PDA
View Full Version : Electronics, Audio, and Video
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
  1. old school needs help with choosing a system
  2. g5 speedo in a cobalt
  3. need help....so pissed off
  4. Problems after changing battery
  5. Radio Antenna Groud?
  6. Speaker Amp question about ohms
  7. *OFFICIAL* Torque App Mod's
  8. Not reading USB
  9. left low beam doesn't turn on at times
  10. Xtrons TD714 install?
  11. Line out converter confusion
  12. viper smartstart issue
  13. Headlights Dim While Turning the Wheel
  14. 17 inch rims on a 2006 cobalt ls sedan
  15. XM Question for Aux mod
  16. installling a double din radio
  17. High output alt
  18. left turn signal problems help
  19. FS: Pioneer AVH-P4200DVD
  20. HIDs vs radio reception...
  21. VSS Speed Sense wire for Pioneer GPS Stereo installations
  22. Radio Harness
  23. Extra pair of wires in door wire harness...
  24. Help!!!!
  25. Need Help Wiring in new Pioneer Head Unit
  26. Fatmat vs Second Skin
  27. Gmos-lan-04 + kenwood ddx719
  28. LED sizes for controls..
  29. Need Help
  30. Low beams with high beams? (Projectors)
  31. Ebrake Bypass
  32. Horn problem
  33. Optima Yellow Top
  34. Alpine Type-R Speakers and Headunit Questions
  35. kia soul speakers ?
  36. New Remote Starter installed and...
  37. Front door speaker replacement depth worry
  38. Swapping OEM XM Receiver with Aftermarket via Harness
  39. OEM Remote Start 06 SS/SC
  40. anyone have a pioneer app radio deck?
  41. Remote start question??
  42. Lost power to HU?
  43. Weird Security System
  44. Tablet install 06 Redline
  45. Alpine 8" Radio
  46. Would 06 head unit fit in 07?
  47. Where do I mount a crossover if I can't fit spkr wire through the door loom thing?
  48. cobalt boost gauge
  49. Nexus 7 in dash?
  50. Anyone upgraded alts(I know you have Emp)?
  51. Is my amp dead?
  52. Rear camera used for a race camera
  53. 2-DIN HU and SWI-JACK confusion
  54. New design to my subwoofer box!!!!!!!
  55. Keyless entry?
  56. Pioneer AVH-P4400BH Double Din Headunit
  57. Cobalt LS Amp
  58. So finally installed a new deck....
  59. How is the stock stero? Is it loud/bassy?
  60. shift light help...please
  61. HID Problems After Install
  62. Help Installing HID in Gen 1 Projectors
  63. keyless pushbutton start
  64. XM Antenna
  65. Madagascar 3 !!!
  66. Badass DB table I found on SMD.
  67. Question about amp.
  68. New Headunit - All parts? help an electrical noob
  69. HELP with wiring in deck
  70. Blue wire to stock stereo
  71. Jdm Hitler
  72. Aux port
  73. Metra/PAC problems
  74. Looking to go to a double din setup
  75. Steering wheel controls adapted to aftermarket radio???
  76. 06 lsj aftermarket HU install without "special harness"
  77. 2-DIN options
  78. Upgraded systems what are you running?
  79. seat heater wiring help
  80. What is this???
  81. Install SS steering Wheel on LT
  82. Help With Sub
  83. Looking for some advice on audio upgrades on a budget - what are my options?
  84. On a budget - will this setup work? Pioneer 3400BH + JL Audio TR series
  85. Stock Stereo dead?
  86. Bluestar bluetooth/PAL and XM question
  87. Wires to pioneer sub cut
  88. Fuse Tap
  89. Digital Climate Control
  90. Stereo hiss/crackling while driving
  91. Who's hitting what?
  92. Steering Wheel Control Issue.... Reward
  93. iPhone 4 n 4s users Pioneer 4300
  94. Quick electrical question
  95. New Project Audio Guys Help
  96. Door sensor ground?
  97. Power Acoustic/Soundstream Single Din 8.3"
  98. Need help with passenger fuse box
  99. Fuse box.
  100. fuse box removal
  101. Anybody have the Subthump box for the Cobalt installed?
  102. ZZP Hid Upgrade
  103. Thoughts on this setup?
  104. Suggestions on wiring harnesses?
  105. Android Torque IAT2?
  106. viper alarm install
  107. Not sure if my system is wired correctly?
  108. What's that pioneer headunit...?
  109. Aftermarket Stereo No audio please help!
  110. Front driver side blinker
  111. HID problems
  112. Airbag Sensor
  113. EL wire??
  114. SPEC D Projector Headlights Help
  115. Gaming system install
  116. replace stock radio
  117. 6 channel amp ?
