- No power to steering wheel controls. reverse lights out too
- Aftermarket deck installation
- passenger door lock switch wont work??? switch is fine
- Headlight harness fix
- What Amplifier Should I Buy? HEEELPPPP!!!?
- Will I Bump?
- Stock radio questions
- Factory Remote Start on a 2007 SS S/C
- Time for a new headunit.
- Who can I pay to swap my interior LED's?
- Installed Ghost Lights
- Hid pnp?
- Radar Detector!!!!
- Reinstalling factory H/U, No Power?
- HELP! Blinker doesn't snap back to neutral
- demon eyes
- Tweeter issues!
- new HU to be installed ipod issue?
- swap 05 ss steering wheel to newer style ss wheel
- Whats up with that?
- Gen 1 Halo Help! Bulb Sizes!!
- Reverse Lights not working?
- few questions regarding XM and 06 ss sound system
- help with radio cluster and ignition switch
- LED Map Lights not working
- What bulbs have you guys used?
- Antenna removal/replacement
- Question about subwooder specs
- New Headunit Time, what to choose?
- OEM Radio w/USB port
- Maximizing doors
- Question about Stereo System
- HID Help
- LED license plate, HID reverse Problems
- Sunroof
- New HU Install
- someone come to 08094 (come help install my halo ccfl's)
- Need suggestions for total stereo
- Viper Alarm & Remote Start - Clutch Bypass Issue
- !help!speaker problems
- Weird sound from radio
- Factory XM Antenna on aftermarket head unit.
- need help aftermarket speakere
- Check charging system
- Help Please! - Stereo Replacement Electrical Gremlin
- Adding factory sub to base model balt
- Cant hookup Touchscreen
- Factory XM How To
- RAP Wire, Pic please
- diy color chang halos???
- Wipers Really Slow, & Passenger Window Slow
- P4100 Won't Play Movies from USB
- Can someone please identify this
- HU or Speaker Fail?
- Snow performance hookup help
- 06 SS Antenna help
- Budget SQ speakers
- factory amp and sub
- Bet you cant figure this one out! -Soon to be certified
- what is this wire/plug?
- I dont know whats going on. Radio
- Lights dimming when braking, rolling down window
- No Bass from sub or spreakers
- Starting my stereo build
- Service Airbag
- Want to add some Bump and more Volume!
- Whine Through Speakers With Wideband And Radio
- Pioneer Premier deh-p680mp head unit
- Security Light Solid, no HVAC, good BCM fuse
- Diagnosing Clutch Sensor Problem, ran into unexpected issue, info needed
- Stereo Install
- High Output Alt
- new radio need help
- stock alarm help
- Cigarette Lighter Wiring
- Need Detailed Aftermarket HU Install Instructions!
- Altenator help
- Sound deadener
- Retrofit head light install
- Connectors, help
- Aeroforce interceptor problem?
- Fog Light replacement
- 06 LT with 05ss mp3 radio
- Stereo won't turn on, please help!
- Depo 4th Gen LED wiring
- Horn wiring question
- "Skyline" taillight mod question!
- hvac controls and airbag light thing
- mustang battery update
- Headlight Wiring Help!
- Mirror Rattle
- aftermarket starter with g8 switchblade key?
- What am I missing?
- Help?? Aftermarket hu install??
- Head unit adapter
- SS/SC Stock Boost Gauge Wiring
- all this time...
- where can the stock cd player fit?
- SuperCharger Boost Controller?
- '06 Cobalt w/pioneer upgrade. "RADIO INSTALL ISSUES"
- Aeroforce Problem
- hid?
- Pioneer Iphone 5 Cable Rebate
- Taillights and reverse light on trunk lid not working
- short to ground ? help !
- HID system in a 2007 Chevy Cobalt LS
- 3157 wiring harness for custom tail lights
- Antenna
- Loc question
- Subwoofer box Disected - make your stock steath box boom.
- Front door sprakers intermitantly not working
- What Size Quick Splice For Interceptor?
- wire harness
- Headlights only sometimes come on at night
- PRK LAMP fuse location
- Wires for aftermarket double din
- Headunit install question
- Possible alternate amp bypass method.
- OEM bluetooth intergration/aftermarket hu
- Will my 2Tb external hard drive work on my pioneer avh-4000dvd?????
- Poor quality, lots of variables, need help.
