PDA
View Full Version : Suspension
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
  1. Lowering springs
  2. Taking struts off
  3. Should I DIY or pay for it...
  4. Brake Fluid
  5. Slight "clunk" noise when turning the steering wheel
  6. Cobalt LS spring questions!!
  7. Douchebag CABs
  8. rear suspension sound (video inside)
  9. S/C Front Sway bar
  10. Help
  11. Coilovers for a 2008 sedan ls
  12. Airlift air ride kit
  13. Coilover Issues
  14. Steering angle reset. Anyone do one?
  15. Stock springs or something else?
  16. steering question
  17. Brake Bias Adjustment
  18. Ksport coilovers
  19. Process of hub swapping
  20. help with lowering rear shocks/springs (coilovers)
  21. New suspension recommendation 2009 LT 4dr
  22. Hsd coil over install: shaky ride
  23. Loose feeling when turning wheel.
  24. Rear transverse bar idea.
  25. Insight Needed A.S.A.P
  26. Might be back in the cobalt game
  27. strut bearing fix
  28. Raising the Engine and Transmission
  29. Coil overs with Koni's on the rears
  30. Clunk
  31. need help strut experts
  32. Help! Replacing Driver side front Lower Control Arm
  33. whats your currebt set up?
  34. After probably too long... My Cobalt is getting upgraded to the FE5's!
  35. help!!
  36. Control arms
  37. Front end clunk
  38. ECS Blinks and steering weird after coilovers
  39. b&g rear springs
  40. LNF new rear brake issue!
  41. Bwoody swaybar endlinks question
  42. LNF to Lsj breaks
  43. Brembo calipers pin issue
  44. Rear axle beam LSJ can it fit LNF?
  45. Rear Beam Bushings
  46. Ebay Struts, Quick Struts, Anybody use them?
  47. OEM Brake Line Thread Type?
  48. Best Rotors?
  49. Need Wheel Spacer Sticky
  50. rear suspension problem
  51. Drum to dis
  52. Coilovers
  53. Rear disk conversion - 2006 LT
  54. Will these control arms for my LSJ?
  55. Clunking in rear after installing coilovers
  56. Control arm and ball joint
  57. Part # for bolt on control arm?
  58. Bought Powell's YYZ V5!
  59. Steering rack replacement
  60. Rear coil adjustment?
  61. AC Delco Rear Brake Part #
  62. Front end sitting high
  63. KYB Excel-G struts?
  64. Front strut too long
  65. Coilover Support
  66. K sport coilovers
  67. New Suspension Setup ideas/help
  68. what color should i paint it?
  69. Axle bind check up
  70. Softer front springs for better launch?
  71. Cradle member brace/skid plate for the Chevy Cobalt
  72. Axle bind??
  73. Seized Coilovers
  74. G5 rear sway bar
  75. 06 Cobalt 2.4 Control Arms
  76. squeaky breaks
  77. Coilover Tuning
  78. questions
  79. Need some Suspension help
  80. SOLID info ON CUSTOM BC COILS
  81. Bags
  82. New Rotors
  83. New Springs Settle Time
  84. cobalt ss suspension?
  85. HELP Vibration Coming From Front End
  86. suspension recommendations
  87. Getting Stance Coilovers....
  88. ★★★ Fortune Auto 550 Coilovers - EXCLUSIVE ★★★
  89. h&r sport spring bump stop
  90. Suspension Clunk
  91. The Official SS/NA and Base Model Spring Thread
  92. Any 2.4's on H&R Springs Part# 50735
  93. Struts and Shocks
  94. fe5 question
  95. Bent beam axle?!
  96. Rear beam bushing tool
  97. BPS Short Throw Shifter Knob pattern not lining up
  98. abs delete
  99. Caliper differences between 5 lug Cobalt and G5?
  100. SSC & B&G Lowering Springs For Sale. Need Gone ASAP!!
  101. OEM brake parts w/o OEM pricing
  102. Spring number education needed
  103. Ball joint
  104. OEM rear springs
  105. Fe5 Strut part number question
  106. Best wheel/hub bearing for CSS or IRL?
  107. TC Struts - What springs
  108. Suspension Question
  109. Any info out on OTTP springs?
  110. Differences in Steering Gears (rack & pinion)
  111. Hard front springs = wheel hop?
  112. Zzp control arms
  113. moog rear axle bushing on a cobalt ss/tc?
  114. Installed Road Magnet Springs
  115. Car still shaking after new tie rods + alignment.
  116. Outer tie rod end won't come off.
  117. Air bags
  118. D-Max tension rods for a 240sx on my SS/SC?
  119. control arm bushings or something else
  120. Want to use OEM rear springs
  121. coilover dampening
  122. Yyz + konis vs coilovers for 500-600whp
  123. Time to replace suspension
  124. Any Reviews on St Suspension Sway bar
  125. Still A Clunk
  126. CCS and B&G springs for sale
  127. help me find suspension part plz..