  118. 06 Cobalt radio problems
  119. Halos work HIDs don't
  120. Amp Problem
  121. Is there a way
  122. Aftermarket Subs
  123. Amp problem?
  124. Remote Start Install?
  125. Remote Start Question
  126. AVH-p4400 back up camera
  127. stock head unit relocate
  128. IPod armrest dock v2.0
  129. is 2 10" Alpine Type-R too much for a Cobalt?
  130. pioneer z130/140bh video bypass
  131. Front speakers
  132. Sub problem
  133. android apps
  134. Front Passenger Turn Signal
  135. fog lights on with high beams
  136. HID conversion...
  137. Word of warning
  138. Wiring Harness
  139. Driver's side headlight not working (low beams)
  140. wiring question..
  141. wiring harness
  142. Pretty sure i blew out my rh door speaker...
  143. Citizens Band Radio
  144. Pioneer X940BT install, no sound
  145. Car Audio people
  146. stock pioneer sound system
  147. Sub/Amp In my new car
  148. Stock head unit/amp question
  149. headlights (low beams) stopped working
  150. 2 options
  151. Second Skin's Summer Sizzler Giveaway!
  152. headunit help?
  153. New member in need of urgent help!
  154. Ac fan speeds not working
  155. Reset keyfob
  156. BCM Damage
  157. Blew Stock amp.. now what?
  158. ipod charger on non usb radio?
  159. After Market Tweeters
  160. 2009 cobalt ss question
  161. Speaker Troubleshooting Suggestions?
  162. HID kit?
  163. Converting to power?
  164. Need help with amp
  165. Electric fan switch?
  166. using onstar oem mic for aftermarket headunit
  167. in search of
  168. reverse signal
  169. Opinions wanted on my projected setup
  170. What 10'' Sub fits the stock Pioneer box? Like actually fits?
  171. tweeters too bright
  172. Stock Radio Display Problem
  173. electrical help
  174. starting to get a sound system put together
  175. Head unit install, no sound
  176. Question about xsvi-2103-nav install with factory speakers
  177. antenna adapter for 09 cobalt ss
  178. Adding steering wheel controls
  179. XM radio won't activate, how do I do a "hard reset"?
  180. What kind of XM antenna and where is it located?
  181. 07 radio in 06
  182. Where to mount iphone? RPD unit and Radar
  183. XM Radio With Factory Deck 05-06 SS/SC
  184. Are these speakers better than my stock pioneers?
  185. Projector Headlight Dim
  186. Wiring help please....
  187. Adding amp while Factory powering speakers
  188. Updated Bluetooth module
  189. Pioneer AVIC 700BT Issue
  190. Splice Pack SP200
  191. Saab hu
  192. Subwoofer Review
  193. headunit help please
  194. Is it hard to install the 10" subwoofer?
  195. Trunk dimensions?
  196. switchblade key for our car?
  197. DNX 7200 goes into protect mode
  198. Passenger side Door Lock not working
  199. ASWC and Pioneer Video Interface Cable
  200. wiring problems
  201. I need stock door speakers!
  202. Hard wood floor in the trunk and sound dead questionening
  203. AEM AFR gauge
  204. turn signal wiring question
  205. Re-did my trunk over the weekend.
  206. Harness Question
  207. Pioneer AVH-P2400BT
  208. New Car Stereo Setup Help
  209. Problem with stock HU
  210. USB port Amperage output
  211. what wire do i connect the Axxess ASWC to
  212. Free XM ftw!!
  213. Stock HU XM option just disappeared...
  214. Question about fog lights
  215. Wiring from the Engine Bay to the Interior?
  216. Setting the alarm
  217. Radio cutting out
  218. NeoWedge Bulb Size??
  219. Ipad2 installed!
  220. sub under seat
  221. MAP LIGHT LED's
  222. Anyone know how to make custom wallpapers for Alpine Headunit IVA-W200?
  223. Need help with Head unit
  224. Glowshift gauge install ??
  225. Aeroforce Interceptor Wideband Installl
  226. mini amp? replace stock HU?
  227. Comp. Package Boostgauge/Ladder Tach question
  228. USED interceptor,couple questions
  229. who wants a howto for usb reloacate cobaltss
  230. switchback problems
  231. wanna install pioneer double din on my 09 ss
  232. Sedan LED 3157's bright enough?
  233. Choices on sound system hook up
  234. Demon Eye Mod Question
  235. Avi
  236. Remote Start
  237. Weird Sensor/Electrical Issues Need Help
  238. Replacement head unit & steering wheel controls (again)
  239. Steering wheel bezel
  240. I can haz king kong?
  241. Where can I buy red CCFLs?
  242. Oil percentage
  243. 12inch Type-R ported vs. sealed box
  244. Speedometer Change
  245. can anyone help me out?
  246. Car Computer 1 year Later! "Vids" Voice Control
  247. Installing additional amp w/ pioneer system
  248. To those who replaced Viper L3 2-way remotes
  249. Mkulrey, can you come up with something like this?
  250. heater and a/c mode door opperation
