PDA
View Full Version : Suspension
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
  1. FE5 brands
  2. Handling worse after lowering?
  3. Knocking sounds in front suspension
  4. sportlines. Wich way's up... doh
  5. Balts on Air-ride
  6. BC coilovers?
  7. Jic cobalt coilovers anyone?
  8. Couple questions, things to look for.
  9. Carbotech Street pads for TC
  10. very loud bang while driving!!!!
  11. lowering springs!
  12. Shocks 101
  13. Installing Stance Coils Today!
  14. Gotta reduce wheel hop!!
  15. R1 Concepts Review
  16. suggestions
  17. lnf suspension?
  18. replacing springs
  19. Help with Rear Suspension.
  20. Installed ZENN springs
  21. bwoody motor mounts
  22. Looking for strut bars
  23. R1 Concepts = FAIL
  24. difference in Caliper
  25. Lowered on Ksports
  26. Base model lowering springs
  27. Suggestions for rotors & pads?
  28. Emergency Brake + No Brake lights
  29. In need of help.
  30. Brake kit question
  31. Placed my order with R1 Concepts
  32. Spring selection for tc
  33. is this guy bullsh--ing me?
  34. sportlines installed today
  35. Stance GR+ Problem
  36. New D2 RS Coilovers
  37. new pads now big problem
  38. What endlinks to get
  39. Coilover Question..
  40. L-CABs comparison
  41. Front Link Kit keeps quitting on me
  42. What coilovers
  43. Working on my suspension!
  44. Brake fluid suggestions
  45. Rack and pinion part number and questions
  46. Clunking
  47. Ride height after new strut and springs
  48. Eibach front and rear sway bar review
  49. ss/sc springs installed on 2lt coupe
  50. Quick Break Question for all cobalt owners!!!
  51. Zzp control arms
  52. Koni rear shocks installed on TC
  53. question about H&R Race springs
  54. Koni shock adjustment question
  55. drifz wheels
  56. Wheel Spacers
  57. Rack Spacers.
  58. Pedders question and some other stuff
  59. lowered on stance gr,slight issue
  60. Rear spring problem: H&R Super Sports
  61. differences in the master cylinder between the ls and ss/tc
  62. The NEW 1.5" "XXX" Sway Bar
  63. Which route to go...
  64. alignmnet while lowered
  65. how good are these pads?
  66. remove drum??
  67. Rear Alignment
  68. im cheap
  69. Pedders and Winter
  70. Rear isnt very low?
  71. Coilovers
  72. Koni Rear Shocks Only?
  73. green stuff front pads LNF
  74. Fe5 for me??
  75. warped rotors or suspension problem?
  76. Ride Height
  77. My suspension sucks! (Help)
  78. FE1 control arm bushing question.
  79. Sportlines
  80. Brembo brake conversion HELP!
  81. EBC Sport or PowerSlot rotors?
  82. anyone on dropzone springs?
  83. Bump steer
  84. Just lowered the car on CM's springs
  85. Break Systems
  86. Brake Paint help
  87. ss/sc spring drop on a 2lt?
  88. rear spring issue
  89. Pedder question
  90. lowering cobalt ls
  91. Need Some Opinions
  92. FE5 suspension vs FE5(LNF)
  93. Brembo Pedal Play
  94. quick question
  95. Coilover spring rates
  96. questions about FE5 install
  97. Control arm bushings/Homemade press
  98. Vibration Station over here..
  99. Back of rotor grooved front smooth
  100. NOOB with a suspension question
  101. Rack spacers caused noise
  102. FE5 lowering springs...
  103. Camber plates
  104. Time to order some springs! Om nom nom
  105. Oh noes I haz shiny rotor!!!!!
  106. First time needing rotors and break pads
  107. Control Arms Question
  108. Wtf zzp.
  109. Positive camber?
  110. SSC Lowering Springs - 3 Weeks Later
  111. Eibach Spring Cracked!!!
  112. Rotor info TC
  113. G5 GT Lowering Question...
  114. OTTP/Powell 1" rear sway bar is definitely not sitting right.
  115. Anyone lowered and towing? Lol
  116. loud calnk and rattle from the rear
  117. ABS on an LS
  118. Stiff and low
  119. Where to get R1 Concepts?
  120. Strut bar question
  121. Looking for new stance.
  122. Link kit question
  123. Saturday's install
  124. Hard pulls
  125. 1.5" Rear Swaybar?
  126. Springs, what should I do?
  127. issue with pedders handling
  128. Cobalt Turbo Rotors Now Available!
  129. suspension help please!