  128. ZZP Big Brake kit issues?
  129. Top nut size for rear CAB bolt
  130. 18s xxr wheel
  131. Rotors do crack
  132. Sway issue when turning
  133. Symptoms of a bad strut mount?
  134. bilstein struts and shocks
  135. Do I need a new rear axle beam?
  136. Rear camber
  137. Do Cobalt SS springs fit HHR?
  138. Bouncy stance gr+ coilovers
  139. coilover install questions
  140. Replacing rear struts help?
  141. should I buy them new or used?
  142. ABS light on after having car transported
  143. quick question regarding installing axle
  144. Suspension chirp.
  145. Powell rear sway bar
  146. Suspension components!
  147. I'm glad I checked.....
  148. Brake question.
  149. Coilovers with 16" wheels
  150. B&G Springs
  151. intermediate shaft slight play
  152. New Design Moog Control Arm Bushings
  153. Shorter rear shocks for coils
  154. Knocking noise coming from passenger side front driving me crazy!
  155. 05-2010 SS Model Wheel Bearing
  156. 05 SC Strut Question
  157. Suspension upgrades.. Idea's guys ?
  158. ottp vs powell spherical bushing
  159. Random clunk in suspension
  160. legit or not?
  161. this will sound ridiculous...
  162. Squeaky noise -_-
  163. Power steering question
  164. suspension question
  165. Crate Engine Wheel Spacer
  166. Question about wheel hop
  167. linking after strut replacement
  168. FE5 suspension and everything else it fits
  169. super handling question
  170. need new rear bump stops? dont want to pay for oem?
  171. sway bar bushings
  172. 5 lug to 4 lug
  173. h&r vs canuck motorsports
  174. Alright, I have an alignment question.
  175. Need some help
  176. torsion bars
  177. Post your pad/rotor setup!
  178. Stance Coilovers Rear Squeaking
  179. Coilover sleeves - ok to use for a quick fix?
  180. Dorman FE5 replacement control arms?
  181. Flush Question
  182. Moog Sway Bar Bushings
  183. Anyone install ebay strut tech front strut kit Unhappy with new ride height?
  184. after powell
  185. New Suspension Needed! Please help.
  186. craptastick plastic
  187. Pressed on ring for front brakes?
  188. stance gr+ major issue
  189. Broken OE Rear springs
  190. Bled brakes repeatedly, still soft w/ car on ***HELP***
  191. Rear axle 2006 cobalt ss compatibility
  192. I joined the club!
  193. 47k Miles upgrades/replacements
  194. Creaking noise from front end
  195. Sway Bar Busted due to my superhuman strength -NOT
  196. Reputable Websites To Buy Stance Coilovers?
  197. bc coil overs vs yyz spings
  198. Squeaky Rear End after Ksport Coils Installed
  199. SSC springs installed
  200. My review on power Grid endlinks from powell
  201. Steering wheel shaking
  202. Spring rate selection
  203. Looking to trade B&G springs for SSC
  204. wheel cylinder removal
  205. Stock springs?
  206. LSJ caliper rebuilding service
  207. b&g S2K Suspensioms kit for cobalt
  208. Pulling when braking
  209. Looking to replace my suspension
  210. Stance GR+ coilover issue
  211. Excessive "torque steer" or tramlining
  212. not having a good day
  213. 4 lug to 5 lug switch with adapters
  214. Wobble surprise
  215. SSC springs/ one side higher
  216. replacement front struts with YYZ's. and a small rant
  217. 4x100 drum to 5 lug disc swap NON abs questions
  218. Stance coilovers
  219. fitment issues????
  220. H&R springs finally
  221. Spring spacer/pucks?????
  222. 5000-miles of daily driving on PRS spherical bearing control arms
  223. Brembo squeal
  224. NAPA pads and rotors?
  225. decent car jack?
  226. Broken Rear Eibach Sportline
  227. LSJ Brakes Pad Selection. Street + AutoX
  228. Stainless Steel Brake Lines - 2009 SS
  229. Need some tech advice. Coil spring insulators
  230. Noise in Front End
  231. H&R or B&G ?
  232. rear shock bolt. bolt was spinning bushing inside the rear shock.
  233. Stance Coils
  234. Knocking from wheels?
  235. How can you tell if you need rack spacers?
  236. Which springs too choose
  237. Bumpy ride, not sure why.
  238. Coilovers parts???
  239. Cutting off sway bar link bolts...FML
  240. D2 Coilovers Front End Link Mounting Tab
  241. alignment problems
  242. ZZP Strut Tower Bar
  243. Megan Racing Coilover Rear adjustment
  244. When upgrading to FE5 + new springs do i need to upgrade the mounts and endlinks as w
  245. Smooth rotors and replacements
  246. moog sway bar end links
  247. Spring Help
  248. Rear Brake Calipers
  249. 'Heavy Duty' springs
  250. new struts what else do I need?
