearview.
  123. starter continues after key let off
  124. Radio Crack under hard acceleration?
  125. Driver's side headlight turns off
  126. Directed PKE review
  127. key fobs not programing with tech 2 or snap on solus
  128. will this work for fob programming
  129. pioneer f700bt question
  130. AC Randomly shuts off
  131. Equalizer curves on stock Head Unit with Pioneer
  132. a/c wiring schematic please?
  133. Aftermarket headunit problem
  134. Battery upgrade.
  135. h/u question
  136. Reverse Lights
  137. Comming soon to a cobalt near me!
  138. N2MB WOT Box Problems
  139. 3rd Brake light..
  140. LEDs in map lights keep glowing
  141. interceptor accuracy question
  142. fuel gauge not reading properly
  143. Low Effort Sub - Factory Crossover Question
  144. How to watch an iphone 5c on an in-dash unit
  145. Factory RKE
  146. No blinker sound and radio is not working!
  147. Airbag light
  148. LED question!
  149. Adding Aftermarket subs off stock sub wiring
  150. Audio Setup on a budget
  151. Door locks acting funky
  152. Best Option, need advice
  153. Got bass?
  154. RPD unit for sale on eBay
  155. AeroForce Interceptor Not Turning Off
  156. HID Relay Harness Diagram
  157. Stock hu, speakers and sub
  158. Information & radio display randomly quits working
  159. whats the deal, retro problems...
  160. Headlight Wiring Harness
  161. noob wideband question..
  162. If you HAD to chose between these two Double DINS, which would you pick?
  163. Antenna adaptor
  164. Question for you audio guys .?
  165. SOLVED! Optima Battery that fits! (Red Top)
  166. 2007 SS Gauge cluster issue.
  167. No Sound, Power?/Speaker Good
  168. Time for new Door Speakers.
  169. Blowing parking lamp fuse Please HELP!
  170. Hella Horn Install
  171. Adding AUX to 2005 stock HU
  172. Aftermarket Amp for Speakers
  173. led's running down batterie?
  174. underhood main ground
  175. Exact name for 3 projector LEDS
  176. How to remove roof XM antenna?
  177. LED Light Strips under dash
  178. Question on fuse voltage
  179. Need Help With Sub Enclosure
  180. HID's blowing fuses
  181. Passenger side sub enclosure
  182. 06 aftermarket stereo install
  183. Sony aftermarket Stero compatible?
  184. wiring a new amp and subs
  185. Car Wont Start After Mod Instal! HELP!
  186. Passenger Side Headlight Won't Turn Off
  187. How can i fix my sub box
  188. F700BT update
  189. Turn Signal Sound
  190. Wire behind stereo wrapped in foil?
  191. HID Relay Harness Problem
  192. Foglight harness
  193. Bass Rattle
  194. New O2 sensor for LC1
  195. wouldbit be a head ache
  196. stock hu
  197. P4000dvd fluorescent tube replacement.
  198. Mendomar06's build thread
  199. Help with the horn
  200. Fuse location please help
  201. Fuse to tap for constant 12v?
  202. antenna question
  203. Subwoofr and aftermarket head unit wiring.
  204. Tweeter Removal????
  205. Crazy stuff
  206. Predator security systems help
  207. Anyone have the predator alarm system?
  208. Pioneer TS-A6965R
  209. Head unit questions
  210. from little problem to big problem. rear view mirror
  211. Rear sub wiring cut
  212. Fog Lights don't work
  213. Sub box question.
  214. Rear Deck Speakers
  215. Factory Alarm Issues...Please Help
  216. 2010 head unt in my 09 SS Sedan
  217. Heated Seat Panel
  218. Odometer and horn not working on 2008 cobalt
  219. Need HELP! Cruise Control
  220. Installing XM on a car without factory XM or AUX radio
  221. Wiring aftermarket head unit question
  222. Reconfigurable Performance Display Missing Knob
  223. lost chimes and blinker noise.
  224. Help with spyder CCFL LED headlights.
  225. 07 install head unit without GMLAN harness?
  226. Recomendations on Upgrading?
  227. Problem with aftermarket stereo.
  228. Quick Resistor question(s)
  229. Trip Meter Trim Panel
  230. odd electrical issue
  231. question about the XM radio in my 06 SS/SC
  232. OBD ii HUD
  233. DRL's
  234. Train horns :)
  235. Relay wiring question
  236. 06 SS/SC Speaker recommendations
  237. Big 3....Anybody
  238. Why do power plugs always stay hot? Any way to change this?
  239. Stock amp to aftermarket HU
  240. Will Scangaguge 2 read IAT2?
  241. Weird question I'll probably catch flack for!
  242. LED Headlights - Modded Depo Gen4
  243. Fatmat, GT mat, Dynamat, etc.
  244. Heated seat not working
  245. Blower motor getting noisy?
  246. The JL Audio Story.
  247. PIAA light mounting?
  248. Projectors wont turn on
  249. Stereo problems
  250. Gauge Malfunctions