  130. ZZP strut tower bar
  131. Rear coil adjustment?
  132. I will Need new brakes soon...
  133. KW V2s or Stance?
  134. Rotors
  135. im stuck on what coilover system to get.
  136. I know, I know, ANOTHER BRAKE THREAD!
  137. B Pillar Bar
  138. FE3 vs FE5
  139. Brakes Upgrade! 2.4L SS/NA
  140. Dropped on KSports
  141. lowest lowering springs out there?
  142. Suspension sounds like a matress during sex...
  143. 09 ss/tc rotor install problem
  144. Suspension advice?
  145. Lowest drop springs??
  146. thinking of dropping a little, looking for advice...
  147. Eibach Pro kit w/ stock struts/springs
  148. Brembo Rear Brakes
  149. B&G s2k sport suspension kits
  150. Stance ?
  151. Springs for LNF on LSJ
  152. rear suspension problem help!!!
  153. Installed Rear Shoes
  154. Pulled into the Garage after running errands
  155. coilover
  156. pedders for sedan?
  157. finally here!
  158. Problems after H&R Lowering springs - Alignment or What?
  159. Calipers and pads
  160. Tips for Pedder install
  161. Spring plate alignment
  162. FE3 Links dead, replace to FE5? Possible?
  163. What is the difference with these springs?
  164. Sway bar question.
  165. Clunking Noise only when wet
  166. cobalt ss bottoming out bad
  167. Powell Racing SS/TC ss brake lines kit
  168. Springs
  169. BC racing too high in back
  170. sportlines
  171. Suspension repair under warranty
  172. SSC + FE3 + Strut Tower Bar Installed
  173. opinions
  174. control arms
  175. Interest in Good Coilovers for Cheap?
  176. Coilover Search!
  177. Think i found what i would like
  178. SS/SC Brake and Rotor Questions
  179. D2 Install Update
  180. skid plate
  181. Pedders installed wrong
  182. need help on strut choices
  183. Koni's VS Stance
  184. KW Coilovers Opinion? Good or Bad?
  185. Cradle help
  186. 09 cobalt ss/tc suspension
  187. suspension help
  188. Air Ride Help
  189. SSC & Strut Tower bar...
  190. fuckin rear brakes
  191. 2010 Cobalt with Sport Appearance Group which Suspension?
  192. springs--pictures
  193. Coilover install
  194. ion redline springs question
  195. Eibach Sway Bar Kit Problem..
  196. Rear sway bar comparison
  197. do I need alignment?
  198. Help new guy lower his slow car?
  199. I can not find this rattle, can you?
  200. I need new Coils under $900 (need opinions)
  201. Brembo Brake Pads? HELP!
  202. Alright Now Your Personal Sway
  203. Supporting Vendor that...
  204. Need some help from someone, Replacing shocks and struts. want to lower?
  205. ? about preloading the suspension
  206. Stance
  207. ABS light
  208. Help Just Blew my struts
  209. 20% off 05-07 SS Stainless Steel Brake Line Sets @ PFYC - PartsForYourCar
  210. Koni Install?
  211. Official painted calipers thread!
  212. Steering response and turn in
  213. Apex springs
  214. megan racing springs
  215. Eibach Sportline Lowering Springs
  216. Got my pedders installed. pretty sure i dicked up the rear ones tho.
  217. Before I Buy
  218. stabilizer bar links
  219. Help Removing Front Stabilizer Bar
  220. Creaking noise
  221. Control Arms bushings
  222. Bushings
  223. anyone ever bought these springs ?????
  224. Torsion bar
  225. How to tell whats my suspension?
  226. lowered ppl
  227. Bushings
  228. having problems with a left pull after eibach prokit sprin intsall... please help
  229. FE5 struts and shocks with peddar springs
  230. Brake question from a G6 owner ...
  231. New brakes at 17K miles??? Seriously??
  232. driver back side lower
  233. Steering Rack Spacers
  234. stance vs bc coilovers....pics wanted
  235. pretty bad squeaking
  236. Ebrake Problem
  237. Something shaking
  238. Cobalt to Ion
  239. I hear some clunking in the back with CM Springs in my 09 SS/TC.
  240. SS/TC Front Brakes not Working
  241. Coil spring Choice help choosing
  242. Struts should always be replaced in pairs? Correct?
  243. [FIXED] Annoying Rattle
  244. Sway bars for 09 SS/TC?
  245. suspension noise from front right wheel area.
  246. Popping/knocking noise when turning?
  247. springs from ZZP
  248. struts
  249. D2 racing coilovers?
  250. Broken rear springs. Eibach warranty?
