- Strut problem. Need help
- Anyon who upgradedstruts or has coilovers
- Cquence Brake rotors?
- some questions before i buy coilovers
- new girl with suspension question
- New rear shocks & mounts, new stance
- Cheap lowering other than heated springs or cut springs
- loweing 2.2
- 4 lug to five lug?
- springs
- rear seat bottom bracket THE TRUTH!
- bad struts???
- So Im thinking air ride....
- About to install Eibach sportlines...
- front stuts
- How low can you go?
- lowering my car
- 06 SS steering problem
- Metal on metal rubbing noise....
- Eibach Sportlines!!
- SRV Brakes Soon
- Help... Clicking noise from rear wheels
- KW Variant 2 Install Help PLZ!!!
- front sway bars
- stupid ball joint
- stupid e brake
- Brake line questions
- a couple of inches??
- Springs-only upgrade
- Tire Hitting Fender/Wheel Well
- H&R springss
- Eibach or H&R????
- cutting springs
- Zenn Spring HELP
- Front spring ?
- Negative camber
- Sway Bars?
- Sportlines or SSC?
- H&R Springs?
- ARK Strut Brace Review
- eibach rear sway bar
- Will SS/TC springs fit an Ion?
- Finally........AN AWESOME SWAY BARS SETUP!!!
- OMG...The box arrived!
- Spring/Strut Decisions Decisions
- SSC Springs Questions
- Brembos on 2008 Sport Coupe
- dump ottp cabs question
- Progress Springs
- Suspension ? On the eibach pro kit
- Warranty and suspension
- A few questions about lowering springs.... on the wall about buying
- Funky noises
- woot woot ...axles and cabs oh my..lol
- Advice on building from the bottom up?
- Does Eibach make 2 types of front sway bars
- To people with Eibach Sportlines
- Thoughts on Peddars Coilovers
- struts/shocks for ss/sc?
- Control Arm Bushings
- File complaint on brakes
- Rear Rotors going bad?
- Front strut help!
- SS/SC suspension swap with SS/TC suspension
- Who can install lowering springs?
- Strut mounts
- Control arms...cabs...questoins
- Front end knock (and solution)
- ark vs eibach
- Brake pulsing question
- rear strut bar..??
- springs
- bent rear suspension on my 08 SS/TC
- springs
- Spotlines broken?! HELP!
- Bend my struts and found this great deal on ebay....are these any good???
- Cobalt SS/SC Strut Mounts
- Bump stops- Cut?
- how do u
- To those who know suspension
- Need some suspension help...
- 215/35/18 with Eibach Sportlines?
- Installing front lowering springs...help
- control arms???
- genuinesaab rotors
- ss/tc front brake pads
- Brake Rotor rust?!!?
- lowering the cobalt
- NEW in box TC rear rotors. how much?
- Progress Rear Sway Bar on the SS/TC
- Wheel shake
- Sway Bar, TTR or OTTP
- lowering my 2008 cobalt ls
- use of stock jack after lowering
- I Gotz Some Brakes!
- '06-'07 Cobalt SS rear springs question
- SSTC springs on an LT?
- Suspension Info!
- SUSPENSION qUESTION.
- ss/tc shocks/struts
- rotor size
- Picked up New Progress Springs!!
- B&G VS Sportline
- (potential)group buy for Pedder springs
- Posi Ceramic Brake Pads- Reviews????
- Thumping noise on passenger side
- Lowering springs on SS/TC with 3" exhaust
- Bump stops
- Bump stops
- K-sport making clunk sound!?
- New rotors
- Quick Rotor Installation Question
- ss/tc lower??? worth it?
- brake lines
- Just to make sure I'm not an idiot
- lowering
- EBC Rotors & EBC Reds
- Brake Fluid
- keep ark coliovers or get lnf suspension?
- HELP! H&R SS/SC springs on SS/NA ????
- Control arm bushing install question
- brake questions
- Toe Out Toe in rear adjustment
- Odd Vibration
- Quick Question about how I put my brakes back on
- a few questions.. issues..
