View Full Version : Suspension
- What bushings are these?
- End Links suggestions
- Progress vs Tein vs Ksport
- front end humming noise?
- Rear brakes loud humming/roaring noise
- where do you buy pedders at?
- lowering springs in winter.
- BC racing coilovers
- help....what should i get?
- H&R's Safe?
- Stock spring dimensions
- all lowered SS/NA's post pics please
- Cobalt Stock Suspension
- coilover questions
- need some break help
- help! fe5 on an lt
- Street Sport Industries Lowering Springs???
- from sportlines to pedders
- help please starting to get pissed
- not to much bounce not extreamly stiff
- lowering alignment
- SSC Springs
- Leaking reat caliper
- stiffer springs
- Help. Changing front rotors
- control arm bushings
- LNF suspension
- HELP!!! Strut replacement help
- how do i lower rear coilovers?
- Canuck Motorsport vs SSC Springs
- Lowering springs interchangablilty
- SS/TC SS Brake Lines
- Brakes question
- how to adjust coilovers (how to lower?)
- lowering springs with pics
- where to buy coilovers?
- 2.2 on Sportline's (PICS)
- Well im gonna need new rear brakes.
- ottp hardcore bar vs street bar
- Rear Sway Bar Question
- Shimming the rear for negative camber
- replaced rear brakes, turned rotors....
- Creaking Noise from the front end
- CED cross drilled and slotted rotor kit ?
- SS vs LS vs LT
- G5/SStc KYB Struts?
- Broken Studs...Again
- Axles issues
- Progress Vs. B & G Springs
- Possible issue
- SS/TC Springs?
- Excessive Pedal Travel
- 2009 SS, Brakes acting very strange
- Pedders Springs on an SS/TC
- Just installed new front and rear sway bars!
- Time for Suspension Maintenance - Thoughts?
- question on sportlines
- Which coil + question
- Vibration in 3rd after sportline drop
- Suggestion on brakes?
- Rubbing with 225/45s info
- footballs in rear
- Eibachs..Stock Shocks?? HELP! :)
- just got coilovers
- Coilovers, the decision
- Bump Stop Location?
- springs question..
- Bounce after lowering?
- Help me pick some new springs!
- What if you never install RACK SPACERS?
- couple suspension questions
- rear clunk..help
- Camber bolts installed
- SS/SC springs and struts on LT
- track differences between sedan and coupe
- Coilovers which ones and where?
- Best Suspension
- Switching to fe5 shocks and struts
- question
- Eibach Sportline's vs. H&R"s
- adding rear sway bar question
- Eibach Front and Rear Sway Bars
- FE1 to FE5
- Brembo Pin HELP!
- pissing me off
- Clunking Sound from Right Rear.
- strange clunky noise
- Where to buy Pedders
- Help - Best Lowering Spring for Cobalt SS/TC?
- need opinion
- Lowering Spring Vibration
- Brembo's are kick ass
- fixed the vibration
- These any good?
- Instalation question
- stance coilover customers
- SS/TC Strut Bar
- Pedders or B&G, and what steering rack spacer for each
- Coilovers.....Which ones!?!?
- what about a rear sway bar? worth it?
- best pads with oem rotor
- Camber Adjustments
- anybody know where i can get lowering springs
- moog part number
- axle nut size on lsj
- aftermarket rotors
- How do I get these to separate? (Steering rack removal...)
- suspension issue
- Never put in steering rack spacers.
- pedders for drag track?
- intermediate shaft installation
- are ksport good
- Strut bar
- spring question
- Lowering springs
- Rear toe/Thrust angle
- Getting a new setup
- Sportline VS. Pro Kit
- Poll: Coilovers or Pedders/LNF setup?
- Rotors
- What to replace with..??
- What strut shock replacements for SS 2.4?
- Have Sportlines - SS/TC Springs vs Pedders For Upgrade
- ordering stance coilovers... anything else i should get?
- extreme wear on right rear brakes
- Squeak squeak
- Hr springs?????
