View Full Version : Suspension
- sway bar links are they the same?
- suspension tech?
- just dropped it with sportlines
- SSC springs vs eibach sportlines
- this is why not to install urethane control arm bushings
- what coilovers
- AG Springs
- Question for our suspension gurus, reguarding shocks
- New Brakes, Need Suggestions
- H&R Race but says not for SS...??
- Ground Control Coilovers are Being Developed!!
- Suspension Setups!
- CA Floor Brace
- Stainless Brake lines
- Auto-X
- controll arm bushings
- Canuck Springs the same as SSC?
- What's everyone's suspension setup?
- New brake pads??
- Can I Put Coilovers W/o Lower Struts
- need camber adjustment or new camber and possibly shim.
- Cobalt Addiction CA#1 Springs
- Ss Springs On A Lt
- Sway bar
- Question for ALL who have lowered SS S/C cars
- Eibach Pro kit vs Sportline
- BWoody Adjustable Rear Sway Bar??
- Would GM notice?
- Any 2.2's on Sportlines?
- Before and After: Eibach Sportlines on 2.2L coupe
- Trying to get rid of drum brakes on 2.2 coupe
- BWoody traction bar
- Ground Control Coilover kit
- SS/TC Brake prices!!!!
- Brake questions
- help with sway bars
- big brake kit??
- eiback sportlines on base/SS suspension
- E-Brake Squeaking?
- Springs.
- Which is the better strut brace?
- So I just order rotors...
- Problem with powerslot rotors
- dumb question but i need opinions
- I finally cracked.. Ordered new springs!
- strut/shock question
- What do you think about ksports lowering springs.
- lower control arm question
- vogtland suspension
- progress lowering springs
- Best Place to Purchase Springs...
- need opinions
- Quick Question On Stoptech rotor and hawk pads install
- Need opinion on suspension
- KW Variant 2, anyone?
- best place online to find eibach's
- H&R Sport 2s??
- Strut Tower Bars
- anyone know how to stop or reduce some crazy wheel hop on launch?
- Drum for Disk?
- Stupid question..
- Ssc Springs
- Coil overs suck
- drilled and slotted rotors with pads ordered!
- were is the cheapest place to get drilled and slotted rotors and pads
- Koni rebound adjustment help
- Suspension tuning on a sedan?
- stop tech rotors??
- Koni instulation question
- Help please (sportlines)
- Need Alittle Input
- lowering
- does anyone have the CA springs
- Vendors: Poly Steering Rack Bushings
- Rotora Brakes
- K Sport Springs
- Got a spring question...
- FE3 vs. FE5
- Koni & Sportlines or Coilovers?
- help with springs
- Spring ride in general?
- Springs bottoming out, damaging my car?
- Need Koni Shocks!
- are these springs any good ?
- ion springs vs cobalt springs
- lowest springs for ss/sc
- Axels
- Strut Tower Bars
- Traction bars
- sway bar removal
- Broken Cobalt Knuckles???
- Sportlines or progressive
- Any pics of Cobalt SS/SC with SSC Springs?
- Help me help my 2.4L Friend w/ Eibach Pro-kit
- Who sells the KW1 variant coilovers?
- Eibach alignment bolts go where?
- SS/SC springs on a LT
- handling and lowering
- Rebel Autoworx Subframe bar
- Eibach Springs are being shipped : )
- Coil overs
- bump stops?
- Alignment only?
- Is it possible?
- Anyone running Wagner thermo quiet pads?
- Who makes shocks/ struts
- Biggest increase in Suspension for performance
- Progress Sport Spring
- Suspension Mount-2, D4-1!
- UMMMMMM....springs??
- morse ceramic pads
- Camber Plates
- here's an idea?
- how are the sportline springs?
- please help
- just got the tenxo r springs but i need help
- Ground Control
- Koni Shock/Strut Question
- Help On Springs
- ss supercharged stock springs for sale.
- How to Rear Brake Job?
- Need Some advice w/ Sportlines !!!
- suspension problem
- Are all camber kits for cobalt the same?
- any input....
- Lowering?
- Got my Coilovers today
- H&R Coilovers more comfort than KW V1?
