View Full Version : Suspension
- WANTED FE5 springs Please
- Iebach swaybar ?
- Rear suspension "knock" sound
- Strut metal on metal sound on jacks or not
- Part Numbers for 5 x 114 hub swao 2009 ss tc
- Possible shock siezing?
- Pulsating brakes???
- Setup Question
- FE5 STRUT AND SHOCK PCKAG...Do you have it?
- Eibach or H&R
- Needing new brakes soon.
- Control Arm Bushing
- Question about new struts
- Grinding/humming/thumping noise
- Tenzo R springs - yes or no?
- FE5 Sway Bar
- FE5 LNF Alignment specs?
- Quick spring question
- Little confusion sportlines vs b&g s2's
- Eibach sportline
- Cant find any eibach sway bar kits in stock
- shock problem!
- Need help please!
- K-Sport squeak?
- OTTP Hardcore
- Eibach Pro kit vs sportlines?
- Any problems from dealer with lowered car?
- probably easy question on coilovers
- i got q's you got the a's
- Springs or coilovers?
- sway bars solid vs hollow
- Correct setup for 07 SS/NA
- zennn springs.
- HELP, Squeek noise
- EBC Rotors
- Wheelie in Reverse!!!
- Trim Bump Stops or no?
- Swaybar endlinks
- vibration help
- FE3 suspension questions problems etc.
- Best Place to by H&R Sport Springs?
- Lowering Springs for sport 08
- Tire Rack has Koni's 25% off until June 30th.
- 06 ss/SC front suspension
- 2.2 wheel hop
- SSTC Struts
- New Springs
- Which color to powdercoat big brake kit calipers?
- Any LS lowered on stock alloy 5 spoke?
- busted control arm bushings
- Thoughts on Cobalt Front Suspension
- Performance Ceramic Brake Pads
- Lowered SS's
- Stock Spring Rate????
- need to lower
- Allignment on lowered car
- Need help diassembling brake clalipers
- Thoughts on rear twisting beam sway bars
- Custom Drilled and slotted rotors TC
- Brake Help!
- B&G Spring Problem..
- H&r springs, have a weird problem
- ST Sway Bars
- 5 lug swap
- Sway bar?
- Look Nice, How Do They Perform?
- Alignment for rack spacers?
- 05 Cobalt SS/SC rear shock ? Old Schooler
- Camber adjustment kit???
- WANTED: Eibach Sportlines
- Few problems with suspension and brakes.... Looking for some guidance
- ebrake..?
- alignment with sportlines..?
- decent replacement struts
- anyone have a picture of the eibach prokit installed in a ss/sc ???
- Sway bars
- Rear sway bar
- OEM Rotors
- Advantages of coilovers?
- ksports finally came!
- pillow ball mounts
- brake swap
- Need new brakes
- Tenzo Springs vs Progress
- springs
- HELP! Steering Messed Up!
- clearance issues anyone?
- about my 2.4ss/na....would ss/sc springs make a noticable drop on my car?
- Cold weather and suspension noise
- Just a yes or no question
- Air Ride Setups
- OTTP sway bar installed
- How long do SS/TC struts/shocks last with Sportlines?
- Need help asap
- Labour & Parts cost for calipers?
- rear disc? off honda?
- im down in the clunks...
- Break Rotors Shot!!!
- Best Lower control arm bushing?
- SS/TC FE5 Strut Questions.... HELP
- TEIN springsssss
- back brakes shot?
- Grinding is back.
- does anyone make a direct bolt in strut/shock?
- Steering Rack Spacers
- Hello Am Selling A brand new Tein kit
- clunk noise from front end??
- Noob Question
- People with Pedders - ?
- quick question
- How does this sound?
- T/C Shocks and Struts vs Konis?
- Suspention Noise
- Aftermarket Shocks
- Parking/e-brake
- K Sport lowering springs?
- Coilovers ?
- Sway Bars?
- anyone has try this rotors?
- Running an OTTP Hardcore Bar with the 29mm Eibach front bar?
- Tein
- Vibration in steering wheel
- Well Im Tucking...
- Camber + Curb
- Front Lip=Scraped
- Front sway bar question
- Shocks already worn out i think
- eibach
- Squealing Brakes
- floor brace, is it worth it?
- How bad are Tenzos?