- Front speakers, idiot question
- Aeroforce gauges
- Headlight Harness Terminal Connector
- Not sure how to wire this up.
- Aftermarket Pioneer Doulbe Din Installation
- Problems with fog light wiring!
- Factory Cobalt subwooder enclosure mod
- will GMOS-LAN-04 work in an 05 SS??
- **Need help with compatibility issue, Quick Question**
- dome light
- In car surveillance System
- How to wire factory Pioneer sub?
- Speaker to RCA. Install question for a kicker p10 in my Vette
- Wiring fog lights, universal switch/harness?
- Air space?
- Optima red top
- Double Din Radio Questions
- Pioneer touchscreen radio question
- Installing Stock Radio need help
- Component speakers for Pioneer setup
- Will this fit in a 2006 Cobalt?
- Water coming from under speaker
- MAP Shorty Antenna
- Another sub upgrade thread
- where to order 12v led bulbs for led interior
- Voltage Drop
- Alternator only charging 14.4 on start up
- Sound System
- 2007 raido unlocked still no sound. help
- I get bored and remake old race videos
- Firewall Grommets?
- 06 Cobalt SS System Install, HIDs, Big 3, Etc..
- 06 SS AUX Cable on XM Function
- L.e.d taillights
- Bad Reverse Light Idea is Bad?
- A/C / Heat Works when it wants to
- 2007 Cobalt SS Instrument Cluster & 12v Plug-in issues
- My boring 3 minute video!
- Aftermarket Alt's
- New Headunit Install Help.
- 2010 SS/TC stock pioneer amp question
- Setting Amp Gains...
- Metra 70-2104 Wire Harness, What wires do I need to use?
- Nav System
- What type of horn to get?
- ACC Files?
- what module do i need?
- looking for a mono block amp!
- dual aeroforce and wide band issues !!!!!
- subwoofer issues
- subwoofer issues
- Thoughts? Awesome double din I found.
- Stock Stero Replacement Info ?
- Door lock electrical problem
- Can the stock head unit be a bottleneck for new speakers?
- Noob Wiring Question
- Plastidip? Hmm.
- Need some help. Amps protect at mid volume?
- Door harness?
- The not so Official show off your system Thread
- What amp to use?
- Switchbacks(beat to death i bet)
- Dim when accelerating
- Prosport Evo Boost Gauge Help
- Flickering electrical system. Help!!
- LED 140mph cluster
- Crazy Aeroforce Problem! HELP!
- Headunit Confusion
- Going over RMS speaker value with a clean signal?
- ShoWellEr OEM replacement radio
- axxess aswc steering wheel control module problem
- Dvd/navi factory hookup
- Infinity Reference 6022i
- No radio signal to JVC deck
- Pioneer sub
- Audio help
- front door speakers not working??
- upgrading stock sub
- Bluetooth Hands Free Issues
- No Gauge Lights, No "PRNDL" light
- innovate LC1 help
- indash touch screen headunit
- Car Alarm
- Pioneer Navi
- Aftermarket Alarm
- HIDs or healight probelm
- tell me what im doing wrong with my HIDS
- Where can you buy led tail lights!?
- Jensen UV8 installation help
- Need help finding the right head lights!
- Gen 1 light output difficulties
- Cheapest way of getting decent high beam hid
- Hid kit high beam dim
- Separating Turn Signal Problems
- Audio/Sub gurus...help? Want 8 inch sub(s)
- Interior LED Conversion !!!
- New speakers base model
- XM antenna question.
- Stock Deck Question
- New Radio Screwed up Gauges
- Factory Speaker Replacement
- Fog lights don't work
- retro hi-beams keep blowing fuse
- who's good with audio?
- Help installing a remote starter/keyless entry or programing remote
- Wanted: Rpd
- Antenna cable!!!
- New Radio!
- Complete Wire Diagram
- 2006 cobalt ss CD player
- Best way to mount a iPad in your car?
- push button start kit
- Dual Amp and Battery Setup
- Need a New Battery
- Sat Nav not synching with satellites?
- Places that install viper alarms?
- gauge cluster issue
- 07 g5 radio harness
- new radio issues
- Turn off auto headlight feature
- Adding a capacitor
- opinions on double din HU...
- Steering controls
- Installing New Head
- Just Bought a Kenwood DDX419 How to Install?
- Radio not working please help!
- key fob part number
- Need some help identifying an HID bulb
- Headunit lights went out... any ideas?