- Pedal play and Handbrake
- Brakes and Rotors....help
- ordered some parts
- Brake question: front inside pads worn/Inside rotors warped
- Wheel/Brembo Question
- installing rack spacers on 2.2 auto
- SSC Springs... Do they sag?
- FE3 to FE5 Sway Bar Upgrade - HELP
- Any tips for powergrid endlinks install?
- What Springs Are These?
- Rear Brembo Kit?
- can't stop squeeking
- Where to get new shock components?
- Severe brake problem!
- rear brakes
- Rear Caliper, Rotor, Pads part numbers and recommendations for 09 SS
- opinions, thanks
- Lowering Springs
- SSTC springs on an LT
- Struts and shocks question
- Lowering 2010 Cobalt SS
- I give up...CABs
- lubing points?
- what lowering springs are black?
- Lowering Springs & Struts Question
- Single pop/clunk
- Help Noise after installing h&r springs
- Air ride?
- SS/SC Springs on a 2.4L
- Interchangable Suspension?
- Struts
- help
- Control arm help
- control arm bushing going out??
- Megan vs. Stance vs. Pedders Coilovers
- shocks for lowered car
- Spring Question
- Pedders for 2009ss Question Bump Stops
- Some advice.
- all springs interchangable? LT to SS
- A couple of questions
- Lowering springs
- emergency answer...
- check my alignment
- Moog Endlink Question
- coilover ?'s
- need help for progress springs
- Cross Drilled Rotors
- Does a blown shock sit lower?
- Will OTTP Rack Spacers Fit?!
- Rear disc upgrade
- ksport or d2?
- Time for new lowering springs! =D
- Suspension dilemma
- ksport gt
- MacPherson Universal Strut Nut Remover
- Rear sway bar choices
- Left rear brake/caliper
- Need axle to move 1/4" further into transmission HELP!
- Inner tie rod...
- tie rod end question
- Lowered SS/SC with Stock rims?
- Where is your top hat tab on your front lowering springs?
- New Axle Installed - A new rattle arises
- dot 5 silicone brake fluid?
- 2008 SS Towing specifications
- top hats question
- Vibration from lowering
- tein springs question
- Wanting to upgrade rotors!!!
- LS/LT with Coilovers
- Who's got Koni Yellows in stock?
- BC Racing coilovers reviews? SS/TC application
- WTB B&G Lowering Springs
- Control Arm Help
- license plate light
- Thought this might be of interest to some...
- Question about ST lowering springs
- ARK GT performance springs
- weird rattle
- Brembo HELP PLEASE
- stuck nut on top of strut
- Steering wheel wobble (lets solve this damn problem)
- Reconnect Front end link?
- after lowering do i use factory spec for alignment?
- Lowering springs
- Ground Control Still Available?
- Who's good for shocks/struts besides Koni?
- Front suspension clunk??
- sway bar bolts
- will i rub
- Need Advice
- Caliper retainer clip
- rear suspension.
- Anyone using B&G Springs or coilovers? pics please
- traction bars
- springs for autox
- question about rear shocks
- Omg help please
- Hit a road-wide construction "bump", rattles + grease aftermath
- Steering Knuckles
- Any other 2.4 cars with Brembos?
- Whos good for Brakes?
- Urgent: Any Brembo help..? Also, a question..
- Pictures of Cobalts with Pedders springs please.
- H&R race springs just after install
- B&G axle question! just ordered need an answer asap!
- Just got my sway bars
- My ss/sc is now 5 years old 54,000 miles. Time for new suspension parts?
- Rubbing Issue...
- 2009 2.2 Suspension ??
- coilovers and bumpstops
- Moog swaybar endlinks
- 2006 LS suspension overhaul
- front end noise
- people with air ride.
- BEST Brake Rotors(4 BOLT)
- question on progress springs??
- Torn Ball Joint Boot (Front Stabilizer Linkage)
- Ordering from OTT Performance
- Progress rear swaybar
- anyone selling lowering springs??