- Moaning/Creaking sound possibly brakes stuck?
- clunk/thud in front suspension...
- has anyone ever heard of these or used the brand
- 04 redline, does it have jl9?????
- New BC Coilovers
- need your opinions on springs.....
- OTTP Hardcore Bar or Street Bar?
- Eibach to Pedders?
- Air Ride Suspension Kit
- Cobalt SS Stainless Brake Lines - ship for only $1 @ PFYC.com
- tire rub issue (pics)
- please help! bushings
- How Much to Replace Steel Brake Line
- Brake System
- need some ideas, options, recommendations.....
- H&R's
- Brake fluid flushing intervals?
- When driving slowly down an off camber driveway I get a creak.....
- Eibach Sportlines
- Lnf front brake pads
- Sportlines on SS/TC
- Centric Premium Rotor for SS/TC? Heard of them?
- rear camber
- lnf struts?!?!?! WTF!?!?!?!
- time for new cabs
- Lowering springs. . . .again lol
- Am I the first?
- What will the difference be between...
- can some one please post pic of thier SS/NA on lowering springs and name what brand..
- front brakes hanging up
- ARK DT-P Coilovers for the SS/TC
- will lowering springs f___ with my snow traction?.
- OTTP Spherical control arm bushings??
- Need new brake setup
- which ones
- What happens to old posts in this Thread??
- Those of you with Pedders springs
- Good suspension information
- will cobalt springs fit on a cavi?
- ZENN vs TENZOS
- Eibach Sportlines & Pro-Kit - 10% HOLIDAY REBATE FROM EIBACH
- Stainless Steel Braided Brake Line Kits
- Need opinion!!
- Which springs for the SS/TC?
- stock ls/lt springs stock ss/na springs helppppp
- I need traction
- sportlines
- WTB: B&G Lowering Springs
- Ksport Coilovers
- question about lowering
- question about fe3 struts.........
- Clunk noise
- Springss
- SS/TC Sedan spring height
- H&R Race Springs SS/TC? (Dead Horse..I Know)
- need help
- One week sale - 10% off Hawk HPS or Ceramic brake pads @ PFYC.com
- what susp.mods are out for the ss t/c
- Cutting Coils
- Need new brake set up, help please!
- Harsh ride on stock 06 SS
- Help! Camber questions...
- Bolt coming loose on top of strut assembly
- Camber plates...
- Brake Caliper ?'s
- guessing its time for brakes
- Any feedback on Pedders Xa coilovers?
- brake problems
- help: front end links
- Traction Bars.
- rear camber shims
- best brakes and rotors to get?
- halp question
- Mobil 1 drag cobalt.
- Drop springs
- TC brake pads
- 06 to 08 rear suspension, will it bolt up?
- 4 lug to 5 lug...
- LS/LT w/ TC Springs
- build your own traction bars.
- ss/tc vs. ss/sc struts?
- Fs: Stock lnf coupe springs
- left front strut bent!!!!!!!!!!!!
- sportlines question..please help
- Ingalls Camber Kit
- Want to lower, will 3in Exhaust cause problems?
- What kind of struts should I get?
- OEM Brake Pressure on 09 LT w/ 16" Alloys
- big brakes
- few questions about lowering.
- ss/tc springs on a ss/na
- KYB GR-2 Struts/Shocks
- quick question about links?
- Other Car Brembos..??
- Brembo Rear Brake Swap
- SS/SC Springs on an LT
- Aftermarket sway bar links - questions
- Anyone know about brakes?
- looking for some springs.
- what will this do
- Need a permanent solution for my car's LCA bushings
- Ground Force Springs
- B&G S2 Sport Springs fit SS/TC?
- aftermarket rear calipers
- Lowering Springs with Aftermarket Exhaust
- Wanna Drop But Afraid Too.Help Please???
- prothane CAB part 7-234
- Kyb 4 gr-2 struts shocks with eibach prokit
- Difference in buddys sportlines & my coilovers
- pretty excited...
- lower spings for the ss/tc ? ? ? ?
- will this fit
- shaking between 50 and 60 ?
- 06 SS/SC Sway bar link torque
- springs
- which are better
- Stance suspension prototypes!
- 10% off Hawk HPS or Ceramic Brake Pads @ PFYC.com
- Anyone know what this metal clip is for?