- eibach springs
- Are my brakes FRACKED? 56k no
- Eibach Sportline Question? New member help please
- I've been lowered... Havent a camber kit yet???
- Thunk sound in suspension
- What To Do???
- Passenger side sound
- Question about Eibach Sportline ride quality...
- Camber Kits
- Which to get for my LT Coupe
- Easy lowering Spring Question
- Knocking on Passenger side
- Drag bags review
- springs problem!!
- lowering and handling
- B+G Cobalt Suspension have finally arrived
- Rotor Problems?
- Rear Brakes
- Which Coilovers Should I Get
- which springs?
- Twin Subframe Brace (RAW)
- Has anyone tried these JDM lowering springs?
- SS/SC springs question
- subframe question
- So...I've been out of the loop
- LNF SS/TC Brembo Calipers Part Numbers?
- Bought new stuff
- BC Coilover Question
- drilling 4 lug rotors to fit on 5 lug hub
- rotors
- KW V1 Coilovers with LSJ Downpipe
- Progress Springs vs. SSC Springs
- to all who are using tenzo springs look here!
- How to lower car?
- Drag Bags?
- knuckle and control arm
- spring install
- Rear Brake Help
- what is the difference between eibach sport and pro springs?
- Anyone Intrested on a GROUP BUY on Baer Big Brake Kits
- EBC Rotors or Powerslot Rotors.
- Research on Eibach Anti-Roll Kit
- front sway bar, upper front strut bar, or both??
- LSJs only, is the Progress rear bar worth it?
- Need shock change. Question
- Should i lower???
- Bad tire wear, w/ H&R springs?
- Suspension Question before I order
- Another sportline question
- LOWEST Coilovers Out There.
- dc strut bar
- Lowered cobalt now pulls to one side.
- brake noise
- suspention techniques sway bar kit
- Hit a curb going sideways ...now wierd noise
- which springs should i get??
- will springs fit on
- Got Hydrolics on the Cobalt?
- wrong sway bar bushings
- which brake pads????
- Lowering and Struts for the SS/SC
- Lowering my ss/sc
- Brake noise
- ag springs?????
- squeeking brakes
- Lowering Your Car...
- ss/sc springs on ls
- need help
- New Suspension Find
- Bigger rotors....
- Lowering Question
- Brake problem???
- DC-2 Strut brace question
- Negative Camber issues
- Powerslot 5x110 Rotors Are Back In-Stock at Gravana
- Help me out please
- 2inch drop
- Where are the front bump stops
- What are the best coilovers for street use and rare track use!!!???? POLL INSIDE
- how many actually bought...
- H&R or Eibach
- ATTN: Hawk HPS Pads - who has them?
- urethane, motor, mounts ??
- eibach prokit
- Ksport srings
- BC Sports Coilovers and Progres Rear Sway Bar
- vibration at WOT
- Eibach Rear Sway Bar
- which brake pads are safer?
- Suspension
- Pro Line vs. Sport Line
- Normal.. Or Not??
- just curious
- Cobalt FE5 Suspension Pkg
- Cold Weather: Creaks In Suspension
- Redstuff ceramics or Hawk Ceramics
- Cobalt SS.SC suspension check
- NEW Progess Rear Sway/Eibach Sportlines/DC Strut Bar
- Where's the best place to get the Progress rsb?
- Low Dust Brake Pads
- Just snagged a set of Rotors and Pads off ebay... What do ya think?
- NEW Suspension Parts
- How to know when you need new rotors?
- Goldline Springs Install..Need Help
- Hawk HPS vs. Ceramic
- lowering springs
- does anyone have any suggestions?
- lowering springs
- poping noise from front end after lowering.
- SSC Springs
- need new rotars: opinions/options?
- jbp coil overs
- OK, So I think I might have figured out the lowering springs vibration issue...
- Brakes Rotors
- Alignment with the Pro-Kit?
- how low can i go?
- ? bout lowering a SS/SC
- Cobalt SS/SC lowering Springs 1.0/1.3 suggestions
- Eibach Swaybars
- How many miles on Sportlines? Still Reliable?
- KW Variant 1 Coilover Question