- about rear dics convertions
- Looking to buy new rotors,Thinkin maybe R1 Concepts, Need some suggestions!
- ss on ls
- sportlines on ls- RR sets higher than LR
- I just wanted to say
- SS/TC rear fender lip factory rolled?
- Why do the TC's rear brakes look like they're unused?
- Help!!!!!
- Air Lift Company "Cobalt Kit"
- H&R Race Spring/Eibach Sportlines. Pros/Cons
- went with sportlines!!!! bumpstop Q?
- Z06 brakes?
- 2.2 pads + rotors suggestions?
- Rear sway bar without drop
- took my car in for work...
- Opinions on EBAY brakes...???
- Ride Quality
- quick spring question
- Brembo conversion question
- why do Cobalt's sit so high as built?
- Ark GT-F Springs
- Fixing my brake squeak today..
- Crossmember/traction bar?
- eibach LNF spring release?
- FE5 Conversion
- Suspension Setup
- Slip On Coil-Overs...
- What Vendors Sell G2 Caliper Paint?
- Buying new rotors
- handling questions
- Suspension Wierd Noises
- Sportlines for the TC?
- Spring's
- Need Help With Rotors ASAP
- warped my GMPP rotors
- Need Sway bar end link tourqe specs
- Please help now
- Pedders springs
- 09 LT with SSTC springs?
- cutting bump stops for ark springs
- Factory Brake Proportioning Valve
- SS/TC Struts + Eibach Pro-Kit ?
- Brake fitting sizes
- lowering with 235/40 18's
- SS/TC shock and strut question
- Probably dumb question (rotors)
- B&G + Koni's
- sport line issue
- JBP rear k brace
- Canuck motorsport springs
- Are these ss/tc shocks/struts?
- Handbraking
- Stuck Brake Caliper
- B&G or Tenzo R for lowest
- Major front end clunking over bumps!
- Make a SC handle like a TC?
- SS/TC Slotted & Drilled
- Alignment Issue
- Coilover Recommendations?
- Source or Part # for SS/TC Struts?
- Free shipping on Goodridge Stainless Steel Brake Lines @ PFYC.com
- time between drop and alignment.
- I want to slam this thing.
- Drop springs alignment
- wut are the best springs for the 2.4 ss
- Air ride help!!!!!
- Sportlines + SS/TCs
- question about lowered cobalts
- Need help with spring install
- just installed my springs
- b&G coilover help!
- Fed-Ex = Santa Claus
- who has the RAW sub brace and strut bar?
- Big Brakes
- looking for suggestions
- Drum brake problem
- TEIN springs?
- front brakes making loud squeeky noise??
- ss springs...pics please
- SS springs on a ls
- Vibrations????
- Suspension Parts
- Are control arm joints supposed to look like this?
- Brake brands?
- Wearever Brakes -- Thoughts
- Specific Springs for SS/TC?
- Drag race set up
- Car feels unstable
- Helppp
- TC guys help
- h and r or tenzo R,with a 235/40/18?
- 08 rear brake question
- yay new goodies
- Front Brake Help
- ARK Gt-F Lowering Springs
- which springs drop the most
- BC Coilovers from Modern Performance
- Brake lines for ss/tc?
- drop on stock LT wheels
- Hey Maven:
- Strut tower brace or rear sway bar?
- How much brake fluid? etc
- Loud hum at 75-80 MPH
- anyone ever bend a endlink bracket on their coilovers?
- SS/SC springs not sitting right
- Stock TC Spring rates
- Anyone else seen the ebay coilovers?
- Drum shoe replacements?
- lowering springs ?
- What lower springs to get?
- Turning Radius
- Installed Powerslots, Hawk pads and FTP lines yesterday...
- Cobalt SS Suspension?
- Brakes
- question for people with sportlines
- SS/TC rotors
- ABS Light Help
- 245's and sportlines
- H&R Springs on SS/TC
- Has anyone done this?
- brake pads anyone?
- Which sway bars to get
- Lowering springs while keeping the warranty?
- 07 major brake pulsation
